Hello.
I updated my garuda after 6 months and now everything crashed. I have to reach out everything through the terminal and my accounts have been singed out of chrome, the shortcuts have been reseted, etc.
How do i fix this? What is the best choice to not loose all my data and fix this?
Can you describe your problem in more detail? Please also follow the post template and post your garuda-inxi.
BTRFS snapshots + hard disk backups. Those are great ways to start.
But that will mainly work next time, once you get back your files. I was specifically answering the above quoted question.
@FGD I have btrfs snapshots. So to log in to the snapshots I have to select the snapshot from the advanced option for garuda and wait for some time for it? I tried that once but it crashed my whole system and was not able to open even the garuda menu
Here's my garuda-inxi
root=UUID=a455354a-de9b-4579-ac0d-867687fd5f18 rw rootflags=subvol=@
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming F15 FX506LH_FX566LH
Mobo: ASUSTeK model: FX506LH v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: FX506LH.310 date: 11/26/2021
ID-1: BAT1 charge: 21.7 Wh (54.5%) condition: 39.8/48.1 Wh (82.8%)
volts: 12.2 min: 11.7 model: ASUS A32-K55 type: Li-ion serial: N/A
status: charging
Info: model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 2 microcode: 0xEC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2929 high: 4236 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 4236 2: 4209 3: 4170
4: 3920 5: 4203 6: 900 7: 898 8: 900 bogomips: 39999
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: ASUSTeK driver: i915
v: kernel ports: active: eDP-1 empty: none bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU117M vendor: ASUSTeK driver: nvidia v: 510.54
alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f99 class-ID: 0300
Device-3: Sonix USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-7:3 chip-ID: 322e:202c class-ID: 0e02
loaded: modesetting gpu: i915 display-ID: :0 screens: 1
Monitor-1: eDP-1 model: Najing CEC Panda 0x004d built: 2019
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.0.0
direct render: Yes
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-3: Lite-On Dell Wireless Mouse WM118 type: USB
driver: hid-generic,usbhid bus-ID: 1-2:2 chip-ID: 04ca:00a8 class-ID: 0301
Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 1-14:4 chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter>
bt-v: 3.0 lmp-v: 5.2 sub-v: 2202 hci-v: 5.2 rev: 915
Info: acl-mtu: 1021:6 sco-mtu: 240:8 link-policy: rswitch sniff
link-mode: slave accept
service-classes: rendering, capturing, object transfer, audio, telephony
Local Storage: total: 476.94 GiB used: 121.9 GiB (25.6%)
model: 2210 MTFDHBA512QFD size: 476.94 GiB block-size: physical: 512 B
rev: P6MA001 temp: 52.9 C scheme: GPT
ID-1: / raw-size: 146.49 GiB size: 146.49 GiB (100.00%)
used: 121.87 GiB (83.2%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
used: 25.8 MiB (10.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 146.49 GiB size: 146.49 GiB (100.00%)
ID-4: /var/log raw-size: 146.49 GiB size: 146.49 GiB (100.00%)
ID-5: /var/tmp raw-size: 146.49 GiB size: 146.49 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.6 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: 72.0 C pch: 66.0 C mobo: 27.8 C
Fan Speeds (RPM): cpu: 0
Processes: 288 Uptime: 0m wakeups: 1 Memory: 7.6 GiB used: 2.65 GiB (34.8%)
Init: systemd v: 250 tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1
Packages: pacman: 1490 lib: 359 Shell: fish v: 3.3.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.14
Garuda (2.5.6-2):
System install date: 2021-12-04
Last full system update: 2022-03-30
Snapshots: Timeshift (maybe)
Please don’t ignore this part of my question, thank you.
@TNE so i didn't update my garuda for more than 6 months, and yesterday i updated it with
sudo pacman - Syy
sudo pacman - Syu
After that i felt a few bugs but now the shortcuts are reseted, the latte dock is gone - just a blank screen with wallpaper is there as homescreen.
Google account have been erased from chrome.
These are the things which I can find wrong for now but i think there are many more.
What shortcuts are we talking about specifically here?
Honestly, for your Google account I would say just log in again, doesn’t seem like a big deal.
In regard to latte-dock, it looks like you will have to reset the configuration as described here:
@TNE the shortcuts i am talking about are system keyboard shortcuts like maximizing minimizing window, getting to next, previous desktop, etc
Garuda is a rolling distribution.
You must update rolling distributions on a regular basis, (weekly or bi-weekly at most).
Waiting 6 moths between updates is not acceptable system maintenance on a rolling distribution.
You are mistaking Garuda for a static distribution.
Switch back to Ubuntu or Mint if you intend to update annually or semi-annually.
You’ve already been told before, dude:
