title says it all, actually. Since I installed dr460nized this last time (for those bluetooth problems and such), my Garuda Assistant settings has the default shell set for bash:
But terminal keeps hanging on to fish
any ideas?
Kernel: 6.6.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
available: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=62466f37-c375-42ba-aff7-3394e510b8d5 rw rootflags=subvol=@ quiet
resume=UUID=b1c2a014-9f50-4873-a7b9-7dd39ebec4f7 loglevel=3 nvidia_drm.modeset=1 ibt=off
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
Type: Laptop System: Dell product: G5 5590 v: N/A serial: <superuser required> Chassis: type: 10
Mobo: Dell model: 0F3T2G v: A00 serial: <superuser required> UEFI: Dell v: 1.22.0
date: 11/10/2022
ID-1: BAT0 charge: 45.4 Wh (100.0%) condition: 45.4/60.0 Wh (75.6%) volts: 16.9 min: 15.2
model: SMP DELL JJPFK87 type: Li-poly serial: <filter> status: full
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake gen: core 9 level: v3
note: check built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10)
microcode: 0xF4
desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3823 high: 4100 min/max: 800/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 4097 2: 4099 3: 4100 4: 4097 5: 4087 6: 800 7: 4100 8: 4100 9: 4099
10: 4100 11: 4099 12: 4098 bogomips: 62399
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: none off: eDP-1 empty: DP-2,
DP-3, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Dell driver: nvidia v: 545.29.02
alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current (as of 2023-10; EOL~2026-12-xx)
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie: gen: 2 speed: 5 GT/s
lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none off: DP-1,HDMI-A-1
empty: none bus-ID: 01:00.0 chip-ID: 10de:1f11 class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0c45:671f class-ID: 0e02
Display: x11 server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,intel,nv,vesa dri: iris
gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x2160 s-dpi: 96 s-size: 675x570mm (26.57x22.44") s-diag: 883mm (34.78")
Monitor-1: DP-1 mapped: DP-1-0 note: disabled pos: primary,top model: LG (GoldStar) HDR WFHD
serial: <filter> built: 2018 res: 2560x1080 hz: 60 dpi: 81 gamma: 1.2
size: 798x334mm (31.42x13.15") diag: 869mm (34.2") modes: max: 2560x1080 min: 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-1-0 note: disabled pos: bottom model: LG (GoldStar) ULTRAWIDE
serial: <filter> built: 2013 res: 2560x1080 hz: 60 dpi: 96 gamma: 1.2
size: 677x290mm (26.65x11.42") diag: 628mm (24.7") modes: max: 2560x1080 min: 640x480
Monitor-3: eDP-1 note: disabled model: BOE Display 0x084a built: 2018 res: 2560x1080 dpi: 142
gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
API: EGL v: 1.5 hw: drv: intel iris drv: nvidia platforms: device: 0 drv: nvidia device: 1
drv: iris device: 3 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: iris
inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2 glx-v: 1.4
direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL GT2) device-ID: 8086:3e9b
memory: 14.95 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 8 device: 0 type: integrated-gpu name: Intel UHD Graphics 630
(CFL GT2) driver: mesa in
tel v: 23.2.1-arch1.2 device-ID: 8086:3e9b surfaces: xcb,xlib
device: 1 type: discrete-gpu name: NVIDIA GeForce RTX 2060 driver: nvidia v: 545.29.02
device-ID: 10de:1f11 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe (LLVM 16.0.6 256
bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000
surfaces: xcb,xlib
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Dell driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f9
Device-3: Realtek USB Audio driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 1-4.5:11 chip-ID: 0bda:4014 class-ID: 0102 serial: <filter>
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse status: active
Device-1: Realtek vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 3c:00.0 chip-ID: 10ec:2502 class-ID: 0200
IF: enp60s0 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter vendor: Dell
driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 3d:00.0
chip-ID: 168c:003e class-ID: 0280 temp: 48.0 C
IF: wlp61s0 state: down mac: <filter>
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB rev: 3.0
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-1.2:3 chip-ID: 0bda:8153 class-ID: 0000
Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 1-14:7 chip-ID: 0cf3:e007 class-ID: e001
Local Storage: total: 1.14 TiB used: 923.22 GiB (78.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520 NVMe WDC 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD
serial: <filter> fw-rev: 20240012 temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-75Z10T3 size: 931.51 GiB
fw-rev: 4514 scheme: GPT
ID-1: / raw-size: 221.33 GiB size: 221.33 GiB (100.00%) used: 93.49 GiB (42.2%) fs: btrfs
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 592 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 221.33 GiB size: 221.33 GiB (100.00%) used: 93.49 GiB (42.2%) fs: btrfs
ID-4: /var/log raw-size: 221.33 GiB size: 221.33 GiB (100.00%) used: 93.49 GiB (42.2%)
ID-5: /var/tmp raw-size: 221.33 GiB size: 221.33 GiB (100.00%) used: 93.49 GiB (42.2%)
ID-1: swap-1 type: zram size: 15.31 GiB used: 256 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 12 dev: /dev/zram0
ID-2: swap-2 type: partition size: 16.84 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 63.0 C pch: 70.0 C mobo: N/A
Processes: 328 Uptime: 58m wakeups: 0 Memory: total: 16 GiB note: est. available: 15.31 GiB
used: 6.19 GiB (40.4%) Init: systemd v: 254 default: graphical tool: syst
emctl Compilers:
gcc: 13.2.1 Packages: 1435 pm: pacman pkgs: 1428 libs: 439 tools: octopi,paru pm: flatpak pkgs: 7
Client: shell wrapper v: 5.2.15-release inxi: 3.3.31
Garuda (2.6.17-1):
System install date: 2023-11-04
Last full system update: 2023-11-09 â»
(yeah, I know I need a restart, but thatâs because Iâve been trying to set my smartcard reader up again and Iâm failing in following back my own footsteps)
