Unintentionally deleted chaotic-mirrorlist
Hello Garuda users.
I had problem with the update because some packages was corupted or something like that. So I decided to uninstall everything by sudo pacman -Rns $(pacman -Qtdq) and then I want to install it again. Unfortunatelly I can not do anyhing now because of following error:
error: config file /etc/pacman.d/chaotic-mirrorlist could not be read: No such file or directory
even when I try to install it by sudo pacman -S chaotic-mirrorlist it jgive me the same error.
Please help me.
Try a:
update remote fix
Restoring a previously working snapshot could be another option.
Thanks, This fixed the mirror list. Unfortunately I have another issue. I have really slow internet around 100 Mb/s. After a while of downloading the updates it fails on timeout. Is there anything I can doo with it?
This is konsole output of last update attempt:
This will reset a few configuration files like pacman.conf 🛑Are you sure? (y/n)
y
--2023-02-25 13:35:46--  https://pkgbuild.com/~morganamilo/pacman-static/x86_64/bin/pacman-static
Loaded CA certificate '/etc/ssl/certs/ca-certificates.crt'
Resolving pkgbuild.com (pkgbuild.com)... 78.46.178.133, 2a01:4f8:c2c:51e2::1
Connecting to pkgbuild.com (pkgbuild.com)|78.46.178.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 4606712 (4,4M) [application/octet-stream]
Saving to: ‘/tmp/tmp.xpUeMnYY31’
/tmp/tmp.xpUeMnYY31         100%[=========================================>]   4,39M  3,20MB/s    in 1,4s
2023-02-25 13:35:48 (3,20 MB/s) - ‘/tmp/tmp.xpUeMnYY31’ saved [4606712/4606712]
.--.                  Pacman v6.0.1 - libalpm v13.0.1
/ _.-' .-.  .-.  .-.   Copyright (C) 2006-2021 Pacman Development Team
\  '-. '-'  '-'  '-'   Copyright (C) 2002-2006 Judd Vinet
This program may be freely redistributed under
the terms of the GNU General Public License.
--2023-02-25 13:35:48--  https://gitlab.com/garuda-linux/tools/garuda-tools/-/raw/master/data/pacman-default.conf
Resolving gitlab.com (gitlab.com)... 172.65.251.78, 2606:4700:90:0:f22e:fbec:5bed:a9b9
Connecting to gitlab.com (gitlab.com)|172.65.251.78|:443... connected.
Length: 2515 (2,5K) [text/plain]
Saving to: ‘/etc/pacman.conf’
/etc/pacman.conf            100%[=========================================>]   2,46K  --.-KB/s    in 0s
2023-02-25 13:35:48 (37,0 MB/s) - ‘/etc/pacman.conf’ saved [2515/2515]
--2023-02-25 13:35:48--  https://archlinux.org/mirrorlist/all/
Resolving archlinux.org (archlinux.org)... 95.217.163.246, 2a01:4f9:c010:6b1f::1
Connecting to archlinux.org (archlinux.org)|95.217.163.246|:443... connected.
Length: 49410 (48K) [text/plain]
Saving to: ‘/etc/pacman.d/mirrorlist’
/etc/pacman.d/mirrorlist    100%[=========================================>]  48,25K  --.-KB/s    in 0,05s
2023-02-25 13:35:49 (904 KB/s) - ‘/etc/pacman.d/mirrorlist’ saved [49410/49410]
--2023-02-25 13:35:49--  https://aur.chaotic.cx/mirrorlist.txt
Resolving aur.chaotic.cx (aur.chaotic.cx)... 185.199.111.153, 185.199.109.153, 185.199.108.153, ...
Connecting to aur.chaotic.cx (aur.chaotic.cx)|185.199.111.153|:443... connected.
Length: 2822 (2,8K) [text/plain]
Saving to: ‘/etc/pacman.d/chaotic-mirrorlist’
/etc/pacman.d/chaotic-mirro 100%[=========================================>]   2,76K  --.-KB/s    in 0,001s
2023-02-25 13:35:49 (4,22 MB/s) - ‘/etc/pacman.d/chaotic-mirrorlist’ saved [2822/2822]
gpg: /etc/pacman.d/gnupg/trustdb.gpg: trustdb created
gpg: no ultimately trusted keys found
gpg: starting migration from earlier GnuPG versions
gpg: porting secret keys from '/etc/pacman.d/gnupg/secring.gpg' to gpg-agent
gpg: migration succeeded
==> Generating pacman master key. This may take some time.
gpg: Generating pacman keyring master key...
gpg: directory '/etc/pacman.d/gnupg/openpgp-revocs.d' created
gpg: revocation certificate stored as '/etc/pacman.d/gnupg/openpgp-revocs.d/7F09193C00CF52A28EC08E0F94415A6CFBA76C80.rev'
gpg: Done
==> Updating trust database...
gpg: marginals needed: 3  completes needed: 1  trust model: pgp
gpg: depth: 0  valid:   1  signed:   0  trust: 0-, 0q, 0n, 0m, 0f, 1u
==> Appending keys from archlinux.gpg...
==> Appending keys from chaotic.gpg...
==> Locally signing trusted keys in keyring...
-> Locally signed 11 keys.
==> Importing owner trust values...
gpg: setting ownertrust to 4
gpg: inserting ownertrust of 4
==> Disabling revoked keys in keyring...
-> Disabled 37 keys.
gpg: depth: 0  valid:   1  signed:  11  trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1  valid:  11  signed:  95  trust: 0-, 0q, 0n, 11m, 0f, 0u
gpg: depth: 2  valid:  72  signed:  27  trust: 72-, 0q, 0n, 0m, 0f, 0u
gpg: next trustdb check due at 2023-03-30
gpg: key A6234074498E9CEE: 4 duplicate signatures removed
gpg: key A6234074498E9CEE: 1 signature reordered
gpg: key A6234074498E9CEE: "Christian Hesse <[email protected]>" 8 signatures cleaned
gpg: key FBA220DFC880C036: "Nico Jensch (Chaotic-AUR) <[email protected]>" not changed
gpg: Total number processed: 2
gpg:              unchanged: 1
gpg:     signatures cleaned: 8
-> Locally signed 2 keys.
gpg: depth: 0  valid:   1  signed:  12  trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1  valid:  12  signed:  94  trust: 1-, 0q, 0n, 11m, 0f, 0u
gpg: depth: 2  valid:  71  signed:  27  trust: 71-, 0q, 0n, 0m, 0f, 0u
garuda is up to date
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur                             2.3 MiB  2.70 MiB/s 00:01 [------------------------------------] 100%
warning: archlinux-keyring-20230223-1 is up to date -- reinstalling
warning: chaotic-keyring-20220803-1 is up to date -- reinstalling
resolving dependencies...
Packages (2) archlinux-keyring-20230223-1  chaotic-keyring-20220803-1
Total Download Size:   1.16 MiB
Total Installed Size:  1.63 MiB
Net Upgrade Size:      0.00 MiB
:: Retrieving packages...
chaotic-keyring-20220803-1-any         26.9 KiB   154 KiB/s 00:00 [------------------------------------] 100%
archlinux-keyring-20230223-1-any     1156.5 KiB  2043 KiB/s 00:01 [------------------------------------] 100%
Total (2/2)                          1183.4 KiB  1915 KiB/s 00:01 [------------------------------------] 100%
(2/2) checking keys in keyring                                     [------------------------------------] 100%
(2/2) checking package integrity                                   [------------------------------------] 100%
(2/2) loading package files                                        [------------------------------------] 100%
(2/2) checking for file conflicts                                  [------------------------------------] 100%
(2/2) checking available disk space                                [------------------------------------] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due SKIP_AUTOSNAP environment variable being set.
(1/2) reinstalling archlinux-keyring                               [------------------------------------] 100%
(2/2) reinstalling chaotic-keyring                                 [------------------------------------] 100%
(1/2) Reloading system manager configuration...
(2/2) Arming ConditionNeedsUpdate...
core is up to date
extra is up to date
chaotic-aur is up to date
warning: garuda-update-4.0.4-1 is up to date -- reinstalling
Packages (1) garuda-update-4.0.4-1
Total Download Size:   0.01 MiB
Total Installed Size:  0.02 MiB
garuda-update-4.0.4-1-any               9.8 KiB  60.7 KiB/s 00:00 [------------------------------------] 100%
(1/1) checking keys in keyring                                     [------------------------------------] 100%
(1/1) checking package integrity                                   [------------------------------------] 100%
(1/1) loading package files                                        [------------------------------------] 100%
(1/1) checking for file conflicts                                  [------------------------------------] 100%
(1/1) checking available disk space                                [------------------------------------] 100%
(1/1) reinstalling garuda-update                                   [------------------------------------] 100%
(1/1) Arming ConditionNeedsUpdate...
core is up to date
extra is up to date
--> Refreshing mirrorlists using reflector, please be patient..đŸ”
[2023-02-25 13:36:31] WARNING: failed to rate http(s) download (https://mirror.ufscar.br/archlinux/community/os/x86_64/community.db): Download timed out after 5 second(s).
garuda downloading...
core downloading...
extra downloading...
community downloading...
multilib downloading...
chaotic-aur downloading...
warning: libcpufeatures-git: local (0.7.0+.r269.d20220308.8a494eb-1) is newer than chaotic-aur (0.7.0+57.r326.d20230223.a6bf4f9-1)
warning: lxc-git: local (4.0.0.r2198.g30ebf0964-1) is newer than chaotic-aur (lxc.5.0.0.140-1)
:: Replace python-jupyter_client with community/python-jupyter-client? [Y/n] y
:: Replace python-jupyter_core with community/python-jupyter-core? [Y/n] y
:: Replace python-jupyter_packaging with community/python-jupyter-packaging? [Y/n] y
warning: ignoring package pipewire-common-git-0.3.66.r28.gda21cfa9-1
warning: dependency cycle detected:
warning: harfbuzz will be installed before its freetype2 dependency
warning: python-ipykernel will be installed before its python-jupyter-client dependency
warning: python-jupyterlab_server will be installed before its jupyter-server dependency
warning: jupyterlab will be installed before its jupyter-server dependency
warning: lib32-harfbuzz will be installed before its lib32-freetype2 dependency
Packages (571) acl-2.3.1-3  alembic-1.8.4-2  ananicy-rules-1.r113.0e07bf8-1  android-emulator-32.1.11-1
antimicrox-3.3.3-1  aom-3.6.0-1  appstream-0.16.1-1  appstream-qt-0.16.1-1
archlinux-appstream-data-pamac-1:20230220-1  ark-22.12.2-1  attica-5.103.0-1  audit-3.0.9-2
autorandr-1.13.3-1  b43-fwcutter-019-4  baloo-5.103.0-1  baloo-widgets-22.12.2-1
bash-5.1.016-3  beautyline-1:20230213-1  binance-1.43.2-1  bind-9.18.11-1  binutils-2.40-4
blas-3.11.0-2  blender-17:3.4.1-14  bluedevil-1:5.27.1-1  bluez-qt-5.103.0-1
boost-libs-1.81.0-3  breeze-5.27.1-1  breeze-icons-5.103.0-1  brotli-1.0.9-10
btrfs-assistant-1.8-1  btrfs-progs-6.1.3-1  c-ares-1.19.0-1  ca-certificates-mozilla-3.88.1-1
cairo-1.17.8-2  cblas-3.11.0-2  chromium-110.0.5481.177-1  clang-15.0.7-1
compiler-rt-15.0.7-1  cppcheck-2.10-1  cryptsetup-2.6.1-1  curl-7.88.1-3  dav1d-1.1.0-1
dbus-1.14.6-1  device-mapper-2.03.19-1  diffutils-3.9-1  discord-0.0.25-1  dnsmasq-2.89-1
dolphin-22.12.2-1  dosfstools-4.2-3  dotnet-host-7.0.2.sdk102-2  dotnet-runtime-7.0.2.sdk102-2
dotnet-sdk-7.0.2.sdk102-2  dotnet-targeting-pack-7.0.2.sdk102-2  e2fsprogs-1.47.0-1
editorconfig-core-c-0.12.6-1  egl-wayland-2:1.1.11-3  embree-3.13.5-2  exiv2-0.27.6-1
faudio-23.02-1  ffmpegthumbs-22.12.2-1  file-5.44-3  filelight-22.12.2-1
filesystem-2023.01.31-1  findutils-4.9.0-2  flex-2.6.4-4  fontconfig-2:2.14.2-1
frameworkintegration-5.103.0-1  freetype2-2.13.0-1  fscrypt-0.3.4-1  fuse-common-3.13.1-1
fuse3-3.13.1-1  fzf-0.37.0-1  garuda-assistant-2.7.5-1  garuda-setup-assistant-3.1.9-1
gcc-12.2.1-2  gcc-fortran-12.2.1-2  gcc-libs-12.2.1-2  gconf-3.2.6+11+g07808097-10.2
geoclue-2.7.0-1  geoip-database-20230120-1  gifski-1.10.0-1  git-2.39.2-1  glib2-2.74.5-1
glibc-2.37-2  gnustep-base-1.29.0-1  gnutls-3.8.0-1  google-chrome-110.0.5481.177-1
gpgme-1.18.0-2  graphite-1:1.3.14-3  grep-3.8-3  grub-2:2.06.r456.g65bc45963-1
gst-libav-1.22.0-3  gst-plugin-pipewire-1:0.3.66-2  gst-plugins-bad-1.22.0-3
gst-plugins-bad-libs-1.22.0-3  gst-plugins-base-1.22.0-3  gst-plugins-base-libs-1.22.0-3
gst-plugins-good-1.22.0-3  gst-plugins-ugly-1.22.0-3  gstreamer-1.22.0-3
gstreamer-vaapi-1.22.0-3  guile-3.0.9-1  gzip-1.12-2  harfbuzz-7.0.1-1  harfbuzz-icu-7.0.1-1
hblock-3.4.1-1  highway-1.0.3-1  hwdata-0.367-1  hwinfo-22.2-2  hwloc-2.9.0-1
iana-etc-20230105-1  imagemagick-7.1.0.62-1  imath-3.1.6-2  imlib2-1.10.0-3  iproute2-6.2.0-2
iptables-nft-1:1.8.9-1  ipython-8.10.0-1  jack2-1.9.22-1  java-runtime-common-3-5
jre-openjdk-19.0.2.u7-2  jre-openjdk-headless-19.0.2.u7-2  jre11-openjdk-11.0.18.u10-2
jre11-openjdk-headless-11.0.18.u10-2  jre17-openjdk-17.0.6.u10-2
jre17-openjdk-headless-17.0.6.u10-2  jre8-openjdk-8.362.u09-1
jre8-openjdk-headless-8.362.u09-1  jupyter-nbclassic-0.5.2-1  jupyter-nbconvert-7.2.9-1
jupyter-server-2.3.0-1  jupyterlab-3.6.1-1  kactivities-5.103.0-1  kactivities-stats-5.103.0-1
kactivitymanagerd-5.27.1-1  kamera-22.12.2-1  karchive-5.103.0-1  kate-22.12.2-1
kauth-5.103.0-1  kbookmarks-5.103.0-1  kcmutils-5.103.0-1  kcodecs-5.103.0-1
kcompletion-5.103.0-1  kconfig-5.103.0-1  kconfigwidgets-5.103.0-1  kcontacts-1:5.103.0-1
kcoreaddons-5.103.0-1  kcrash-5.103.0-1  kdbusaddons-5.103.0-1  kde-cli-tools-5.27.1-1
kdeclarative-5.103.0-1  kdeconnect-22.12.2-1  kdecoration-5.27.1-1  kded-5.103.0-1
kdegraphics-mobipocket-22.12.2-1  kdegraphics-thumbnailers-22.12.2-1
kdelibs4support-5.103.0-1  kdesu-5.103.0-1  kdialog-22.12.2-1  kdnssd-5.103.0-1
kemoticons-5.103.0-1  kfilemetadata-5.103.0-1  kglobalaccel-5.103.0-1  kguiaddons-5.103.0-1
kholidays-1:5.103.0-1  ki18n-5.103.0-1  kiconthemes-5.103.0-1  kidletime-5.103.0-1
kimageformats-5.103.0-1  kio-5.103.0-1  kio-extras-22.12.2-1  kirigami2-5.103.0-1
kitemmodels-5.103.0-1  kitemviews-5.103.0-1  kjobwidgets-5.103.0-1  kmenuedit-5.27.1-1
knewstuff-5.103.0-1  knotifications-5.103.0-1  knotifyconfig-5.103.0-1  kodi-20.0-6
kompare-22.12.2-1  konsole-22.12.2-1  kpackage-5.103.0-1  kparts-5.103.0-1  kpeople-5.103.0-1
kpipewire-5.27.1-1  kpty-5.103.0-1  kquickcharts-5.103.0-1  krunner-5.103.0-1
kscreen-5.27.1.1-1  kscreenlocker-5.27.1-1  kservice-5.103.0-1  ksystemstats-5.27.1-1
ktexteditor-5.103.0-1  ktextwidgets-5.103.0-1  kunitconversion-5.103.0-1  kwallet-5.103.0-1
kwayland-5.103.0-1  kwidgetsaddons-5.103.0-1  kwin-5.27.1-1  kwindowsystem-5.103.0-1
kxmlgui-5.103.0-1  lapack-3.11.0-2  layer-shell-qt-5.27.1-1  ldb-2:2.6.1-2  less-1:608-2
lib32-acl-2.3.1-2  lib32-cairo-1.17.8-2  lib32-curl-7.88.1-4  lib32-dbus-1.14.6-1
lib32-e2fsprogs-1.47.0-1  lib32-fontconfig-2:2.14.2-1  lib32-freetype2-2.13.0-1
lib32-gcc-libs-12.2.1-2  lib32-glib2-2.74.5-1  lib32-glibc-2.37-2  lib32-gnutls-3.8.0-1
lib32-gst-plugins-base-libs-1.22.0-1  lib32-gstreamer-1.22.0-1  lib32-harfbuzz-7.0.1-1
lib32-libcap-2.67-1  lib32-libcurl-compat-7.88.1-4  lib32-libcurl-gnutls-7.88.1-4
lib32-libdrm-2.4.115-1  lib32-libjpeg-turbo-2.1.5-4  lib32-libldap-2.6.4-1
lib32-libnm-1.42.2-1  lib32-libpipewire-1:0.3.66-2  lib32-libtiff-4.5.0-2
lib32-libx11-1.8.4-1  lib32-llvm-libs-15.0.7-1  lib32-mesa-22.3.6-1  lib32-mpg123-1.31.2-1
lib32-nss-3.88.1-1  lib32-nvidia-utils-525.89.02-1  lib32-openal-1.23.0-1
lib32-opencl-nvidia-525.89.02-1  lib32-pango-1:1.50.13-1  lib32-pcre2-10.42-1
lib32-pipewire-1:0.3.66-2  lib32-sdl2-2.26.3-1  lib32-sdl2_image-2.6.3-1
lib32-sdl2_mixer-2.6.3-1  lib32-systemd-253-1  lib32-vkd3d-1.5-1
lib32-vulkan-icd-loader-1.3.240-1  lib32-zstd-1.5.4-1  libadwaita-1:1.2.2-1  libcamera-0.0.4-1
libcanberra-1:0.30+r2+gc0620e4-3  libcap-2.67-1  libcups-1:2.4.2-5  libcurl-compat-7.88.1-3
libcurl-gnutls-7.88.1-3  libde265-1.0.11-1  libdrm-2.4.115-1  libelf-0.188-3
libgit2-1:1.5.1-2  libgphoto2-2.5.30-2  libhandy-1.8.1-1  libheif-1.15.1-1  libibus-1.5.28-1
libimagequant-4.1.0-1  libimobiledevice-1.3.0-6  libinput-1.22.1-1  libinput-gestures-2.74-1
libjpeg-turbo-2.1.5-2  libjxl-0.8.1-1  libkdcraw-22.12.2-1  libkexiv2-22.12.2-1
libkomparediff2-22.12.2-1  libkscreen-5.27.1-1  libksysguard-5.27.1-1  libldap-2.6.4-1
libmfx-23.1.0-1  libnghttp2-1.52.0-1  libnl-3.7.0-3  libnm-1.42.2-1  libnotify-0.8.2-1
libopenmpt-0.6.8-1  libpipewire-1:0.3.66-2  libplist-2.2.0-6  libretro-beetle-psx-2650-1
libretro-beetle-psx-hw-2650-1  libretro-flycast-5464-1  libretro-gambatte-984-1
libretro-genesis-plus-gx-1977-1  libretro-mgba-8797-1  libretro-mupen64plus-next-1:454-1
libretro-picodrive-2272-1  libretro-play-7605-1  libretro-ppsspp-35599-1
libretro-shaders-slang-1175-1  libretro-stella2014-git-298.8ab051e-1  libsasl-2.1.28-4
libsrtp-1:2.5.0-1  libsysprof-capture-3.46.0-4  libtiff-4.5.0-2  libtool-2.4.7+4+g1ec8fa28-2
liburcu-0.14.0-1  libvirt-1:9.0.0-1  libvirt-python-1:9.0.0-1  libwacom-2.6.0-1
libwbclient-4.17.5-1  libwpe-1.14.1-1  libx11-1.8.4-1  libxfce4ui-4.18.2-1  libxmlb-0.3.11-1
libxnvctrl-525.89.02-1  libxpm-3.5.15-1  libyaml-0.2.5-2  linux-6.1.12.arch1-1
linux-api-headers-6.1.9-1  linux-firmware-20230210.bf4115c-1
linux-firmware-whence-20230210.bf4115c-1  linux-zen-headers-6.1.12.zen1-1  llvm-15.0.7-1
llvm-libs-15.0.7-1  lmdb-0.9.30-2  lsof-4.98.0-1  luajit-2.1.0.beta3.r471.g505e2c03-1
lvm2-2.03.19-1  lzo-2.10-5  m4-1.4.19-2  man-pages-6.03-1  mariadb-10.11.2-1
mariadb-clients-10.11.2-1  mariadb-libs-10.11.2-1  memtest86+-6.10-1  mesa-22.3.6-1
milou-5.27.1-1  minecraft-technic-launcher-4.769-1  modemmanager-qt-5.103.0-1  mpfr-4.2.0-3
mpg123-1.31.2-2  ndctl-75-1  neon-0.32.5-1  net-tools-2.10-2
netstandard-targeting-pack-7.0.2.sdk102-2  networkmanager-1.42.2-1
networkmanager-qt-5.103.0-1  nodejs-19.7.0-1  noto-fonts-20230201-1  nss-3.88.1-1
nvidia-settings-525.89.02-1  nvidia-utils-525.89.02-2  openal-1.23.0-1  opencolorio-2.2.1-3
openimageio-2.4.6.1-4  openpmix-4.2.3-1  openshadinglanguage-1.12.9.0-1  openssh-9.2p1-1
openssl-3.0.8-1  openssl-1.1-1.1.1.t-1  openvdb-10.0.1-2  openvpn-2.6.0-1
oxygen-sounds-5.27.1-1  p7zip-1:17.05-1  pahole-1:1.24+r29+g02d67c5-1  pango-1:1.50.13-1
patch-2.7.6-9  pcre2-10.42-2  perl-clone-0.46-1  perl-html-parser-3.81-1
perl-http-daemon-6.15-1  php-8.2.3-1  pipewire-1:0.3.66-2  pipewire-media-session-1:0.4.2-1
plasma-desktop-5.27.1-2  plasma-framework-5.103.0-1  plasma-integration-5.27.1-1
plasma-nm-5.27.1-1  plasma-thunderbolt-5.27.1-1  plasma-workspace-5.27.1-1
plasma5-applets-window-buttons-0.11.1-2  plymouth-git-22.02.122.r163.g7302b49d-1
pocketsphinx-5.0.0-1  polkit-kde-agent-5.27.1-1  poppler-23.02.0-1  poppler-data-0.4.12-1
poppler-glib-23.02.0-1  poppler-qt5-23.02.0-1  postgresql-libs-15.2-1  powerdevil-5.27.1-2
prison-5.103.0-1  proton-ge-custom-bin-1:GE_Proton7_45-1  pybind11-2.10.3-2
python-beautifulsoup4-4.11.2-1  python-black-23.1.0-2  python-bleach-6.0.0-1
python-cairo-1.23.0-3  python-cryptography-39.0.1-1  python-debugpy-1.6.6-1
python-evdev-1.6.1-1  python-gpgme-1.18.0-2  python-ipykernel-6.21.2-1
python-json-logger-2.0.5-1  python-jupyter-client-8.0.3-1  python-jupyter-core-5.2.0-2
python-jupyter-packaging-0.12.3-1  python-jupyter-server-terminals-0.4.4-1
python-jupyter_client-7.4.9-1 [removal]  python-jupyter_core-5.1.3-1 [removal]
python-jupyter_packaging-0.12.3-1 [removal]  python-jupyterlab_server-2.19.0-1
python-markdown-it-py-2.1.0-1  python-markupsafe-2.1.2-1  python-mdurl-0.1.2-2
python-mistune-2.0.5-1  python-mypy_extensions-1.0.0-1  python-numpy-1.24.2-1
python-packaging-23.0-1  python-pathspec-0.11.0-1  python-pip-23.0.1-1
python-platformdirs-3.0.0-1  python-pygments-2.14.0-2  python-pyqt5-5.15.9-1
python-pyqt5-sip-12.11.1-1  python-requests-2.28.2-1  python-rich-13.3.1-1
python-soupsieve-2.4-1  python-traitlets-5.9.0-1  python-typing_extensions-4.5.0-1
python-uc-micro-py-1.0.1-3  python-websocket-client-1.5.1-1  qemu-audio-alsa-7.2.0-3
qemu-audio-dbus-7.2.0-3  qemu-audio-jack-7.2.0-3  qemu-audio-oss-7.2.0-3
qemu-audio-pa-7.2.0-3  qemu-audio-sdl-7.2.0-3  qemu-audio-spice-7.2.0-3
qemu-block-curl-7.2.0-3  qemu-block-dmg-7.2.0-3  qemu-block-nfs-7.2.0-3
qemu-block-ssh-7.2.0-3  qemu-chardev-spice-7.2.0-3  qemu-common-7.2.0-3  qemu-desktop-7.2.0-3
qemu-emulators-full-7.2.0-3  qemu-hw-display-qxl-7.2.0-3  qemu-hw-display-virtio-gpu-7.2.0-3
qemu-hw-display-virtio-gpu-gl-7.2.0-3  qemu-hw-display-virtio-gpu-pci-7.2.0-3
qemu-hw-display-virtio-gpu-pci-gl-7.2.0-3  qemu-hw-display-virtio-vga-7.2.0-3
qemu-hw-display-virtio-vga-gl-7.2.0-3  qemu-hw-s390x-virtio-gpu-ccw-7.2.0-3
qemu-hw-usb-host-7.2.0-3  qemu-hw-usb-redirect-7.2.0-3  qemu-hw-usb-smartcard-7.2.0-3
qemu-img-7.2.0-3  qemu-pr-helper-7.2.0-3  qemu-system-aarch64-7.2.0-3
qemu-system-alpha-7.2.0-3  qemu-system-alpha-firmware-7.2.0-3  qemu-system-arm-7.2.0-3
qemu-system-arm-firmware-7.2.0-3  qemu-system-avr-7.2.0-3  qemu-system-cris-7.2.0-3
qemu-system-hppa-7.2.0-3  qemu-system-hppa-firmware-7.2.0-3  qemu-system-loongarch64-7.2.0-3
qemu-system-m68k-7.2.0-3  qemu-system-microblaze-7.2.0-3
qemu-system-microblaze-firmware-7.2.0-3  qemu-system-mips-7.2.0-3  qemu-system-nios2-7.2.0-3
qemu-system-or1k-7.2.0-3  qemu-system-ppc-7.2.0-3  qemu-system-ppc-firmware-7.2.0-3
qemu-system-riscv-7.2.0-3  qemu-system-riscv-firmware-7.2.0-3  qemu-system-rx-7.2.0-3
qemu-system-s390x-7.2.0-3  qemu-system-s390x-firmware-7.2.0-3  qemu-system-sh4-7.2.0-3
qemu-system-sparc-7.2.0-3  qemu-system-sparc-firmware-7.2.0-3  qemu-system-tricore-7.2.0-3
qemu-system-x86-7.2.0-3  qemu-system-x86-firmware-7.2.0-3  qemu-system-xtensa-7.2.0-3
qemu-tools-7.2.0-3  qemu-ui-curses-7.2.0-3  qemu-ui-dbus-7.2.0-3  qemu-ui-egl-headless-7.2.0-3
qemu-ui-gtk-7.2.0-3  qemu-ui-opengl-7.2.0-3  qemu-ui-sdl-7.2.0-3  qemu-ui-spice-app-7.2.0-3
qemu-ui-spice-core-7.2.0-3  qemu-user-7.2.0-3  qemu-vhost-user-gpu-7.2.0-3
qemu-virtiofsd-7.2.0-3  qqc2-desktop-style-5.103.0-1  qt5-base-5.15.8+kde+r181-1
qt5-imageformats-5.15.8+kde+r9-1  qt5-multimedia-5.15.8+kde+r2-1  qt5-tools-5.15.8+kde+r1-3
qt5-wayland-5.15.8+kde+r58-1  re2-1:20230201-1  readline-8.2.001-2  reiserfsprogs-3.6.27-4
retroarch-autoconfig-udev-git-r2121.91af80b-1  rider-1:2022.3.2-1  ruby-json-2.6.3-1
rust-1:1.67.1-1  sane-1.2.1-3  sdl2-2.26.3-1  sdl2_image-2.6.3-1  sdl2_mixer-2.6.3-1
sdl2_ttf-2.20.2-1  sed-4.9-2  shadow-4.13-2  shared-mime-info-2.2+13+ga2ffb28-1
smbclient-4.17.5-1  sndio-1.9.0-1  solid-5.103.0-1  sonnet-5.103.0-1
source-highlight-3.1.9-10  spdlog-1.11.0-2  spice-gtk-0.42-1  sqlite-3.41.0-1  stunnel-5.68-1
sudo-1.9.13-1  supertuxkart-1.4-5  syndication-5.103.0-1  syntax-highlighting-5.103.0-1
systemd-253-1  systemd-libs-253-1  systemd-sysvcompat-253-1  systemsettings-5.27.1-1
talloc-2.4.0-2  tdb-1.4.8-1  telegram-desktop-4.6.3-1  terminus-font-4.49.1-5
tevent-1:0.14.1-1  texinfo-7.0.2-2  thin-provisioning-tools-1.0.2-1  threadweaver-5.103.0-1
tor-0.4.7.13-2  tracker3-3.4.2-2  ttf-firacode-nerd-2.3.3-2  ttf-iosevka-nerd-2.3.3-2
tzdata-2022g-2  unarchiver-1.10.7-8  unrar-1:6.2.6-1  upower-1.90.0-3  usbmuxd-1.1.1-2
vte-common-0.70.3-1  vte3-0.70.3-1  vulkan-headers-1:1.3.240-1  vulkan-icd-loader-1.3.240-1
vulkan-tools-1.3.240-1  webkit2gtk-2.38.5-1  webkit2gtk-4.1-2.38.5-1  which-2.21-6
wildmidi-0.4.5-1  wine-staging-8.1-1  xbitmaps-1.1.3-1  xdg-desktop-portal-kde-5.27.1-1
xfce4-panel-4.18.2-1  xfsprogs-6.1.1-2  xkeyboard-config-2.38-1  xorg-server-21.1.7-1
xorg-server-common-21.1.7-1  xterm-379-1  zenity-3.44.0-2  zsh-5.9-3  zstd-1.5.4-1
zvbi-0.2.41-1
Total Download Size:    5220.45 MiB
Total Installed Size:  17307.25 MiB
Net Upgrade Size:        308.64 MiB
nvidia-utils-525.89.02-2-x86_64       260.3 MiB   933 KiB/s 04:46 [------------------------------------] 100%
android-emulator-32.1.11-1-x86_64     247.6 MiB   648 KiB/s 06:31 [------------------------------------] 100%
proton-ge-custom-bin-1:GE_Proton...   354.8 MiB   658 KiB/s 09:12 [------------------------------------] 100%
linux-6.1.12.arch1-1-x86_64           164.0 MiB   907 KiB/s 03:05 [------------------------------------] 100%
linux-firmware-20230210.bf4115c-...   137.1 MiB   962 KiB/s 02:26 [------------------------------------] 100%
binance-1.43.2-1-x86_64.pkg.tar.zst failed to download
supertuxkart-1.4-5-x86_64             618.9 MiB   869 KiB/s 12:09 [------------------------------------] 100%
rider-1:2022.3.2-1-x86_64            1021.8 MiB  1212 KiB/s 14:24 [------------------------------------] 100%
Total (  8/568)                         5.1 GiB  6.04 MiB/s 14:24 [------------------------------------] 100%
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from geo-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from cdn-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from cdn-cn-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from br-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from br-2-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from bg-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from ca-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from fr-1-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from fr-2-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from de-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from de-2-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from de-3-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from de-4-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from in-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from in-2-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from in-3-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from kr-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from es-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from es-2-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from ae-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from ae-2-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from us-fl-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from us-mi-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from us-ny-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from us-tx-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from us-ut-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'binance-1.43.2-1-x86_64.pkg.tar.zst' from us-va-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
warning: failed to retrieve some files
error: failed to commit transaction (unexpected error)
I have run garuda-update again and again and now I am finally where I was before I broke the mirror list. Anoune could help me how to solve this error?
pocketsphinx: /usr/share/man/man1/sphinx_lm_convert.1.gz exists in filesystem (owned by sphinxbase)
The whole output of garuda-update is here: https://pastebin.com/raw/pYiYNjFN
Try this
It fixed the issue where I was unable to update the system. Then I tryed to reboot and from this point I am unable to boot up. Is there anything I can do to save my system? I tryed to load fallback initrams from advanced options in grub but every option ends up in the similar black screen as this:
I think that issue could be caused by the fact that I haven't updated the grub after garuda-update. Could it be caused by that? Is there any way to fix that?
I tryed logging to the text console but it isn't possible from the screen that you can see on the photo I provided. The system won't boot at all. It isn't just graphical interface unable to load. I am not sure if you are able to see the photo in my previous comment so I will rewrite it here:
Loading Linux linux-zen ...
error: file `/@/boot/vmlinuz-linux-zen` not found.
Loading initial ramdisk ...
error: you need to load kernel first.
Pres any key to continue...
This is presented to me every time that I try to boot up the linux.
I can not get to any system terminal. Now when I am thinking about it I may get to the grub konsole but I am not familiar with it and don't know if I can do anything from it.
Now I will try to flash garuda on live usb and check /mnt and /boot partitions of the system.
Use the live USB to chroot into your installed system and reinstall the kernel and headers.
pacman -S linux-zen linux-zen-headers
sudo is not necessary inside chroot.
So I managed to install the suggested packages. This is the konsole output:
╭─[email protected] in ~ as 🧙 took 131ms
╰─λ sudo garuda-chroot /mnt/broken/@
sh-5.1# pacman -S linux-zen linux-zen-headers
warning: linux-zen-headers-6.1.12.zen1-1 is up to date -- reinstalling
Packages (2) linux-zen-6.1.12.zen1-1  linux-zen-headers-6.1.12.zen1-1
Total Download Size:   196.53 MiB
Total Installed Size:  318.79 MiB
Net Upgrade Size:      169.42 MiB
linux-zen-headers-6.1.12.zen1-1-x86_64                                                 27.4 MiB  1557 KiB/s 00:18 [--------------------------------------------------------------------] 100%
linux-zen-6.1.12.zen1-1-x86_64                                                         67.0 MiB  3.87 MiB/s 0 linux-zen-6.1.12.zen1-1-x86_64         69.8 MiB  3.64 MiB/s 00:27 [------------linux-zen-6.1.12.zen1-1-x86_64                                                        169.1 MiB  3.03 MiB/s 00:56 [--------------------------------------------------------------------] 100%
Total (2/2)        196.5 MiB  3.52 MiB/s 00:56 [--------------------------------------------------------------------] 100%
(2/2) checking keys in keyring        [--------------------------------------------------------------------] 100%
(2/2) checking package integrity        [--------------------------------------------------------------------] 100%
(2/2) loading package files        [--------------------------------------------------------------------] 100%
(2/2) checking for file conflicts        [--------------------------------------------------------------------] 100%
(2/2) checking available disk space        [--------------------------------------------------------------------] 100%
Using system disk as snapshot device for creating snapshots in BTRFS mode
** (process:56): CRITICAL **: 16:46:05.112: tee_jee_file_system_path_combine: assertion 'path1 != NULL' failed
** (process:56): CRITICAL **: 16:46:05.112: tee_jee_file_system_dir_exists: assertion 'dir_path != NULL' failed
** (process:56): CRITICAL **: 16:46:05.113: tee_jee_file_system_path_combine: assertion 'path1 != NULL' failed
** (process:56): CRITICAL **: 16:46:05.113: tee_jee_file_system_dir_exists: assertion 'dir_path != NULL' failed
E: Selected snapshot device is not a system disk
E: Select BTRFS system disk with root subvolume (@)
** (process:96): CRITICAL **: 16:46:05.173: gee_abstract_collection_get_size: assertion 'self != NULL' failed
(1/2) installing linux-zen        [--------------------------------------------------------------------] 100%
Optional dependencies for linux-zen
wireless-regdb: to set the correct wireless channels of your country [installed]
linux-firmware: firmware images needed for some devices [installed]
(2/2) reinstalling linux-zen-headers        [--------------------------------------------------------------------] 100%
(1/3) Arming ConditionNeedsUpdate...
(2/3) Updating module dependencies...
(3/3) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'default'
-> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen.img
==> Starting build: 6.1.12-zen1-1-zen
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [autodetect]
-> Running build hook: [modconf]
-> Running build hook: [block]
==> WARNING: Possibly missing firmware for module: xhci_pci
-> Running build hook: [keyboard]
-> Running build hook: [keymap]
-> Running build hook: [consolefont]
-> Running build hook: [plymouth]
-> Running build hook: [filesystems]
==> ERROR: module not found: `nvidia'
==> ERROR: module not found: `nvidia_modeset'
==> ERROR: module not found: `nvidia_uvm'
==> ERROR: module not found: `nvidia_drm'
==> Generating module dependencies
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-zen.img
==> WARNING: errors were encountered during the build. The image may not be complete.
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'fallback'
-> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: aic94xx
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: qla2xxx
==> WARNING: Possibly missing firmware for module: wd719x
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-zen-fallback.img
I am a little bit concerned about the nvidia errors :confused:
I also run a update-grub command and this is the output:
Found theme: /usr/share/grub/themes/garuda-dr460nized/theme.txt
Found initrd image: /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot:  initramfs-linux-zen-fallback.img
Found initrd image: /boot/initramfs-linux.img
Found fallback initrd image(s) in /boot:  initramfs-linux-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sdc1.  Check your device.map.
Found Garuda Linux on /dev/nvme0n1p1
Found Debian GNU/Linux 11 (bullseye) on /dev/nvme0n1p1
Found Arch Linux on /dev/nvme0n1p1
Found Windows 10 on /dev/sda1
Found Windows 10 on /dev/sdb1
Adding boot menu entry for UEFI Firmware Settings ...
Detecting snapshots ...
Found snapshot: 2023-02-25 14:50:04 | timeshift-btrfs/snapshots/2023-02-25_14-50-04/@ | ondemand       | {timeshift-autosnap} {created before upgrade} |
Found snapshot: 2023-02-25 12:23:35 | timeshift-btrfs/snapshots/2023-02-25_12-23-35/@ | ondemand       | {timeshift-autosnap} {created before upgrade} |
Found snapshot: 2023-02-24 15:00:01 | timeshift-btrfs/snapshots/2023-02-24_15-00-01/@ | daily          | N/A                                           |
Found snapshot: 2023-02-22 00:00:01 | timeshift-btrfs/snapshots/2023-02-22_00-00-01/@ | weekly         | N/A                                           |
Found snapshot: 2023-01-31 20:01:08 | timeshift-btrfs/snapshots/2023-01-31_20-01-08/@ | ondemand       | {timeshift-autosnap} {created before upgrade} |
Found snapshot: 2023-01-27 07:00:01 | timeshift-btrfs/snapshots/2023-01-27_07-00-01/@ | monthly        | N/A                                           |
Found snapshot: 2023-01-15 22:39:04 | timeshift-btrfs/snapshots/2023-01-15_22-39-04/@ | ondemand daily | {timeshift-autosnap} {created before upgrade} |
Found snapshot: 2023-01-07 14:16:23 | timeshift-btrfs/snapshots/2023-01-07_14-16-23/@ | ondemand       | {timeshift-autosnap} {created before upgrade} |
Found 8 snapshot(s)
Unmount /tmp/grub-btrfs.sfHBfbRwpZ .. Success
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
Update after booting the linux:
Now it wont boot. But also it won’t show any error. It is stuck in the black screen showing this text:
  Booting ‘Garuda Linux’
Here it is stuck forewer.
Did you remove some nvidia dkms packages? Also you haven't provided your garuda-inxi yet.
Try to chroot into your installation and run sudo grub-install. If this also does not work, just restore a snapshot, that's the whole point of snapshots after all :wink:
Now I successfully reinstalled nvidia driver with sudo mhwd -i pci video-nvidia-dkms -f.
I am unable to run garuda-inxi from within chroot session. It is returning sh: garuda-inxi: command not found. Is there something I am missing?
How can I restore to snapshot from chroot session? When i run timeshift --check it will return me this:
** (process:30958): CRITICAL **: 17:36:13.497: tee_jee_file_system_path_combine: assertion 'path1 != NULL' failed
** (process:30958): CRITICAL **: 17:36:13.497: tee_jee_file_system_dir_exists: assertion 'dir_path != NULL' failed
Daily snapshots are enabled
Last daily snapshot not found
** (process:30958): CRITICAL **: 17:36:13.498: tee_jee_file_system_path_combine: assertion 'path1 != NULL' failed
** (process:30958): CRITICAL **: 17:36:13.498: tee_jee_file_system_dir_exists: assertion 'dir_path != NULL' failed
huh your system still uses timeshift? It was replaced by snapper a long time ago...
I'm a little confused about the garuda-inxi part. Could you please reinstall garuda-common-settings and rerun garuda-inxi?
So apparently it was caused by the nvidia drivers error. Forsing reinstall on them fixed the issue. Unfortunately I lost the garuda theme for KDE Plasma. And more native packages so I decided to restore previous version on snapshot using the timeshift. It went through smoothly and I have everything as it was before.
Thanks for the help everyone.
garuda-dr460nized
all the packages can be found this way but I strongly recommend you roll back your system now that you can at least access it again. You seem to have lost like 90% of the garuda-configuration.
TBF I would not doubt that even snapper got uninstalled. If this is the case, a reinstall is probably your only option.
