:: Synchronising package databases...
core 131,5 KiB 465 KiB/s 00:00 [--------------------------------------------------------------------] 100%
extra 1601,4 KiB 3,92 MiB/s 00:00 [--------------------------------------------------------------------] 100%
community 5,5 MiB 4,78 MiB/s 00:01 [--------------------------------------------------------------------] 100%
multilib 150,4 KiB 147 MiB/s 00:00 [--------------------------------------------------------------------] 100%
chaotic-aur 1022,3 KiB 1398 KiB/s 00:01 [--------------------------------------------------------------------] 100%
warning: gesture-manager-x-git: local (0.1-1) is newer than chaotic-aur (r9.ce6f7d0-1)
warning: libldac: local (2.0.2.3-3) is newer than extra (2.0.2.3-1)
:: Replace python-dbus with extra/dbus-python? [Y/n] y
:: Replace python-dbus-common with extra/dbus-python? [Y/n] y
resolving dependencies...
:: nohang and nohang-git are in conflict. Remove nohang-git? [y/N] y
:: dbus-python and python2-dbus are in conflict. Remove python2-dbus? [y/N] y
warning: dependency cycle detected:
warning: mesa will be installed before its libglvnd dependency
warning: nvidia-utils will be installed before its libglvnd dependency
warning: xorg-server will be installed before its libglvnd dependency
warning: smbclient will be installed before its cifs-utils dependency
Blockquote
Total Download Size: 3,35 MiB
Total Installed Size: 6457,33 MiB
Net Upgrade Size: 183,83 MiB
:: Retrieving packages...
starship-git-0.52.1.1525.g5758abf1-1-x86_64 3,3 MiB 9,41 MiB/s 00:00 [--------------------------------------------------------------------] 100%
(455/455) checking keys in keyring [--------------------------------------------------------------------] 100%
(455/455) checking package integrity [--------------------------------------------------------------------] 100%
error: starship-git: signature from "Nico Jensch [email protected]" is unknown trust
:: File /var/cache/pacman/pkg/starship-git-0.52.1.1525.g5758abf1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] y
error: failed to commit transaction (invalid or corrupted package)
Blockquote
I have tried already:
sudo pacman -Sy archlinux-keyring
sudo pacman-key --populate archlinux
sudo pacman-key --refresh-keys
sudo pacman -Syu
Thanks in advance! (and why did this breakage happen actually?)
Good first try, it was the right thing to do - you just missed one little thing: starship-git a Chaotic-AUR package rather than an Archlinux one so we need to populate chaotic-aur instead of archlinux.
Afaik, you could also simply use the Garuda Assisstants "refresh keyring" option to fix this.
Its not really a breakage, it just seems to me that you didnt update your system for a some time - in this time a new signing key for packages was introduced which your system does not know yet. chaotic-keyring is the package in which the keys are shipped. As this package is not installed before all others the signature is still invalid at the time of updating.
==> Appending keys from chaotic.gpg...
==> Locally signing trusted keys in keyring...
-> Locally signing key EF925EA60F33D0CB85C44AD13056513887B78AEB...
==> Importing owner trust values...
==> Updating trust database...
gpg: next trustdb check due at 2021-08-02
Then sudo pacman -Syyu
starship-git-0.52.1.1525.g5758abf1-1-x86_64 3,3 MiB 5,27 MiB/s 00:01 [--------------------------------------------------------------------] 100%
Blockquote
So i think the result is the same. Should i answer no instead of yes, to that query? The update does not proceed. What could be the problem here?
and then update afterwards. The keyring package needs to be updated before populating the keyring
(notice that usually -Sy is not good practice as it might result in a partial upgrade, in this case however we only need the keyring updated before everything else)
All upgrading! Thank you very much for your help and patience! I'll put these procedures up some place, so i can right away help others upon same issue.
I wonder what this Starship-git is? Could the problem had been solved by removing this source / app or so? I don't have anything too precious installed.
