Update issue about qemu related packages
Kernel: 6.5.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=647e731d-2d7b-4d32-bb3e-73141eaf0bc1 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId
serial: Chassis: type: 10 serial:
Mobo: HP model: 81F0 v: 63.21 serial: UEFI: Insyde
v: F.44 date: 08/07/2018
ID-1: BAT1 charge: 15.2 Wh (71.7%) condition: 21.2/32.6 Wh (65.1%)
volts: 15.9 min: 14.8 model: COMPAL PABAS0241231 type: Li-ion
serial: status: discharging
Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1899 high: 1900 min/max: 500/1900 scaling:
driver: intel_cpufreq governor: performance cores: 1: 1900 2: 1900 3: 1900
4: 1896 bogomips: 15962
Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-8 process: Intel 14nm built: 2014-15 ports:
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1616
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 M430 Radeon
520 Mobile] vendor: Hewlett-Packard driver: radeon v: kernel
alternate: amdgpu arch: GCN-1 code: Southern Islands process: TSMC 28nm
built: 2011-20 pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s lanes: 8 bus-ID: 0d:00.0 chip-ID: 1002:6660 class-ID: 0380
temp: 45.0 C
Device-3: Chicony HP TrueVision HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-5:4 chip-ID: 04f2:b56c
class-ID: 0e02 serial:
compositor: kwin_x11 driver: X: loaded: modesetting,radeon
alternate: fbdev,intel,vesa dri: iris,radeonsi gpu: i915 display-ID: :0
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x70ec built: 2015 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 23.1.7-arch1.1 renderer: Mesa Intel HD Graphics
5500 (BDW GT2) direct-render: Yes
Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c
chip-ID: 8086:9ca0 class-ID: 0403
API: ALSA v: k6.5.3-zen1-1-zen status: kernel-api with: aoss
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 5000
bus-ID: 07:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp7s0 state: down mac:
Device-2: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard driver: wl
v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 13:00.0 chip-ID: 14e4:4365 class-ID: 0280
IF: wlp19s0 state: up mac:
Device-1: Broadcom BCM43142A0 Bluetooth 4.0 driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-4:3 chip-ID: 0a5c:216d
class-ID: fe01 serial:
rfk-block: hardware: no software: yes address: bt-v: 4.0 lmp-v: 6
Local Storage: total: 1.14 TiB used: 37.47 GiB (3.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT250MX500SSD1
size: 232.89 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: fw-rev: 045 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HTS541010A9E680
tech: HDD rpm: 5400 serial: fw-rev: A7G0 scheme: MBR
used: 37.47 GiB (16.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 7.67 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 55.0 C pch: 48.0 C mobo: N/A gpu: radeon
temp: 45.0 C
Processes: 191 Uptime: 25m wakeups: 1 Memory: total: 8 GiB
available: 7.67 GiB used: 2.73 GiB (35.6%) Init: systemd v: 254
pm: pacman pkgs: 1866 libs: 549 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
System install date: 2023-09-19
Last full system update: 2023-09-19
the system not updating system out of update message displaying but cant update system
warning: ignoring package qemu-base-8.1.1-1
warning: cannot resolve “qemu-base=8.1.1-1”, a dependency of “qemu-desktop”
:: The following package cannot be upgraded due to unresolvable dependencies:
qemu-desktop
:: Do you want to skip the above package for this upgrade? [y/N] y
y
looking for conflicting packages…
:: installing qemu-common (8.1.1-1) breaks dependency ‘qemu-common=8.1.0-2’ required by qemu-base
:: installing qemu-img (8.1.1-1) breaks dependency ‘qemu-img=8.1.0-2’ required by qemu-base
:: installing qemu-system-x86 (8.1.1-1) breaks dependency ‘qemu-system-x86=8.1.0-2’ required by qemu-base
:: installing qemu-audio-alsa (8.1.1-1) breaks dependency ‘qemu-audio-alsa=8.1.0-2’ required by qemu-desktop
:: installing qemu-audio-dbus (8.1.1-1) breaks dependency ‘qemu-audio-dbus=8.1.0-2’ required by qemu-desktop
:: installing qemu-audio-jack (8.1.1-1) breaks dependency ‘qemu-audio-jack=8.1.0-2’ required by qemu-desktop
:: installing qemu-audio-oss (8.1.1-1) breaks dependency ‘qemu-audio-oss=8.1.0-2’ required by qemu-desktop
:: installing qemu-audio-pa (8.1.1-1) breaks dependency ‘qemu-audio-pa=8.1.0-2’ required by qemu-desktop
:: installing qemu-audio-pipewire (8.1.1-1) breaks dependency ‘qemu-audio-pipewire=8.1.0-2’ required by qemu-d
esktop
:: installing qemu-audio-sdl (8.1.1-1) breaks dependency ‘qemu-audio-sdl=8.1.0-2’ required by qemu-desktop
:: installing qemu-audio-spice (8.1.1-1) breaks dependency ‘qemu-audio-spice=8.1.0-2’ required by qemu-desktop
:: installing qemu-block-curl (8.1.1-1) breaks dependency ‘qemu-block-curl=8.1.0-2’ required by qemu-desktop
:: installing qemu-block-dmg (8.1.1-1) breaks dependency ‘qemu-block-dmg=8.1.0-2’ required by qemu-desktop
:: installing qemu-block-nfs (8.1.1-1) breaks dependency ‘qemu-block-nfs=8.1.0-2’ required by qemu-desktop
:: installing qemu-block-ssh (8.1.1-1) breaks dependency ‘qemu-block-ssh=8.1.0-2’ required by qemu-desktop
:: installing qemu-chardev-spice (8.1.1-1) breaks dependency ‘qemu-chardev-spice=8.1.0-2’ required by qemu-des
ktop
:: installing qemu-hw-display-qxl (8.1.1-1) breaks dependency ‘qemu-hw-display-qxl=8.1.0-2’ required by qemu-d
esktop
:: installing qemu-hw-display-virtio-gpu (8.1.1-1) breaks dependency ‘qemu-hw-display-virtio-gpu=8.1.0-2’ requ
:: installing qemu-hw-display-virtio-gpu-gl (8.1.1-1) breaks dependency 'qemu-hw-display-virtio-gpu-gl=8.1.0-2
:: installing qemu-hw-display-virtio-gpu-pci (8.1.1-1) breaks dependency ‘qemu-hw-display-virtio-gpu-pci=8.1.0
:: installing qemu-hw-display-virtio-gpu-pci-gl (8.1.1-1) breaks dependency ‘qemu-hw-display-virtio-gpu-pci-gl
:: installing qemu-hw-display-virtio-vga (8.1.1-1) breaks dependency ‘qemu-hw-display-virtio-vga=8.1.0-2’ requ
:: installing qemu-hw-display-virtio-vga-gl (8.1.1-1) breaks dependency 'qemu-hw-display-virtio-vga-gl=8.1.0-2
:: installing qemu-hw-usb-host (8.1.1-1) breaks dependency ‘qemu-hw-usb-host=8.1.0-2’ required by qemu-desktop
:: installing qemu-hw-usb-redirect (8.1.1-1) breaks dependency ‘qemu-hw-usb-redirect=8.1.0-2’ required by qemu
-desktop
:: installing qemu-hw-usb-smartcard (8.1.1-1) breaks dependency ‘qemu-hw-usb-smartcard=8.1.0-2’ required by qe
mu-desktop
:: installing qemu-ui-curses (8.1.1-1) breaks dependency ‘qemu-ui-curses=8.1.0-2’ required by qemu-desktop
:: installing qemu-ui-dbus (8.1.1-1) breaks dependency ‘qemu-ui-dbus=8.1.0-2’ required by qemu-desktop
:: installing qemu-ui-egl-headless (8.1.1-1) breaks dependency ‘qemu-ui-egl-headless=8.1.0-2’ required by qemu
-desktop
:: installing qemu-ui-gtk (8.1.1-1) breaks dependency ‘qemu-ui-gtk=8.1.0-2’ required by qemu-desktop
:: installing qemu-ui-opengl (8.1.1-1) breaks dependency ‘qemu-ui-opengl=8.1.0-2’ required by qemu-desktop
:: installing qemu-ui-sdl (8.1.1-1) breaks dependency ‘qemu-ui-sdl=8.1.0-2’ required by qemu-desktop
:: installing qemu-ui-spice-app (8.1.1-1) breaks dependency ‘qemu-ui-spice-app=8.1.0-2’ required by qemu-deskt
op
:: installing qemu-ui-spice-core (8.1.1-1) breaks dependency ‘qemu-ui-spice-core=8.1.0-2’ required by qemu-des
ktop
:: installing qemu-vhost-user-gpu (8.1.1-1) breaks dependency ‘qemu-vhost-user-gpu=8.1.0-2’ required by qemu-d
esktop
these are the error messages displayed when trying to upgrade
Please always use also forum search, I think this is a new case of an issue reported many times recently. E.g.:
I hope this will help again.
Please edit your post.
Like
Kernel: 5.18.15-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters:
output in forum looks like
    parameters:
Easier to read, specially on the smartphone. :slight_smile:
