I guess my search ninja skills are not that great, but is there a way to upgrade to Harpy Eagle without doing a fresh install? I'm running Garuda on my work laptop and have so many hours into setting it up for work I'd hate to lose it all.
Rolling release
sudo pacman -Syu
or
upd
or
update
Welcome to a rolling-release distro.
If you want to be sure to bring in all the new packages, I think you could use:
curl https://mirrors.fossho.st/garuda/iso/garuda/dr460nized/210926/garuda-dr460nized-linux-zen-210926-pkgs.txt | grep -Eo '^[^ ]+' | paru -Syu --needed -
Not my idea, just found this hint, which seems interesting to me:
Although it might be noted that installing snapper-support will provide access to the new snapper integration with this special release
That wasn't the question
6 posts were split to a new topic: snapper-support not in the repo
Thanks for all the responses haha, yeah rolling release that didn't occur to me
