Hello.
Post your terminal/konsole in- and output as text (no pictures ) from:
inxi -Faz
System: Kernel: 5.15.5-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=748be52d-2eb6-4ca3-baf3-b9a71e42fd0d
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec0xxx v: N/A
serial: Chassis: type: 10 serial:
Mobo: HP model: 86D5 v: 96.45 serial: UEFI: AMI v: F.12 date: 12/21/2020
Battery: ID-1: BAT0 charge: 25.1 Wh (62.9%) condition: 39.9/39.9 Wh (100.0%) volts: 11.3 min: 11.6
model: Hewlett-Packard Primary type: Li-ion serial: N/A status: Discharging cycles: 359
CPU: Info: Quad Core model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64 type: MT MCP
arch: Zen family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108109 cache: L1: 384 KiB
L2: 2 MiB L3: 4 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 33538
Speed: 1301 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz): 1: 1594 2: 1567
3: 1221 4: 1187 5: 1219 6: 1210 7: 1330 8: 1146
Graphics: Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Hewlett-Packard
driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f91
Device-2: AMD Picasso vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 05:00.0
chip-ID: 1002:15d8 class-ID: 0300
Device-3: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo bus-ID: 3-1:2
chip-ID: 0408:5365 class-ID: 0e02
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: modesetting,nvidia
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
Audio: Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Hewlett-Packard
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x,snd_pci_acp5x bus-ID: 05:00.5
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.15.5-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard
driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: e000 bus-ID: 03:00.0 chip-ID: 10ec:c822
IF: wlo1 state: up mac:
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: d000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: eno1 state: down mac:
Bluetooth: Device-1: Realtek 802.11ac WLAN Adapter type: USB driver: btusb v: 0.8 bus-ID: 1-4:2
chip-ID: 0bda:b00c class-ID: e001 serial:
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address:
Drives: Local Storage: total: 1.14 TiB used: 13.13 GiB (1.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Gigabyte model: GP-GSM2NE3256GNTD size: 238.47 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial:
rev: EDFM20.0 temp: 28.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-60Z10T0 size: 931.51 GiB
serial: rev: 1A04 scheme: GPT
Partition: ID-1: / raw-size: 45 GiB size: 45 GiB (100.00%) used: 12.24 GiB (27.2%) fs: btrfs
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%) used: 576 KiB (0.1%) fs: vfat
ID-3: /home raw-size: 65.1 GiB size: 65.1 GiB (100.00%) used: 912.1 MiB (1.4%) fs: btrfs
ID-4: /var/log raw-size: 45 GiB size: 45 GiB (100.00%) used: 12.24 GiB (27.2%) fs: btrfs
ID-5: /var/tmp raw-size: 45 GiB size: 45 GiB (100.00%) used: 12.24 GiB (27.2%) fs: btrfs
ID-1: swap-1 type: zram size: 13.59 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 52.0 C mobo: N/A gpu: amdgpu temp: 52.0 C
Info: Processes: 336 Uptime: 41m wakeups: 1 Memory: 13.59 GiB used: 3.24 GiB (23.9%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1224 lib: 307
Shell: fish v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.09
The two-finger tap button is greyed out.
Screenshot
SGS
2 December 2021 15:01
#2
If you include terminal outputs in your post please use the proper output format in your post. Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look.
anant79:
Same happened to me and it just appeared eventually. Try updating and restarting.
So in Settings > Input Devices > Touchpad, the 'Scrolling: Two Fingers' option is grayed out?
Have you tried different kernels?
System: Kernel: 5.15.6-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=a89ed795-4da8-411d-b800-d40541be6f77
Mobo: HP model: 86D5 v: 96.45 serial: <superuser required> UEFI: AMI v: F.12 date: 12/21/2020
Battery: ID-1: BAT0 charge: 30.3 Wh (76.7%) condition: 39.5/39.5 Wh (100.0%) volts: 11.2 min: 11.6
model: Hewlett-Packard Primary type: Li-ion serial: N/A status: Discharging cycles: 355
L2: 2 MiB L3: 4 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 33534
Speed: 1802 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz): 1: 1830 2: 1823
3: 1364 4: 1286 5: 1333 6: 1329 7: 1270 8: 1350
Sound Server-1: ALSA v: k5.15.6-zen2-1-zen running: yes
Bluetooth: Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 1-4:2
chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
Drives: Local Storage: total: 1.14 TiB used: 13.39 GiB (1.1%)
rev: EDFM20.0 temp: 25.9 C scheme: GPT
serial: <filter> rev: 1A04 scheme: GPT
Partition: ID-1: / raw-size: 50 GiB size: 50 GiB (100.00%) used: 11.92 GiB (23.8%) fs: btrfs
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%) used: 51.2 MiB (10.0%) fs: vfat
ID-3: /home raw-size: 60 GiB size: 60 GiB (100.00%) used: 1.42 GiB (2.4%) fs: btrfs
ID-4: /var/log raw-size: 50 GiB size: 50 GiB (100.00%) used: 11.92 GiB (23.8%) fs: btrfs
ID-5: /var/tmp raw-size: 50 GiB size: 50 GiB (100.00%) used: 11.92 GiB (23.8%) fs: btrfs
Info: Processes: 327 Uptime: 14m wakeups: 1 Memory: 13.59 GiB used: 2.76 GiB (20.3%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1190 lib: 295
Hope this helps, also wanna add that the gestures are not working too. Apologies for the earlier mistake.
Gestures are not well supported in my experience on x11. I did set them up on my kde setup with touche/touchegg for switching virtual desktops though. You might want to check that out.
system
closed
30 December 2021 16:10
#8
