Hello,
I recently installed Garuda to my new computer. After full system update, when I right click to display context menu, it is very slow to load. After that, it is very slow to respond (create new takes 15 seconds and more), which makes it almost unusable. This is happening also in Dolhpin, however not on Thunderbird and not for example in Konsole.
inxi:
Kernel: 6.8.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=a79da49c-0e12-4731-84ee-3d65d1b061cc rw rootflags=subvol=@
quiet resume=UUID=00311b23-dfff-4f27-9142-eb5a345652fd loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Convertible System: Dell product: XPS 13 7390 2-in-1 v: N/A
serial: <filter> Chassis: type: 31 serial: <filter>
Mobo: Dell model: 06CDVY v: A00 serial: <filter> part-nu: 08B0
uuid: 4c4c4544-0035-4710-8052-b4c04f5a3533 UEFI: Dell v: 1.29.0
date: 12/18/2023
ID-1: BAT0 charge: 35.9 Wh (100.0%) condition: 35.9/50.0 Wh (71.9%)
volts: 8.6 min: 7.6 model: SMP DELL NN6M885 type: Li-poly serial: <filter>
status: full
Info: model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xC4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 400 min/max: 400/3900 base/boost: 3500/1500 scaling:
driver: intel_pstate governor: performance volts: 1.0 V ext-clock: 100 MHz
cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400 8: 400
bogomips: 23961
Device-1: Intel Iris Plus Graphics G7 vendor: Dell driver: i915 v: kernel
arch: Gen-11 process: Intel 10nm built: 2019-21 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0 chip-ID: 8086:8a52
Display: server: X.Org v: 23.2.6 with: Xwayland v: 23.2.6
alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :1 screens: 1
Screen-1: 0 s-res: 3840x2400 s-dpi: 96 s-size: 1016x635mm (40.00x25.00")
s-diag: 1198mm (47.17")
Monitor-1: eDP-1 model: Sharp 0x14a8 built: 2018 res: 3840x2400 hz: 60
dpi: 336 gamma: 1.2 size: 290x180mm (11.42x7.09") diag: 340mm (13.4")
ratio: 16:10 modes: 3840x2400
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Plus Graphics (ICL
GT2) device-ID: 8086:8a52 memory: 30.39 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: integrated-gpu name: Intel
Iris Plus Graphics (ICL GT2) driver: mesa intel v: 24.0.5-arch1.1
device-ID: 8086:8a52 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM
Device-1: Intel Image Signal Processor vendor: Dell driver: N/A
bus-ID: 00:05.0 chip-ID: 8086:8a19 class-ID: 0480
Device-2: Intel Ice Lake-LP Smart Sound Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
API: ALSA v: k6.8.7-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.5 status: n/a (root, process) with:
Device-1: Intel Ice Lake-LP PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.2 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-3.4:3
IF: enp0s13f0u3u4 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c0000
Local Storage: total: 953.87 GiB used: 18.61 GiB (2.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: KBG40ZPZ1T02
NVMe KIOXIA 1024GB size: 953.87 GiB block-size: physical: 512 B
fw-rev: 10400106 temp: 43.9 C scheme: GPT
SMART: yes health: PASSED on: 76d 13h cycles: 1,313
read-units: 32,390,123 [16.5 TB] written-units: 27,006,780 [13.8 TB]
ID-1: / raw-size: 919.33 GiB size: 919.33 GiB (100.00%)
used: 18.61 GiB (2.0%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 584 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 919.33 GiB size: 919.33 GiB (100.00%)
maj-min: 259:2
ID-4: /var/log raw-size: 919.33 GiB size: 919.33 GiB (100.00%)
maj-min: 259:2
ID-5: /var/tmp raw-size: 919.33 GiB size: 919.33 GiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: zram size: 31.12 GiB used: 984.8 MiB (3.1%)
ID-2: swap-2 type: partition size: 34.24 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 49.0 C mobo: N/A
Memory: total: 32 GiB available: 31.12 GiB used: 4.12 GiB (13.2%)
igpu: 64 MiB
Processes: 356 Power: uptime: 5m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.44 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1906 libs: 547 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.26
System install date: 2024-04-18
Last full system update: 2024-04-22 ↻
; Windows dual boot: No/Undetected
Any help would be greatly appreciated. Thanks.
filo
22 April 2024 08:35
2
How recently did you last update?
This means that a reboot is pending. Just in case…
nepti
22 April 2024 09:09
3
That sounds like this issue:
I don’t notice this on a powerful workstation. But on a laptop with a weaker i5 7300HQ I can reproduce the problem. This also happens in the hamburger menus e.g. in Dolphin. But that should be fixed by now.
Watch the CPU usage when you open the context menu.
And yes, reboot your system like @filo already said.
FGD
22 April 2024 19:46
4
Can you plz post a screenshot of your context menu?
The fix that was made (not by Garuda) also fixed a quite different context menu look, so if you got the normal look and still got those slow downs, the issue is elsewhere.
I still have this issue, and i updated recently
it happens on the plasma deskop in dolphin and even in the console context menu
any other sugestions on how to solve this.
here my inixi by the way:
Kernel: 6.9.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=31611947-d9e1-4738-8cda-7d5fd48cf90e rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Garuda base: Arch Linux
Type: Convertible System: LENOVO product: 82BG v: Yoga 9 14ITL5
serial: <superuser required> Chassis: type: 31 v: Yoga 9 14ITL5
Mobo: LENOVO model: LNVNB161216 v: SDK0T76461WIN
serial: <superuser required> part-nu: LENOVO_MT_82BG_BU_idea_FM_Yoga 9
14ITL5 uuid: <superuser required> UEFI: LENOVO v: EHCN65WW
date: 07/01/2021
ID-1: BAT0 charge: 51.7 Wh (97.9%) condition: 52.8/60.0 Wh (88.0%)
power: 7.1 W volts: 8.7 min: 7.7 model: SMP BASE-BAT type: Li-poly
serial: <filter> status: charging cycles: 247
Info: model: 11th Gen Intel Core i7-1185G7 bits: 64 type: MT MCP
microcode: 0xB6
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 758 high: 1131 min/max: 400/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 1131 2: 774 3: 962
4: 1100 5: 400 6: 899 7: 400 8: 400 bogomips: 47923
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel alternate: xe arch: Gen-12.1 process: Intel 10nm
built: 2020-21 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4
bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:4 chip-ID: 04f2:b61e
s-diag: 1165mm (45.88")
Monitor-1: eDP-1 model: BOE Display 0x097e built: 2020 res: 3840x2160
hz: 60 dpi: 316 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 3840x2160
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 7.43 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 7 device: 0 type: integrated-gpu name: Intel
Xe Graphics (TGL GT2) driver: mesa intel v: 24.1.1-arch1.1
device-ID: 8086:9a49 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.1.1-arch1.1 (LLVM
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.9.3-zen1-1-zen status: kernel-api
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
IF-ID-2: nordlynx state: unknown speed: N/A duplex: N/A mac: N/A
Info: services: httpd, NetworkManager, systemd-timesyncd, wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0026
Local Storage: total: 953.87 GiB used: 137.82 GiB (14.4%)
model: MZVLB1T0HBLR-000L2 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 3L1QEXF7 temp: 39.9 C scheme: GPT
ID-1: / raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
used: 11.15 GiB (5.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 551 MiB size: 549.9 MiB (99.80%)
used: 724 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4
ID-3: /home raw-size: 750.57 GiB size: 737.72 GiB (98.29%)
used: 126.67 GiB (17.2%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
ID-4: /var/log raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
ID-5: /var/tmp raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.21 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 7.45 GiB used: 0 KiB (0.0%)
Src: /sys System Temperatures: cpu: 40.0 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.21 GiB used: 4.87 GiB (32.0%)
Processes: 342 Power: uptime: 40m states: freeze,mem,disk suspend: s2idle
suspend, test_resume image: 6.07 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1418 libs: 411 tools: octopi,paru pm: flatpak
pkgs: 0 Compilers: gcc: 14.1.1 Shell: garuda-inxi default: Bash v: 5.2.26
System install date: 2024-06-10
Last full system update: 2024-06-11 ↻
I’m afraid I would suggest to check open bugs at bugs.kde.org and open one if you find nothing similar.
No one else has reported context menu issues since the fix.
Have you tried an X11 session, rather than Wayland at the login screen?
Possibly an X session will not present these problems.
nepti
12 June 2024 15:40
8
Maybe a simple reboot will help?
Which global theme are you using?
@tbg definitely means wayland instead of x11, you are already using x11
Ya, don’t pay any attention to my absent mindedness these days. If it’s not my vision, then my memory fails me.
I am on Hyprland and I also have this issue. It occurs for any KDE application, but for other applications (e.g. Firefox) there is no problem. The context menu looks like this:
My waybar also likes to disappear sometimes but that’s definitely my fault (see Fixing plasmashell and I’ve created an abomination )
Inxi
Kernel: 6.9.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1 clocksource: tsc
root=UUID=e10546e7-5690-49ed-ad66-9e109988d6cd rw rootflags=subvol=@ quiet
resume=UUID=e6902d0d-c39c-49f2-9888-37fd2a4dbcfb loglevel=3 ibt=off
Desktop: Hyprland v: 0.41.0 tools: avail: swayidle,swaylock vt: 1 dm: SDDM Distro: Garuda
Type: Laptop System: HP product: HP Laptop 15-dy2xxx v: N/A serial: <superuser required> Chassis:
type: 10 serial: <superuser required>
Mobo: HP model: 87FE v: 57.25 serial: <superuser required> part-nu: 6K7X6UA#ABA
uuid: <superuser required> UEFI: AMI v: F.31 date: 03/25/2023
ID-1: BAT0 charge: 6.8 Wh (18.1%) condition: 37.6/41.0 Wh (91.5%) volts: 10.7 min: 11.4
model: HP Primary type: Li-ion serial: <filter> status: discharging cycles: 242
Info: model: 11th Gen Intel Core i3-1115G4 bits: 64 type: MT MCP arch: Tiger Lake gen: core 11
level: v4 note: check built: 2020 process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 2
microcode: 0x36
Topology: cpus: 1x cores: 2 tpc: 2 threads: 4 smt: enabled cache: L1: 160 KiB
desc: d-2x48 KiB; i-2x32 KiB L2: 2.5 MiB desc: 2x1.2 MiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 778 high: 1600 min/max: 400/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 663 3: 1600 4: 450 bogomips: 23961
Device-1: Intel Tiger Lake-LP GT2 [UHD Graphics G4] vendor: Hewlett-Packard driver: i915
v: kernel alternate: xe arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 0000:00:02.0 chip-ID: 8086:9a78 class-ID: 0300
Device-2: Luxvisions Innotech HP TrueVision HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 30c9:0013 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0 compositor: Hyprland
v: 0.41.0 driver: X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: 1
Monitor-1: eDP-1 model: AU Optronics 0x20ec built: 2018 res: 1366x768 dpi: 101 gamma: 1.2
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9 modes: 1366x768
API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris device: 1 drv: swrast
surfaceless: drv: iris wayland: drv: iris x11: drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.1-arch1.1 glx-v: 1.4
direct-render: yes renderer: Mesa Intel UHD Graphics (TGL GT2) device-ID: 8086:9a78
memory: 3.62 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: Intel UHD Graphics (TGL
GT2) driver: mesa intel v: 24.1.1-arch1.1 device-ID: 8086:9a78 surfaces: xcb,xlib,wayland
device: 1 type: cpu name: llvmpipe (LLVM 17.0.6 256 bits) driver: mesa llvmpipe
v: 24.1.1-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000 surfaces: xcb,xlib,wayland
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Hewlett-Packard
driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel, snd_soc_avs, snd_sof_pci_intel_tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.9.3-zen1-1-zen status: kernel-api tools: alsactl,alsamixer,amixer
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse status: active
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard
driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: 3000 bus-ID: 0000:01:00.0
IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 1-10:4 chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block:
hardware: no software: yes address: <filter> bt-v: 5.1 lmp-v: 10 status: discoverable: no
pairing: no
bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 238.47 GiB used: 42.29 GiB (17.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ256HBJD-00BH1 size: 238.47 GiB
fw-rev: HPS1NFAV temp: 42.9 C scheme: GPT
ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%) used: 42.29 GiB (18.4%) fs: btrfs
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 584 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%) used: 42.29 GiB (18.4%) fs: btrfs
ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%) used: 42.29 GiB (18.4%)
ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%) used: 42.29 GiB (18.4%)
ID-1: swap-1 type: zram size: 7.41 GiB used: 2.95 GiB (39.8%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 4 dev: /dev/zram0
ID-2: swap-2 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
maj-min: 259:3
System Temperatures: cpu: 53.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0 fan-2: 0
Memory: total: 8 GiB note: est. available: 7.41 GiB used: 4.12 GiB (55.6%)
Processes: 265 Power: uptime: 3h 14m states: freeze,mem,disk suspend: s2idle wakeups: 0
hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 2.95 GiB
services: power-profiles-daemon,upowerd Init: systemd v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1788 libs: 458 tools: pacseek,pamac,paru pm: flatpak pkgs: 0
Compilers: gcc: 14.1.1 Client: shell wrapper v: 5.2.26-release inxi: 3.3.34
System install date: 2024-05-26
Last full system update: 2024-06-12 ↻
Failed units: mnt-H.mount mnt-P.mount
FGD
12 June 2024 22:45
11
Have you guys tried changing the Kvantum theme (to various other ones, not just 1 alternative) and uninstalling kvantum?
If uninstalling, a re-login might be required.
Kvantum fixed similar issues a few months ago, but again it seemed to work, at least for those who had the issue back then.
Changing the Kvantum theme works! I’ll be using Nordic-bluish for now as it is very pretty and works for me too.
The problem now is that the Sweet theme packaged with Garuda is barely functional and causes context menus, especially large ones, to take 20+ seconds to load. For example, opening the Kvantum theme context menu took 26 seconds. As soon as I swapped themes, it was instantaneous.
FGD
14 June 2024 18:48
13
That’s probably not KDE then.
Sweet did make a fix on his kvantum theme that was improving performance months ago, but maybe it’s worth open a new issue on this in case he missed something.
system
Closed
16 June 2024 18:48
14
