You know the rules, and so do I.
Kernel: 6.1.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=4f3937b5-6c07-4580-8883-8cef1f42d4f5 rw rootflags=subvol=@
quiet
cryptdevice=UUID=3d769afd-2828-481c-8e36-8aba99397d5a:luks-3d769afd-2828-481c-8e36-8aba99397d5a
root=/dev/mapper/luks-3d769afd-2828-481c-8e36-8aba99397d5a quiet splash
resume=/dev/mapper/luks-a59fcb28-cd12-4a13-abcf-1ad9ee0585a5 loglevel=3
Desktop: KDE Plasma v: 5.27.0 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Framework product: Laptop v: AB
Mobo: Framework model: FRANBMCP0B v: AB serial: <superuser required>
UEFI: INSYDE v: 03.07 date: 12/14/2021
ID-1: BAT1 charge: 43.7 Wh (81.5%) condition: 53.6/55.0 Wh (97.4%)
volts: 17.3 min: 15.4 model: NVT Framewo type: Li-ion serial: <filter>
status: charging
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
microcode: 0xA6
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2800 min/max: 400/4700 scaling: driver: intel_pstate
governor: powersave cores: 1: 2800 2: 2800 3: 2800 4: 2800 5: 2800 6: 2800
7: 2800 8: 2800 bogomips: 44851
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0 chip-ID: 8086:9a49
Device-2: Realtek Laptop Camera type: USB driver: uvcvideo bus-ID: 3-7:3
chip-ID: 0bda:5634 class-ID: 0e02 serial: <filter>
Screen-1: 0 s-res: 2256x1504 s-dpi: 96 s-size: 596x397mm (23.46x15.63")
s-diag: 716mm (28.19")
Monitor-1: eDP-1 model: BOE Display 0x095f built: 2019 res: 2256x1504
hz: 60 dpi: 201 gamma: 1.2 size: 285x190mm (11.22x7.48") diag: 343mm (13.5")
ratio: 3:2 modes: 2256x1504
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct-render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio driver: snd_hda_intel
chip-ID: 8086:a0c8 class-ID: 0403
Sound API: ALSA v: k6.1.12-zen1-1-zen running: yes
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: aa:00.0 chip-ID: 8086:2725
IF: wlp170s0 state: up mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 2-1:4 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp0s13f0u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-005d4b3ec748 state: down mac: <filter>
IF-ID-3: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
IF-ID-4: virbr0 state: down mac: <filter>
IF-ID-5: virbr1 state: down mac: <filter>
IF-ID-6: virbr2 state: down mac: <filter>
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 3-10:5 chip-ID: 8087:0032 class-ID: e001
Local Storage: total: 931.51 GiB used: 123.97 GiB (13.3%)
lanes: 4 type: SSD serial: <filter> rev: 2B2QGXA7 temp: 43.9 C scheme: GPT
ID-1: / raw-size: 896.96 GiB size: 896.96 GiB (100.00%)
used: 123.97 GiB (13.8%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-3d769afd-2828-481c-8e36-8aba99397d5a
used: 752 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 896.96 GiB size: 896.96 GiB (100.00%)
ID-4: /var/log raw-size: 896.96 GiB size: 896.96 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.96 GiB size: 896.96 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.14 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.25 GiB used: 0 KiB (0.0%)
mapped: luks-a59fcb28-cd12-4a13-abcf-1ad9ee0585a5
System Temperatures: cpu: 49.0 C mobo: N/A
Processes: 327 Uptime: 6h 17m wakeups: 18947 Memory: 31.14 GiB
used: 10.46 GiB (33.6%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1808
libs: 393 tools: octopi,pamac,paru,yay Shell: fish v: 3.6.0
running-in: konsole inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2022-05-10
Last full system update: 2023-02-21
Stop SSH from using any popup when asking for password or knowhost
Since the latest upgrade with the removal of latte-dock and a full Garuda settings reset via. the Garuda assistant, my ssh in the Konsole is using ksshaskpass for password or known host questions.
How do I disable this?
(I got the solution already, this is a documentation topic)
some more tags for better search - please ignore:
ssh disable pop up
ssh use terminal for password input
ssh stop asking for password via popup
