Im stuck with a USB mouse issue, it freezes/gets stuck for 2-3 seconds every now and then... It worked fine yesterday after a new install with all updates.
Update, I disconected the USB mouse and tried a USB/Bluetooth mouse and that works fine (different (front instead of back) USB port).. But my wired mouse behaves the same regardless of which port its connected in...
Those screenshots you are posting are difficult to read. If you can paste logs from the terminal as normal text instead of screenshotting whatever that GUI program is, that would be way better.
I hate to say so, but it sounds like something is wrong with the mouse. Is it possible it has been damaged?
My bad, This is the X.org log output that might help.
It just suddenly started to get stuck wile using the computer, its a USB cable mouse, brand "Arrogant Bastard" ($40). Well everything wears out so its possible...
Gonna get another one to test.
Information [ 10318.109] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/event7)
Information [ 10318.109] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/event9)
Information [ 10318.110] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.1/0003:04D9:FC31.0166/input/input490/event7"
Information [ 10318.110] (**) Option "xkb_layout" "se"
Information [ 10318.110] (**) Option "xkb_variant" "nodeadkeys"
Information [ 10318.110] (II) XINPUT: Adding extended input device "USB Gaming Mouse" (type: KEYBOARD, id 12)
Information [ 10318.110] (II) event7 - USB Gaming Mouse: device is a keyboard
Information [ 10318.110] (II) event7 - USB Gaming Mouse: device removed
Information [ 10318.110] (II) event7 - USB Gaming Mouse: is tagged by udev as: Keyboard
Information [ 10318.112] (II) event7 - USB Gaming Mouse: device is a keyboard
Information [ 10318.112] (II) event7 - USB Gaming Mouse: is tagged by udev as: Keyboard
Information [ 10318.113] (**) Option "Device" "/dev/input/event8"
Information [ 10318.113] (**) USB Gaming Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
Information [ 10318.113] (**) USB Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
Information [ 10318.113] (**) USB Gaming Mouse Consumer Control: Applying InputClass "system-keyboard"
Information [ 10318.113] (**) USB Gaming Mouse Consumer Control: always reports core events
Information [ 10318.113] (II) Using input driver 'libinput' for 'USB Gaming Mouse Consumer Control'
Information [ 10318.113] (II) config/udev: Adding input device USB Gaming Mouse Consumer Control (/dev/input/event8)
Information [ 10318.114] (**) Option "AccelerationScheme" "none"
Information [ 10318.114] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.2/0003:04D9:FC31.0167/input/input491/event8"
Information [ 10318.114] (**) USB Gaming Mouse Consumer Control: (accel) acceleration factor: 2.000
Information [ 10318.114] (**) USB Gaming Mouse Consumer Control: (accel) acceleration threshold: 4
Information [ 10318.114] (**) USB Gaming Mouse Consumer Control: (accel) selected scheme none/0
Information [ 10318.114] (II) XINPUT: Adding extended input device "USB Gaming Mouse Consumer Control" (type: MOUSE, id 13)
Information [ 10318.114] (II) event8 - USB Gaming Mouse Consumer Control: device is a keyboard
Information [ 10318.114] (II) event8 - USB Gaming Mouse Consumer Control: device removed
Information [ 10318.114] (II) event8 - USB Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
Information [ 10318.114] (II) libinput: USB Gaming Mouse Consumer Control: needs a virtual subdevice
Information [ 10318.115] (II) event8 - USB Gaming Mouse Consumer Control: device is a keyboard
Information [ 10318.115] (II) event8 - USB Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
Information [ 10318.116] (**) Option "Device" "/dev/input/event8"
Information [ 10318.116] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.2/0003:04D9:FC31.0167/input/input491/event8"
Information [ 10318.116] (**) Option "xkb_layout" "se"
Information [ 10318.116] (**) Option "xkb_variant" "nodeadkeys"
Information [ 10318.116] (**) USB Gaming Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
Information [ 10318.116] (**) USB Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
Information [ 10318.116] (**) USB Gaming Mouse Consumer Control: Applying InputClass "system-keyboard"
Information [ 10318.116] (**) USB Gaming Mouse Consumer Control: always reports core events
Information [ 10318.116] (II) Using input driver 'libinput' for 'USB Gaming Mouse Consumer Control'
Information [ 10318.116] (II) XINPUT: Adding extended input device "USB Gaming Mouse Consumer Control" (type: KEYBOARD, id 14)
Information [ 10318.116] (II) libinput: USB Gaming Mouse Consumer Control: is a virtual subdevice
Information [ 10318.165] (**) Option "Device" "/dev/input/event6"
Information [ 10318.165] (**) USB Gaming Mouse: Applying InputClass "evdev pointer catchall"
Information [ 10318.165] (**) USB Gaming Mouse: Applying InputClass "libinput pointer catchall"
Information [ 10318.165] (**) USB Gaming Mouse: always reports core events
Information [ 10318.165] (II) Using input driver 'libinput' for 'USB Gaming Mouse'
Information [ 10318.165] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/event6)
Information [ 10318.217] (II) event6 - USB Gaming Mouse: device is a pointer
Information [ 10318.217] (II) event6 - USB Gaming Mouse: device removed
Information [ 10318.217] (II) event6 - USB Gaming Mouse: is tagged by udev as: Mouse
Information [ 10318.226] (**) Option "AccelerationScheme" "none"
Information [ 10318.226] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:04D9:FC31.0165/input/input489/event6"
Information [ 10318.226] (**) USB Gaming Mouse: (accel) acceleration factor: 2.000
Information [ 10318.226] (**) USB Gaming Mouse: (accel) acceleration threshold: 4
Information [ 10318.226] (**) USB Gaming Mouse: (accel) selected scheme none/0
Information [ 10318.226] (II) XINPUT: Adding extended input device "USB Gaming Mouse" (type: MOUSE, id 15)
Information [ 10318.279] (II) event6 - USB Gaming Mouse: device is a pointer
Information [ 10318.279] (II) event6 - USB Gaming Mouse: is tagged by udev as: Mouse
Information [ 10319.588] (II) event6 - USB Gaming Mouse: device removed
Information [ 10319.589] (II) config/udev: removing device USB Gaming Mouse
Information [ 10319.591] (II) UnloadModule: "libinput"
Information [ 10319.621] (II) config/udev: removing device USB Gaming Mouse
Information [ 10319.621] (II) event7 - USB Gaming Mouse: device removed
Information [ 10319.623] (II) UnloadModule: "libinput"
Information [ 10319.637] (II) config/udev: removing device USB Gaming Mouse Consumer Control
Information [ 10319.637] (II) event8 - USB Gaming Mouse Consumer Control: device removed
Information [ 10319.639] (II) UnloadModule: "libinput"
Information [ 10319.639] (II) config/udev: removing device USB Gaming Mouse Consumer Control
Information [ 10321.161] (II) No input driver specified, ignoring this device.
Information [ 10321.161] (II) This device may have been added with another device file.
Information [ 10321.161] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/mouse0)
Information [ 10321.170] (II) No input driver specified, ignoring this device.
Information [ 10321.170] (II) This device may have been added with another device file.
Information [ 10321.170] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/event9)
Information [ 10321.175] (**) Option "Device" "/dev/input/event8"
Information [ 10321.175] (**) USB Gaming Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
Information [ 10321.175] (**) USB Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
Information [ 10321.175] (**) USB Gaming Mouse Consumer Control: Applying InputClass "system-keyboard"
Information [ 10321.175] (**) USB Gaming Mouse Consumer Control: always reports core events
Information [ 10321.175] (II) Using input driver 'libinput' for 'USB Gaming Mouse Consumer Control'
Information [ 10321.175] (II) config/udev: Adding input device USB Gaming Mouse Consumer Control (/dev/input/event8)
Information [ 10321.177] (**) Option "AccelerationScheme" "none"
Information [ 10321.177] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.2/0003:04D9:FC31.016A/input/input495/event8"
Information [ 10321.177] (II) XINPUT: Adding extended input device "USB Gaming Mouse Consumer Control" (type: MOUSE, id 12)
Information [ 10321.177] (II) event8 - USB Gaming Mouse Consumer Control: device is a keyboard
Information [ 10321.177] (II) event8 - USB Gaming Mouse Consumer Control: device removed
Information [ 10321.177] (II) event8 - USB Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
Information [ 10321.177] (II) libinput: USB Gaming Mouse Consumer Control: needs a virtual subdevice
Information [ 10321.178] (**) USB Gaming Mouse Consumer Control: (accel) acceleration factor: 2.000
Information [ 10321.178] (**) USB Gaming Mouse Consumer Control: (accel) acceleration threshold: 4
Information [ 10321.178] (**) USB Gaming Mouse Consumer Control: (accel) selected scheme none/0
Information [ 10321.179] (**) Option "Device" "/dev/input/event8"
Information [ 10321.179] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.2/0003:04D9:FC31.016A/input/input495/event8"
Information [ 10321.179] (**) Option "xkb_layout" "se"
Information [ 10321.179] (**) Option "xkb_variant" "nodeadkeys"
Information [ 10321.179] (**) USB Gaming Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
Information [ 10321.179] (**) USB Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
Information [ 10321.179] (**) USB Gaming Mouse Consumer Control: Applying InputClass "system-keyboard"
Information [ 10321.179] (**) USB Gaming Mouse Consumer Control: always reports core events
Information [ 10321.179] (II) Using input driver 'libinput' for 'USB Gaming Mouse Consumer Control'
Information [ 10321.179] (II) XINPUT: Adding extended input device "USB Gaming Mouse Consumer Control" (type: KEYBOARD, id 13)
Information [ 10321.179] (II) event8 - USB Gaming Mouse Consumer Control: device is a keyboard
Information [ 10321.179] (II) event8 - USB Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
Information [ 10321.179] (II) libinput: USB Gaming Mouse Consumer Control: is a virtual subdevice
Information [ 10321.180] (**) Option "Device" "/dev/input/event7"
Information [ 10321.180] (**) USB Gaming Mouse: Applying InputClass "evdev keyboard catchall"
Information [ 10321.180] (**) USB Gaming Mouse: Applying InputClass "libinput keyboard catchall"
Information [ 10321.180] (**) USB Gaming Mouse: Applying InputClass "system-keyboard"
Information [ 10321.180] (**) USB Gaming Mouse: always reports core events
Information [ 10321.180] (II) Using input driver 'libinput' for 'USB Gaming Mouse'
Information [ 10321.180] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/event7)
Information [ 10321.181] (II) event7 - USB Gaming Mouse: is tagged by udev as: Keyboard
Information [ 10321.182] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.1/0003:04D9:FC31.0169/input/input494/event7"
Information [ 10321.182] (**) Option "xkb_layout" "se"
Information [ 10321.182] (**) Option "xkb_variant" "nodeadkeys"
Information [ 10321.182] (II) XINPUT: Adding extended input device "USB Gaming Mouse" (type: KEYBOARD, id 14)
Information [ 10321.182] (II) event7 - USB Gaming Mouse: device is a keyboard
Information [ 10321.182] (II) event7 - USB Gaming Mouse: device removed
Information [ 10321.183] (II) event7 - USB Gaming Mouse: device is a keyboard
Information [ 10321.183] (II) event7 - USB Gaming Mouse: is tagged by udev as: Keyboard
Information [ 10321.230] (**) Option "Device" "/dev/input/event6"
Information [ 10321.230] (**) USB Gaming Mouse: Applying InputClass "evdev pointer catchall"
Information [ 10321.230] (**) USB Gaming Mouse: Applying InputClass "libinput pointer catchall"
Information [ 10321.230] (**) USB Gaming Mouse: always reports core events
Information [ 10321.230] (II) Using input driver 'libinput' for 'USB Gaming Mouse'
Information [ 10321.230] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/event6)
Information [ 10321.283] (II) event6 - USB Gaming Mouse: device is a pointer
Information [ 10321.283] (II) event6 - USB Gaming Mouse: device removed
Information [ 10321.283] (II) event6 - USB Gaming Mouse: is tagged by udev as: Mouse
Information [ 10321.298] (**) Option "AccelerationScheme" "none"
Information [ 10321.298] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:04D9:FC31.0168/input/input493/event6"
Information [ 10321.298] (II) XINPUT: Adding extended input device "USB Gaming Mouse" (type: MOUSE, id 15)
Information [ 10321.299] (**) USB Gaming Mouse: (accel) acceleration factor: 2.000
Information [ 10321.299] (**) USB Gaming Mouse: (accel) acceleration threshold: 4
Information [ 10321.299] (**) USB Gaming Mouse: (accel) selected scheme none/0
Information [ 10321.351] (II) event6 - USB Gaming Mouse: device is a pointer
Information [ 10321.351] (II) event6 - USB Gaming Mouse: is tagged by udev as: Mouse
Information [ 10341.944] (II) event6 - USB Gaming Mouse: device removed
Information [ 10341.945] (II) config/udev: removing device USB Gaming Mouse
Information [ 10341.948] (II) UnloadModule: "libinput"
Information [ 10341.977] (II) config/udev: removing device USB Gaming Mouse
Information [ 10341.977] (II) event7 - USB Gaming Mouse: device removed
Information [ 10341.978] (II) UnloadModule: "libinput"
Information [ 10342.000] (II) event8 - USB Gaming Mouse Consumer Control: device removed
Information [ 10342.001] (II) config/udev: removing device USB Gaming Mouse Consumer Control
Information [ 10342.002] (II) UnloadModule: "libinput"
Information [ 10342.002] (II) config/udev: removing device USB Gaming Mouse Consumer Control
Information [ 10342.003] (II) UnloadModule: "libinput"
Information [ 10342.978] (II) No input driver specified, ignoring this device.
Information [ 10342.978] (II) This device may have been added with another device file.
Information [ 10342.978] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/mouse0)
Information [ 10342.989] (**) Option "Device" "/dev/input/event8"
Information [ 10342.989] (**) USB Gaming Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
Information [ 10342.989] (**) USB Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
Information [ 10342.989] (**) USB Gaming Mouse Consumer Control: Applying InputClass "system-keyboard"
Information [ 10342.989] (**) USB Gaming Mouse Consumer Control: always reports core events
Information [ 10342.989] (II) Using input driver 'libinput' for 'USB Gaming Mouse Consumer Control'
Information [ 10342.989] (II) config/udev: Adding input device USB Gaming Mouse Consumer Control (/dev/input/event8)
Information [ 10342.990] (II) event8 - USB Gaming Mouse Consumer Control: device is a keyboard
Information [ 10342.990] (II) event8 - USB Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
Information [ 10342.991] (**) Option "AccelerationScheme" "none"
Information [ 10342.991] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.2/0003:04D9:FC31.016D/input/input499/event8"
Information [ 10342.991] (II) XINPUT: Adding extended input device "USB Gaming Mouse Consumer Control" (type: MOUSE, id 12)
Information [ 10342.991] (II) event8 - USB Gaming Mouse Consumer Control: device removed
Information [ 10342.991] (II) libinput: USB Gaming Mouse Consumer Control: needs a virtual subdevice
Information [ 10342.992] (**) USB Gaming Mouse Consumer Control: (accel) acceleration factor: 2.000
Information [ 10342.992] (**) USB Gaming Mouse Consumer Control: (accel) acceleration threshold: 4
Information [ 10342.992] (**) USB Gaming Mouse Consumer Control: (accel) selected scheme none/0
Information [ 10342.992] (II) event8 - USB Gaming Mouse Consumer Control: device is a keyboard
Information [ 10342.992] (II) event8 - USB Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
Information [ 10342.993] (**) Option "Device" "/dev/input/event8"
Information [ 10342.993] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.2/0003:04D9:FC31.016D/input/input499/event8"
Information [ 10342.993] (**) Option "xkb_layout" "se"
Information [ 10342.993] (**) Option "xkb_variant" "nodeadkeys"
Information [ 10342.993] (**) USB Gaming Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
Information [ 10342.993] (**) USB Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
Information [ 10342.993] (**) USB Gaming Mouse Consumer Control: Applying InputClass "system-keyboard"
Information [ 10342.993] (**) USB Gaming Mouse Consumer Control: always reports core events
Information [ 10342.993] (II) Using input driver 'libinput' for 'USB Gaming Mouse Consumer Control'
Information [ 10342.993] (II) XINPUT: Adding extended input device "USB Gaming Mouse Consumer Control" (type: KEYBOARD, id 13)
Information [ 10342.993] (II) libinput: USB Gaming Mouse Consumer Control: is a virtual subdevice
Information [ 10342.994] (**) Option "Device" "/dev/input/event7"
Information [ 10342.994] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.1/0003:04D9:FC31.016C/input/input498/event7"
Information [ 10342.994] (**) USB Gaming Mouse: Applying InputClass "evdev keyboard catchall"
Information [ 10342.994] (**) USB Gaming Mouse: Applying InputClass "libinput keyboard catchall"
Information [ 10342.994] (**) USB Gaming Mouse: Applying InputClass "system-keyboard"
Information [ 10342.994] (**) USB Gaming Mouse: always reports core events
Information [ 10342.994] (II) Using input driver 'libinput' for 'USB Gaming Mouse'
Information [ 10342.994] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/event7)
Information [ 10342.994] (II) event7 - USB Gaming Mouse: device is a keyboard
Information [ 10342.994] (II) event7 - USB Gaming Mouse: device removed
Information [ 10342.994] (II) event7 - USB Gaming Mouse: is tagged by udev as: Keyboard
Information [ 10342.995] (**) Option "xkb_layout" "se"
Information [ 10342.995] (**) Option "xkb_variant" "nodeadkeys"
Information [ 10342.995] (II) XINPUT: Adding extended input device "USB Gaming Mouse" (type: KEYBOARD, id 14)
Information [ 10342.995] (II) event7 - USB Gaming Mouse: device is a keyboard
Information [ 10342.995] (II) event7 - USB Gaming Mouse: is tagged by udev as: Keyboard
Information [ 10342.996] (II) No input driver specified, ignoring this device.
Information [ 10342.996] (II) This device may have been added with another device file.
Information [ 10342.996] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/event9)
Information [ 10343.044] (**) Option "Device" "/dev/input/event6"
Information [ 10343.044] (**) USB Gaming Mouse: Applying InputClass "evdev pointer catchall"
Information [ 10343.044] (**) USB Gaming Mouse: Applying InputClass "libinput pointer catchall"
Information [ 10343.044] (**) USB Gaming Mouse: always reports core events
Information [ 10343.044] (II) Using input driver 'libinput' for 'USB Gaming Mouse'
Information [ 10343.044] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/event6)
Information [ 10343.097] (II) event6 - USB Gaming Mouse: device is a pointer
Information [ 10343.097] (II) event6 - USB Gaming Mouse: device removed
Information [ 10343.097] (II) event6 - USB Gaming Mouse: is tagged by udev as: Mouse
Information [ 10343.109] (**) Option "AccelerationScheme" "none"
Information [ 10343.109] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:04D9:FC31.016B/input/input497/event6"
Information [ 10343.109] (**) USB Gaming Mouse: (accel) acceleration factor: 2.000
Information [ 10343.109] (**) USB Gaming Mouse: (accel) acceleration threshold: 4
Information [ 10343.109] (**) USB Gaming Mouse: (accel) selected scheme none/0
Information [ 10343.109] (II) XINPUT: Adding extended input device "USB Gaming Mouse" (type: MOUSE, id 15)
Information [ 10343.162] (II) event6 - USB Gaming Mouse: device is a pointer
Information [ 10343.162] (II) event6 - USB Gaming Mouse: is tagged by udev as: Mouse
Information [ 10696.119] (II) event6 - USB Gaming Mouse: device removed
Information [ 10696.121] (II) config/udev: removing device USB Gaming Mouse
Information [ 10696.124] (II) UnloadModule: "libinput"
Information [ 10696.157] (II) config/udev: removing device USB Gaming Mouse
Information [ 10696.157] (II) event7 - USB Gaming Mouse: device removed
Information [ 10696.158] (II) UnloadModule: "libinput"
Information [ 10696.181] (II) event8 - USB Gaming Mouse Consumer Control: device removed
Information [ 10696.182] (II) config/udev: removing device USB Gaming Mouse Consumer Control
Information [ 10696.183] (II) UnloadModule: "libinput"
Information [ 10696.183] (II) config/udev: removing device USB Gaming Mouse Consumer Control
Information [ 10696.184] (II) UnloadModule: "libinput"
Information [ 10697.154] (II) No input driver specified, ignoring this device.
Information [ 10697.154] (II) This device may have been added with another device file.
Information [ 10697.154] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/mouse0)
Information [ 10697.163] (**) Option "Device" "/dev/input/event8"
Information [ 10697.163] (**) USB Gaming Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
Information [ 10697.163] (**) USB Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
Information [ 10697.163] (**) USB Gaming Mouse Consumer Control: Applying InputClass "system-keyboard"
Information [ 10697.163] (**) USB Gaming Mouse Consumer Control: always reports core events
Information [ 10697.163] (II) Using input driver 'libinput' for 'USB Gaming Mouse Consumer Control'
Information [ 10697.163] (II) config/udev: Adding input device USB Gaming Mouse Consumer Control (/dev/input/event8)
Information [ 10697.164] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.2/0003:04D9:FC31.0170/input/input503/event8"
Information [ 10697.164] (II) XINPUT: Adding extended input device "USB Gaming Mouse Consumer Control" (type: MOUSE, id 12)
Information [ 10697.164] (II) event8 - USB Gaming Mouse Consumer Control: device is a keyboard
Information [ 10697.164] (II) event8 - USB Gaming Mouse Consumer Control: device removed
Information [ 10697.164] (II) event8 - USB Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
Information [ 10697.164] (II) libinput: USB Gaming Mouse Consumer Control: needs a virtual subdevice
Information [ 10697.166] (**) Option "AccelerationScheme" "none"
Information [ 10697.166] (**) USB Gaming Mouse Consumer Control: (accel) acceleration factor: 2.000
Information [ 10697.166] (**) USB Gaming Mouse Consumer Control: (accel) acceleration threshold: 4
Information [ 10697.166] (**) USB Gaming Mouse Consumer Control: (accel) selected scheme none/0
Information [ 10697.167] (II) event8 - USB Gaming Mouse Consumer Control: device is a keyboard
Information [ 10697.167] (II) event8 - USB Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
Information [ 10697.168] (**) Option "Device" "/dev/input/event8"
Information [ 10697.168] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.2/0003:04D9:FC31.0170/input/input503/event8"
Information [ 10697.168] (**) Option "xkb_layout" "se"
Information [ 10697.168] (**) Option "xkb_variant" "nodeadkeys"
Information [ 10697.168] (**) USB Gaming Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
Information [ 10697.168] (**) USB Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
Information [ 10697.168] (**) USB Gaming Mouse Consumer Control: Applying InputClass "system-keyboard"
Information [ 10697.168] (**) USB Gaming Mouse Consumer Control: always reports core events
Information [ 10697.168] (II) Using input driver 'libinput' for 'USB Gaming Mouse Consumer Control'
Information [ 10697.168] (II) XINPUT: Adding extended input device "USB Gaming Mouse Consumer Control" (type: KEYBOARD, id 13)
Information [ 10697.168] (II) libinput: USB Gaming Mouse Consumer Control: is a virtual subdevice
Information [ 10697.169] (**) Option "Device" "/dev/input/event7"
Information [ 10697.169] (**) USB Gaming Mouse: Applying InputClass "evdev keyboard catchall"
Information [ 10697.169] (**) USB Gaming Mouse: Applying InputClass "libinput keyboard catchall"
Information [ 10697.169] (**) USB Gaming Mouse: Applying InputClass "system-keyboard"
Information [ 10697.169] (**) USB Gaming Mouse: always reports core events
Information [ 10697.169] (II) No input driver specified, ignoring this device.
Information [ 10697.169] (II) This device may have been added with another device file.
Information [ 10697.169] (II) Using input driver 'libinput' for 'USB Gaming Mouse'
Information [ 10697.169] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/event7)
Information [ 10697.169] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/event9)
Information [ 10697.170] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.1/0003:04D9:FC31.016F/input/input502/event7"
Information [ 10697.170] (**) Option "xkb_layout" "se"
Information [ 10697.170] (**) Option "xkb_variant" "nodeadkeys"
Information [ 10697.170] (II) XINPUT: Adding extended input device "USB Gaming Mouse" (type: KEYBOARD, id 14)
Information [ 10697.170] (II) event7 - USB Gaming Mouse: device is a keyboard
Information [ 10697.170] (II) event7 - USB Gaming Mouse: device removed
Information [ 10697.170] (II) event7 - USB Gaming Mouse: is tagged by udev as: Keyboard
Information [ 10697.171] (II) event7 - USB Gaming Mouse: device is a keyboard
Information [ 10697.171] (II) event7 - USB Gaming Mouse: is tagged by udev as: Keyboard
Information [ 10697.215] (**) Option "Device" "/dev/input/event6"
Information [ 10697.215] (**) USB Gaming Mouse: Applying InputClass "evdev pointer catchall"
Information [ 10697.215] (**) USB Gaming Mouse: Applying InputClass "libinput pointer catchall"
Information [ 10697.215] (**) USB Gaming Mouse: always reports core events
Information [ 10697.215] (II) Using input driver 'libinput' for 'USB Gaming Mouse'
Information [ 10697.215] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/event6)
Information [ 10697.268] (II) event6 - USB Gaming Mouse: device is a pointer
Information [ 10697.268] (II) event6 - USB Gaming Mouse: device removed
Information [ 10697.268] (II) event6 - USB Gaming Mouse: is tagged by udev as: Mouse
Information [ 10697.278] (**) Option "AccelerationScheme" "none"
Information [ 10697.278] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:04D9:FC31.016E/input/input501/event6"
Information [ 10697.278] (II) XINPUT: Adding extended input device "USB Gaming Mouse" (type: MOUSE, id 15)
Information [ 10697.279] (**) USB Gaming Mouse: (accel) acceleration factor: 2.000
Information [ 10697.279] (**) USB Gaming Mouse: (accel) acceleration threshold: 4
Information [ 10697.279] (**) USB Gaming Mouse: (accel) selected scheme none/0
Information [ 10697.331] (II) event6 - USB Gaming Mouse: device is a pointer
Information [ 10697.331] (II) event6 - USB Gaming Mouse: is tagged by udev as: Mouse
Information [ 10698.249] (II) event6 - USB Gaming Mouse: device removed
Information [ 10698.250] (II) config/udev: removing device USB Gaming Mouse
Information [ 10698.252] (II) UnloadModule: "libinput"
Information [ 10698.288] (II) config/udev: removing device USB Gaming Mouse
Information [ 10698.288] (II) event7 - USB Gaming Mouse: device removed
Information [ 10698.290] (II) UnloadModule: "libinput"
Information [ 10698.312] (II) config/udev: removing device USB Gaming Mouse Consumer Control
Information [ 10698.312] (II) event8 - USB Gaming Mouse Consumer Control: device removed
Information [ 10698.314] (II) UnloadModule: "libinput"
Information [ 10698.314] (II) config/udev: removing device USB Gaming Mouse Consumer Control
Information [ 10699.277] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/mouse0)
Information [ 10699.278] (II) No input driver specified, ignoring this device.
Information [ 10699.278] (II) This device may have been added with another device file.
Information [ 10699.285] (**) Option "Device" "/dev/input/event8"
Information [ 10699.285] (**) USB Gaming Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
Have you tried the wired mouse on a different computer? It is possible the wire for the mouse is bad or even a connection in the mouse. I guess there could be a USB port issue but seems less likely. I am not an expert in anything just what I would consider if I were in your situation.
Your port is going into power-saving mode. First, check your BIOS settings. Then, try adding this two-line "fix" to a file named i915.conf and insert the file in /etc/modprobe.d, reboot and see if that helps.
That's a real biggie. It may be at the heart of this problem, who knows? Use the forum Search function to help you solve that first, and if you still cannot update, start a new help request in the appropriate subforum.
That sounds like the best avenue to find out what is going on. What changed afterwards?
I first thought "kernel", but last -zen update was on 2022-12-02.
Some USB stuff maybe? I see libusb-compat updated on 2022-12-10.
Downgrading packages is not generally a nice thing to do to an Arch system, but try installing the previous libusb-compat 0.1.7-1 version and see if it works again.
Check in your /var/log/pacman.log. It gets huge pretty fast, use grep:
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 102: ID 04d9:fc31 Holtek Semiconductor, Inc. USB Gaming Mouse
Bus 001 Device 004: ID 046d:c31c Logitech, Inc. Keyboard K120
Bus 001 Device 003: ID 0bda:c123 Realtek Semiconductor Corp. Bluetooth Radio
Bus 001 Device 002: ID 04a9:190f Canon, Inc. CanoScan LiDE 220
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
xinput list
ā” Virtual core pointer id=2 [master pointer (3)]
ā ā³ Virtual core XTEST pointer id=4 [slave pointer (2)]
ā ā³ USB Gaming Mouse Consumer Control id=13 [slave pointer (2)]
ā ā³ USB Gaming Mouse id=15 [slave pointer (2)]
⣠Virtual core keyboard id=3 [master keyboard (2)]
ā³ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
ā³ Power Button id=6 [slave keyboard (3)]
ā³ Power Button id=7 [slave keyboard (3)]
ā³ Sleep Button id=8 [slave keyboard (3)]
ā³ Logitech USB Keyboard id=9 [slave keyboard (3)]
ā³ Logitech USB Keyboard Consumer Control id=10 [slave keyboard (3)]
ā³ Logitech USB Keyboard System Control id=11 [slave keyboard (3)]
ā³ USB Gaming Mouse id=12 [slave keyboard (3)]
ā³ USB Gaming Mouse Consumer Control id=14 [slave keyboard (3)]
I trying to figure out how to do it.. Linux takes a lot of learning
āā[email protected] in ~ as š§ took 53ms
[š“] Ć sudo pacman -Q libusb-compat 0.1.7-1
[sudo] password for y4ku:
libusb-compat 0.1.8-1
error: package '0.1.7-1' was not found```
