USB not being detected
I have a HP 16GB USB attached to my USB port and it's not being detected by Garuda.
inxi -Fxxxza
System: Kernel: 5.12.13-zen1-2-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=770de3b2-c5a5-47e3-9c9d-f38998d4a2d3
Desktop: KDE Plasma 5.22.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: MSI model: B350M GAMING PRO (MS-7A39) v: 1.0 serial:
UEFI-[Legacy]: American Megatrends v: 2.F0 date: 03/19/2018
CPU: Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ family: 17 (23)
model-id: 8 stepping: 2 microcode: 800820D cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 81591
Speed: 3511 MHz min/max: 1550/3600 MHz boost: disabled Core speeds (MHz): 1: 3511 2: 3266
3: 3327 4: 3346 5: 3389 6: 3377 7: 3173 8: 3045 9: 3282 10: 3347 11: 3362 12: 3271
Graphics: Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nvidia v: 465.31
alternate: nouveau,nvidia_drm bus-ID: 1f:00.0 chip-ID: 10de:1c82 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0
Screen-1: 0 s-res: 1920x1080 s-dpi: 93 s-size: 524x292mm (20.6x11.5") s-diag: 600mm (23.6")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 94 size: 521x293mm (20.5x11.5")
diag: 598mm (23.5")
OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 465.31
direct render: Yes
Audio: Device-1: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel v: kernel bus-ID: 1f:00.1
chip-ID: 10de:0fb9 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 21:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Razer USA Nari Ultimate type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-3:2 chip-ID: 1532:051a class-ID: 0300
Sound Server-1: ALSA v: k5.12.13-zen1-2-zen running: yes
Sound Server-4: PipeWire v: 0.3.30 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8169 v: kernel port: e000 bus-ID: 1b:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp27s0 state: down mac:
Device-2: Realtek RTL8188EE Wireless Network Adapter driver: rtl8188ee v: kernel port: d000
bus-ID: 1c:00.0 chip-ID: 10ec:8179 class-ID: 0280
IF: wlp28s0 state: up mac:
Drives: Local Storage: total: 253.2 GiB used: 28.06 GiB (11.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: MidasForce model: SSD 256GB size: 238.47 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
serial: rev: S1111A0L scheme: MBR
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: HP model: v245L size: 14.73 GiB block-size:
physical: 512 B logical: 512 B serial: rev: 1100 scheme: GPT
Partition: ID-1: / raw-size: 97.66 GiB size: 238.47 GiB (244.19%) used: 28.06 GiB (11.8%) fs: btrfs
ID-2: /home raw-size: 97.66 GiB size: 238.47 GiB (244.19%) used: 28.06 GiB (11.8%) fs: btrfs
ID-3: /var/log raw-size: 97.66 GiB size: 238.47 GiB (244.19%) used: 28.06 GiB (11.8%) fs: btrfs
ID-4: /var/tmp raw-size: 97.66 GiB size: 238.47 GiB (244.19%) used: 28.06 GiB (11.8%) fs: btrfs
ID-1: swap-1 type: zram size: 663.9 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 663.9 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 663.9 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 663.9 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 663.9 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 663.9 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 663.9 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 663.9 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
ID-9: swap-9 type: zram size: 663.9 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram8
ID-10: swap-10 type: zram size: 663.9 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram9
ID-11: swap-11 type: zram size: 663.9 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram10
ID-12: swap-12 type: zram size: 663.9 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram11
Sensors: System Temperatures: cpu: 57.9 C mobo: 0 C gpu: nvidia temp: 42 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 40%
Info: Processes: 338 Uptime: 14m wakeups: 0 Memory: 7.78 GiB used: 4.56 GiB (58.6%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.0 Packages: pacman: 1410 lib: 338
Shell: fish v: 3.2.2 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.04
On all USB ports, only this Stick?
Read
If you include terminal outputs in your post please use the proper output format in your post. Using β€œ~” 3 times above and β€œ~” 3 times below the text block will provide a readable, raw look.
You may need to boot with the iommu=soft grub kernel boot parameter. Search the forum for detailed instructions on how to modify your Grub load line.
Try your USB2 ports on the rear of the mobo.
Maybe you could also try this one…
