poppler=22.07.0 <- poppler-qt5: impossibile soddisfare le dipendenze
when i try to update programs with discover i get this error message
Welcome
Use terminal and command
garuda-update
Also follow the template and post always your garuda-inxi as text like
Kernel: 5.18.15-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters:
looks like
parameters:
in forum.
Refreshing mirrorlists using rate-mirrors, please be patient..
:: Sincronizzazione dei database in corso...
garuda 86,3 KiB 49,8 KiB/s 00:02 [------------------------------------] 100%
core 158,0 KiB 341 KiB/s 00:00 [------------------------------------] 100%
extra 1710,6 KiB 1342 KiB/s 00:01 [------------------------------------] 100%
community 6,7 MiB 2,35 MiB/s 00:03 [------------------------------------] 100%
multilib 174,1 KiB 231 KiB/s 00:01 [------------------------------------] 100%
chaotic-aur 1978,0 KiB 916 KiB/s 00:02 [------------------------------------] 100%
spawn pacman -Su
warning: reflector-simple: local (3.2-1) is newer than garuda (2.0-1)
resolving dependencies...
:: poppler-git and poppler are in conflict. Remove poppler? [y/N] y
:: removing poppler breaks dependency 'poppler=22.07.0' required by poppler-qt5
Kernel: 5.18.15-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=c1981c03-97d3-4d2a-a678-35d43e6fb27b rw rootflags=subvol=@
resume=UUID=3fec4e73-0b45-4c49-ad35-cc8ceb4a1771 loglevel=3
Desktop: KDE Plasma v: 5.25.3 tk: Qt v: 5.15.5 info: latte-dock
Type: Laptop System: HP product: HP 250 G8 Notebook PC
Mobo: HP model: 85F3 v: 40.33 serial: <superuser required> UEFI: Insyde
v: F.40 date: 11/30/2020
ID-1: BAT1 charge: 36.4 Wh (96.0%) condition: 37.9/41.0 Wh (92.2%)
volts: 13.0 min: 11.4 model: COMPAL PABAS0241231 type: Li-ion
Info: model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 built: 2019-21 process: Intel 10nm family: 6
model-id: 0x7E (126) stepping: 5 microcode: 0xB0
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1972 high: 3002 min/max: 400/3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 2248 2: 1915 3: 2057
4: 1806 5: 633 6: 3002 7: 2613 8: 1509 bogomips: 23961
filling
Device-1: Intel Iris Plus Graphics G7 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21 ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:8a52 class-ID: 0300
Device-2: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 0408:5365 class-ID: 0e02
Monitor-1: eDP-1 model: AU Optronics 0x3791 built: 2020 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
OpenGL: renderer: Mesa Intel Iris Plus Graphics (ICL GT2) v: 4.6 Mesa
22.1.4 direct render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
Sound Server-1: ALSA v: k5.18.15-zen1-1-zen running: yes
speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0
bus-ID: 1-10:4 chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 238.47 GiB used: 16.01 GiB (6.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: BC511 HFM256GDJTNI-82A0A size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: HPS0 temp: 49.9 C scheme: GPT
ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%) used: 16.01 GiB
(7.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%) used: 16.01
GiB (7.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%) used: 16.01
ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%) used: 16.01
ID-1: swap-1 type: zram size: 7.55 GiB used: 227.5 MiB (2.9%)
System Temperatures: cpu: 65.0 C mobo: N/A
Processes: 303 Uptime: 44m wakeups: 1 Memory: 7.55 GiB used: 4.7 GiB
(62.2%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.0 Packages: pacman: 1326 lib: 350 Shell: fish v: 3.5.1
Garuda (2.6.5-1):
System install date: 2022-08-01
Last full system update: 2022-08-02
Is partially upgraded: Yes
Same with N?
Please read
Which part do you not understand in
Risoluzione della dipendenza non riuscita:
i tried to use garuda-update but this is the output:
spawn pacman -Su
garuda-inxi:
v: Type1ProductConfigId serial: Chassis: type: 10
serial:
Mobo: HP model: 85F3 v: 40.33 serial: UEFI: Insyde
serial: status: charging
filling
Display: x11 server: [X.Org](http://x.org/) v: 21.1.4 with: Xwayland v: 22.1.3
IF: eno1 state: down mac:
IF: wlo1 state: up mac:
address:
class-ID: 0104
serial: rev: HPS0 temp: 49.9 C scheme: GPT
Garuda (2.6.5-1):
No need for two threads with same problem.
try removing poppler-qt5 and updating
sudo pacman -R poppler-qt5 && garuda-update
Or don't use poppler-git and keep poppler
sudo pacman -R poppler-git && garuda-update
You might as well try to remove the offending package with pacman -Rdd, this ignores the dependency conflicts seen above.
