Kernel: 6.4.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=f2437583-6345-4124-a9ae-b9f3cf7b1471 rw rootflags=subvol=@
resume=UUID=9ab3115e-c62a-4e32-af95-9e00b376cc5e loglevel=3 ibt=off
Type: Desktop Mobo: Micro-Star model: A320M-A PRO (MS-7C51) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.80
date: 05/08/2023
Info: model: AMD Ryzen 5 5500 bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x50 (80) stepping: 0 microcode: 0xA50000D
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3242 high: 3933 min/max: 1400/4268 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2997 2: 3242
3: 2990 4: 3933 5: 3600 6: 2990 7: 2982 8: 3600 9: 2993 10: 2994 11: 2993
12: 3600 bogomips: 86235
Device-1: NVIDIA TU116 [GeForce GTX 1650 SUPER] vendor: eVga.com.
driver: nvidia v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 10:00.0 chip-ID: 10de:2187
Screen-1: 0 s-res: 1920x1080 s-dpi: 75 s-size: 650x366mm (25.59x14.41")
s-diag: 746mm (29.37")
Monitor-1: HDMI-0 res: 1920x1080 size: N/A modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.54.03 renderer: NVIDIA GeForce GTX 1650
SUPER/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: eVga.com.
bus-ID: 10:00.1 chip-ID: 10de:1aeb class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 30:00.1 chip-ID: 1002:1637
Device-3: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 30:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.4.2-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.73 status: active with: 1: pipewire-pulse
lanes: 1 port: e000 bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp37s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:2 chip-ID: 2357:0604
Local Storage: total: 1.29 TiB used: 816.67 GiB (61.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Biostar model: S100-120GB
tech: SSD serial: <filter> fw-rev: 5.0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37240G
tech: SSD serial: <filter> fw-rev: 0107 scheme: GPT
model: WD10EZEX-22MFCA0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Kingston model: DataTraveler 3.0
size: 57.8 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: PMAP scheme: MBR
ID-1: / raw-size: 206.21 GiB size: 206.21 GiB (100.00%)
used: 21.32 GiB (10.3%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 29.7 MiB (9.9%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 206.21 GiB size: 206.21 GiB (100.00%)
ID-4: /var/log raw-size: 206.21 GiB size: 206.21 GiB (100.00%)
ID-5: /var/tmp raw-size: 206.21 GiB size: 206.21 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.06 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.51 GiB used: 10.8 MiB (0.1%)
System Temperatures: cpu: 50.6 C mobo: N/A gpu: nvidia temp: 48 C
Processes: 309 Uptime: 3h 58m wakeups: 0 Memory: available: 15.51 GiB
used: 5.96 GiB (38.4%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: 1373 pm: pacman pkgs: 1339
libs: 346 tools: octopi,paru pm: flatpak pkgs: 34 Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27
System install date: 2023-07-08
Last full system update: 2023-07-08
Hello, this is my first post here, so sorry if I do something incorrectly such choosing the wrong template.
When I first tried to ssh using Konsole without modifying anything a pop-up appears asking me to type my password, although the text inside the box doesn't match, because the box was asking me to type my password but the text in Konsole ask me to type the typical "Yes/No", the first time I type my local password, then it fails, and I type "Yes" and it worked, but after that the same pop-up appear asking me to type my password, and I incorrectly type my local password instead of the remote server password and now every time I tried to ssh into same server the incorrect password write itself without giving me any time to do something, and obviously it fails.
According to something that I read, this happens because of a Plasma's dependency called ksshaskpass that is responsible to automatize the log-in into remove servers using ssh, I already tried removing the dependency and every time I tried to ssh I receive this message:
ssh_askpass: exec(/usr/bin/ksshaskpass): No such file or directory
I tried reinstalling the dependency but the only thing that change is if I delete .ssh/known_hosts file that the pop-up will appear again asking to write "Yes/No", but that's it, then it will write the incorrect password again
