Update issue nerd-fronts
Hello, I've got some issues with updating.
first the mirrorlist, second dependencies.
╭─[email protected] in ~ took 4s
╰─λ garuda-update
[sudo] password for algori:
garuda is up to date
core is up to date
extra is up to date
community 7,2 MiB 166 KiB/s 00:44 [-------------------------] 100%
multilib is up to date
chaotic-aur 2,3 MiB 142 KiB/s 00:17 [-------------------------] 100%
--> Refreshing mirrorlists using reflector, please be patient..
[2023-01-27 14:25:59] WARNING: failed to rate http(s) download (https://de.arch.mirror.kescher.at/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2023-01-27 14:26:05] WARNING: failed to rate http(s) download (https://mirror.theo546.fr/archlinux/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2023-01-27 14:26:11] WARNING: failed to rate http(s) download (https://geo.mirror.pkgbuild.com/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2023-01-27 14:26:16] WARNING: failed to rate http(s) download (https://mirror.ubrco.de/archlinux/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2023-01-27 14:26:22] WARNING: failed to rate http(s) download (https://mirror.chaoticum.net/arch/community/os/x86_64/community.db): Download timed out after 5 second(s).
garuda downloading...
core downloading...
extra downloading...
community downloading...
multilib downloading...
chaotic-aur downloading...
spawn pacman -Su
:: Replace nerd-fonts-fantasque-sans-mono with community/ttf-fantasque-nerd? [Y/n] y
resolving dependencies...
:: removing nerd-fonts-fantasque-sans-mono breaks dependency 'nerd-fonts-fantasque-sans-mono' required by garuda-bspwm-settings
thank you for your help
best regards algori
@dr460nf1r3 , I don't see nerd-fonts-fantasque-sans-mono anymore in the AUR.
Should we put ttf-fantasque-nerd in
I don't see bspwm in the download place. :slight_smile:
Missing garuda-inxi :slight_smile:
╭─[email protected] in ~ took 1h5m20s
[:red_circle:] × garuda-inxi
Kernel: 6.0.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=48637f32-6542-4b8d-9034-f859ede8855e rw [email protected]
resume=UUID=73407c84-654f-4dc0-9a0c-af4b77f8503c loglevel=3
Desktop: Xfce v: 4.18.0 tk: Gtk v: 3.24.35 info: xfce4-panel wm: bspwm
v: 0.9.10 vt: 7 dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Hewlett-Packard product: HP EliteBook Folio 9480m
v: A3009DD10303 serial: Chassis: type: 10
serial:
Mobo: Hewlett-Packard model: 22DA v: KBC Version 92.15
serial: UEFI: Hewlett-Packard v: M85 Ver. 01.33
date: 10/27/2015
ID-1: BAT0 charge: 35.7 Wh (96.0%) condition: 37.2/37.2 Wh (100.0%)
volts: 16.5 min: 14.8 model: Hewlett-Packard Primary type: Li-ion
serial: status: not charging
Info: model: Intel Core i7-4600U bits: 64 type: MT MCP arch: Haswell
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2322 high: 3300 min/max: 800/3300 scaling:
driver: intel_cpufreq governor: performance cores: 1: 1996 2: 1996 3: 3300
4: 1996 bogomips: 21551
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:0a16 class-ID: 0300
Device-2: Chicony HP HD Webcam type: USB driver: uvcvideo bus-ID: 2-7:5
chip-ID: 04f2:b477 class-ID: 0e02 serial:
Display: x11 server: [X.Org](http://X.Org) v: 21.1.4 compositor: Picom v: git-c4107
driver: X: loaded: intel unloaded: modesetting alternate: fbdev,vesa
dri: i965 gpu: i915 display-ID: :0 screens: 1
s-diag: 414mm (16.31")
Monitor-1: eDP-1 mapped: eDP1 model: ChiMei InnoLux 0x14a4 built: 2014
res: 1366x768 hz: 60 dpi: 112 gamma: 1.2 size: 310x170mm (12.2x6.69")
diag: 355mm (14") ratio: 16:9 modes: 1366x768
missing.
Device-1: Intel Haswell-ULT HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c
Device-2: Intel 8 Series HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20
Sound API: ALSA v: k6.0.8-zen1-1-zen running: yes
Sound Server-1: JACK v: 1.9.21 running: no
Sound Server-2: PulseAudio v: 16.1 running: yes
Sound Server-3: PipeWire v: 0.3.64 running: yes
Device-1: Intel Ethernet I218-LM vendor: Hewlett-Packard driver: e1000e
v: kernel port: 5080 bus-ID: 00:19.0 chip-ID: 8086:155a class-ID: 0200
IF: enp0s25 state: down mac:
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0 chip-ID: 8086:08b1 class-ID: 0280
IF: wlo1 state: up mac:
bus-ID: 2-4:3 chip-ID: 8087:07dc class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 4 state: down
address:
Local Storage: total: 238.47 GiB used: 53.24 GiB (22.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD7TB3Q-256G-1006
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: rev: 0306 scheme: GPT
ID-1: / raw-size: 229.42 GiB size: 229.42 GiB (100.00%)
used: 53.22 GiB (23.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%)
used: 594 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 229.42 GiB size: 229.42 GiB (100.00%)
ID-4: /var/log raw-size: 229.42 GiB size: 229.42 GiB (100.00%)
ID-5: /var/tmp raw-size: 229.42 GiB size: 229.42 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.64 GiB used: 5.52 GiB (72.2%)
ID-2: swap-2 type: partition size: 8.8 GiB used: 21.9 MiB (0.2%)
System Temperatures: cpu: 49.0 C mobo: N/A
Processes: 313 Uptime: 71d 4h 47m wakeups: 90 Memory: 7.64 GiB
used: 6.4 GiB (83.7%) Init: systemd v: 252 default: graphical
pkgs: 1362 libs: 371 tools: pamac,paru Shell: fish v: 3.6.0
running-in: alacritty inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2021-09-03
Last full system update: 2023-01-18 ↻
Relevant software: timeshift NetworkManager mkinitcpio
sorry didn't guess it's important for this issue
Hi,
I edit your text, please use
Terminal text
then others can easily expand or copy the text.
terminal text
then others can easily expand or copy the text in the view. Move the mouse pointer over it in the upper right corner.
It is always important. For example I see you have
But
Hybrids are not supported (we cannot support any possible combination of DE's/WM's/etc) and particularly we cannot know how they were achieved.
Although it is an old installation, so this might have occurred long ago, do you remember what you did?
bspwm is not maintained anymore, so I don't know if we will update garuda-bspwm-settings.
I'd try a:
sudo pacman -Rdd nerd-fonts-fantasque-sans-mono && sudo pacman -S ttf-fantasque-nerd
I recall seeing something about fantasque nerd some upgrades ago but I don't remember having any problem, too bad I don't remember exactly what pacman said at the time.
I get these in my pacman.log:
[2023-01-22T12:21:23+0100] [ALPM] removed nerd-fonts-fantasque-sans-mono (2.2.2-1)
[2023-01-22T12:22:35+0100] [ALPM] installed ttf-fantasque-nerd (2.3.1-2)
actually I did not get it fully either.
Why it is both. I'm fine with just having bspwm.
but I'm to scared to just delete stuff, because I figured it may depends on something I'm not able to catch with the usual tree asking command. dependence command
I'm not using the desktop environment. and I missed to catch up with you guys to get rid of all the stuff I don't want/need.
I'll try your recommendation.
My apologies, you did nothing wrong.
I didn't remember that bspwm edition was based on xfce DE. No hybrid...
Thanks, SGS :slight_smile: Update file PKGBUILD (291185e3) · Commits · Garuda Linux / Themes and Settings / Settings / garuda-bspwm-settings · GitLab
Just garuda-update again...
awright seem to work, not finished yet but it starts updating.
should I be worried about the warnings I mentioned earlier?
[2023-01-27 16:11:38] WARNING: failed to rate http(s) download (https://mirror.theo546.fr/archlinux/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2023-01-27 16:11:44] WARNING: failed to rate http(s) download (https://archlinux.uk.mirror.allworldit.com/archlinux/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2023-01-27 16:11:51] WARNING: failed to rate http(s) download (https://archlinux.za.mirror.allworldit.com/archlinux/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2023-01-27 16:11:56] WARNING: failed to rate http(s) download (https://de.arch.mirror.kescher.at/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2023-01-27 16:12:02] WARNING: failed to rate http(s) download (https://geo.mirror.pkgbuild.com/community/os/x86_64/community.db): Download timed out after 5 second(s).
and is there something I can do to get rid of the UI things I'm not using?
or detect programms I won't use anyway. be sure to not crash the entire system by removing things?
best regards and thank you for the fast and usefull help
Those are only warnings and I don't think you need to worry much about them.
By-the-way, about one year ago, we moved new releases from reflector to rate-mirrors.
You may want to install it (it will replace the other) and garuda-update will use it automatically.
No need to remove anything in my opinion. Again, sorry for my confusion with the xfce release...
no problem. I got it.
I want to remove as many as possible, because I like to have just the things I really need.
Don't like the thought of garbadgeing my system. I definitely don't like the most UI programs. they are mostly confusing overloaded und irritating.
raw is better, and also command base is more direct.
how do I change them? I'll look up how to install rate-mirrors
sudo pacman -Syu rate-mirrors
List packages
pacman -Qeq
Remove you do not like :smiley:
sudo pacman -R app-name
You are the only one who can know what you don't need. :wink:
When you identify a package that you think you don't need, check if it depends on something else, and if not, you can definitely remove it.
If it helps you:
https://wiki.archlinux.org/title/Pacman/Rosetta#Querying_package_dependencies
https://wiki.archlinux.org/title/Pacman#Pactree
However bspwm is one of the lightest editions!
oh wow I figured I had to change something manually, edit some files.
I'll try to try a simple install command first in the future
this is really nice of you.
of curse I was there before. Like I said. I didn't catch up with you about that.
It means. first I have to read by myself, what each package means.
and there are a lot.
and if I'm not sure,
because it may depends on something not mentioned by the command for check up the tree buildings.
it is in deed not as easy to see.
because of the combination of the desktop xfce and bspwm
I might break something, by rm xfce components
maybe I have to go for trial and error at some point anyways.
there will be always the latest image.
:slight_smile:
