USB mouse freezing for 3 sec every 1-5 min
I did reboot and my problem is unaffected
Does it misbehave booting from the Garuda live disk?
Do you have another system to test the mouse?
YES!!! It does and im sure it didnt while I installed Garuda!! Then it must be the mouse itself that has broken down...
Possible (and sad).
Maybe it's just the cable worn out from repeated bending, it happened to me some time ago, it was damaged just where it comes out of the mouse.
It was easy to replace with one from another broken mouse, but I guess it depends on the model.
Actually, now that I test to bend the cable on purpose it works just fine...... I“m such a noob :sweat_smile:
