Hi, I am in Mexico, trying to update a brand new installation of Garuda. Doing nothing but the installation and using the initial upgrade popup, it errors out. After installing a few apps, still the same, and I get the output below. Note that this must be a Mexico issue, because I get the same thing trying to update EndeavorOS, Archman, Archcraft, Arco, apparently any Arch distro:
[sudo] password for carlc:
:: Synchronizing package databases…
garuda is up to date
core is up to date
extra is up to date
multilib is up to date
chaotic-aur is up to date
→ Refreshing mirrorlists using rate-mirrors, please be patient…![]()
garuda downloading…
core downloading…
extra downloading…
multilib downloading…
chaotic-aur downloading…
:: Starting full system upgrade…
:: Replace mhwd-db-garuda-git with garuda/mhwd-db-garuda? [Y/n] y
:: Replace mhwd-garuda-git with garuda/mhwd-garuda? [Y/n] y
:: Replace onevpl with extra/libvpl? [Y/n] y
warning: qbittorrent: local (4.6.3-1) is newer than extra (4.6.2-2)
warning: vulkan-headers: local (1:1.3.276-1) is newer than extra (1:1.3.274-1)
resolving dependencies…
:: There are 2 providers available for dbus-units:
:: Repository core
- dbus-broker-units 2) dbus-daemon-units
Enter a number (default=1): 2
looking for conflicting packages…
:: installing dotnet-runtime (8.0.0.sdk100-3) breaks dependency ‘dotnet-runtime-7.0’ required by pinta
Press enter to exit
inxi output:
Kernel: 6.1.60-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=9a98bb49-4ce7-4798-a3b8-41fe2bb1e4f3 rw rootflags=subvol=@
Type: Desktop System: HP product: HP Pavilion Desktop PC 570-p0XX v: N/A
Mobo: HP model: 82F2 v: 00 serial: <superuser required> UEFI: AMI v: F.35
date: 11/01/2018
Info: model: Intel Core i3-7100 bits: 64 type: MT MCP arch: Kaby Lake
model-id: 0x9E (158) stepping: 9 microcode: 0xF4
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 825 high: 900 min/max: 800/3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 900 3: 800 4: 800
bogomips: 31211
Device-1: Intel HD Graphics 630 vendor: Hewlett-Packard driver: i915
active: DP-2 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5912
Display: x11 server: X.Org v: 21.1.9 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1680x1050 s-dpi: 96 s-size: 444x277mm (17.48x10.91")
s-diag: 523mm (20.6")
Monitor-1: DP-2 model: Acer X223W serial: <filter> built: 2008
res: 1680x1050 hz: 60 dpi: 90 gamma: 1.2 size: 474x296mm (18.66x11.65")
diag: 559mm (22") ratio: 16:10 modes: max: 1680x1050 min: 720x400
API: Vulkan v: 1.3.269 layers: 5 device: 0 type: integrated-gpu name: Intel
HD Graphics 630 (KBL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:5912 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: Intel 200 Series PCH HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
API: ALSA v: k6.1.60-1-lts status: kernel-api tools: N/A
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5 chip-ID: 8087:0aa7
Local Storage: total: 1.2 TiB used: 5.09 GiB (0.4%)
model: WD10EZEX-60WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MQ01ACF032
size: 298.09 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: 1D scheme: MBR
ID-1: / raw-size: 152.33 GiB size: 152.33 GiB (100.00%)
used: 5.04 GiB (3.3%) fs: btrfs dev: /dev/sda6 maj-min: 8:6
used: 48.1 MiB (50.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 152.33 GiB size: 152.33 GiB (100.00%)
ID-4: /var/log raw-size: 152.33 GiB size: 152.33 GiB (100.00%)
ID-5: /var/tmp raw-size: 152.33 GiB size: 152.33 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.52 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 33.0 C mobo: N/A
Processes: 228 Uptime: 25m wakeups: 0 Memory: total: 8 GiB note: est.
available: 7.52 GiB used: 2.7 GiB (35.9%) Init: systemd v: 254
pm: pacman pkgs: 1232 libs: 387 tools: paru Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2024-01-27
Last full system update: 2024-01-27
Is partially upgraded: Yes
I have been running ArcoLinux and/or EndeavourOS for 18 months with no update issues. I have tried updating after running my Windscribe VPN to the USA. No difference. Yes, I have decent Internet speeds here. I do not have any issues updating Debian distros. EOS was updating earlier this week, but began to get this problem, which caused me to look at other distros like Garuda, Archcraft and Archman.
Thanks for the help, I like what I see here on Garuda!
-Carl
