Unable to connect Bluetooth devices "Connection Failed"
Hello yall,
i’ve recently got across an issue with my Bluetooth Devices, as they don’t connect anymore.
At first i thought the issue was an update that destroyed my settings or something similar, but after reverting to an earlier time using snapper i still had the same issue.
After that ive went into the deep dive reading and trying mulible previously created Topics off different users, unfortunately to no avail.
The Articles i’ve already tried:
https://www.reddit.com/r/archlinux/comments/165ehx8/cannot_connect_logitech_mx_masters_3s_using/
Any and all help would be greatly Appreciated!
(Below the result of “garuda-inxi”)
root=UUID=c805425f-bd18-4e5d-8361-f8caf538d353 rw rootflags=subvol=@
wm: kwin_x11 tools: avail: swayidle,swaylock vt: 2 dm: SDDM Distro: Garuda
Type: Laptop System: ASUSTeK product: ZenBook UX325SA_UM325SA v: 1.0
Mobo: ASUSTeK model: UX325SA v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: UX325SA.302
date: 11/09/2021
ID-1: BATT charge: 57.4 Wh (100.0%) condition: 57.4/67.1 Wh (85.5%)
volts: 15.9 min: 15.9 model: ASUSTeK UX325 type: Li-ion serial: <filter>
status: full cycles: 23
Info: model: AMD Ryzen 7 5800U with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA500011
Speed (MHz): avg: 1112 min/max: 400/4507 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1112 2: 1112 3: 1112
4: 1112 5: 1112 6: 1112 7: 1112 8: 1112 9: 1112 10: 1112 11: 1112 12: 1112
13: 1112 14: 1112 15: 1112 16: 1112 bogomips: 60686
Device-1: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5
lanes: 16 ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 04:00.0
chip-ID: 1002:1638 class-ID: 0300 temp: 45.0 C
Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 13d3:56eb
Monitor-1: eDP-1 mapped: eDP model: Samsung 0x4158 built: 2020 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 166 gamma: 1.2
size: 294x165mm (11.57x6.5") diag: 337mm (13.3") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.2-arch1.2
renoir ACO DRM 3.61 6.13.8-zen1-1-zen) device-ID: 1002:1638
memory: 500 MiB unified: no
API: Vulkan v: 1.4.309 layers: 9 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: N/A device-ID: 1002:1638
de: kscreen-console,kscreen-doctor wl: swaymsg,wayland-info
Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
vendor: ASUSTeK driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x,
lanes: 16 bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.13.8-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24fd class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.2 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-1:2
IF: enp4s0f3u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:4 chip-ID: 8087:0a2b
Local Storage: total: 931.51 GiB used: 62.38 GiB (6.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 44.9 C
used: 62.38 GiB (6.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A
Memory: total: 16 GiB note: est. available: 15 GiB used: 4.65 GiB (31.0%)
Processes: 433 Power: uptime: 1m states: freeze,mem,disk suspend: s2idle
image: 5.99 GiB services: org_kde_powerdevil, power-profiles-daemon,
Packages: pm: pacman pkgs: 1829 libs: 550 tools: gnome-software, octopi,
pamac, paru Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 4.0.1 running-in: konsole inxi: 3.3.37
System install date:     2024-06-11
Last full system update: 2025-03-25
also, short info that ive seen.
the Device is connected for a short while, during pairing but then disconnects during the Pairing process.
Best Regards!
Additional update:
After following the arch Wiki regarding bluetoothctl i was able to get the mouse working, tou now after powering the device off the problem rearises once again. having to go to the pairing process onece more
Please, if you want to add new information just edit your last post as long as no one has replied yet. Thank you. :slight_smile:
You may want to try downgrading bluez back to 5.79, see:
You could also switch to using bluueman rather than downgrading, as partial updates are best avoided with Arch based systems.
Hi,
i would much rather downgrade as i don’t really like Pulswire.
And this might be a bit of a stupid question but how exactly do i downgrade? I’ve already Tried the “downgrade” bash script but either im doing something wrong or there’s another option that im unaware of.
Would really appreciate you’re help :slight_smile: Thanks!
Make a bios update pls
Pls look self before you ask how-to, next time. :innocent:
Downgrade : Downgrading packages - ArchWiki
The procedure from the ArchWiki for downgrading packages is not necessary on Garuda Linux.
Just open a terminal and use this:
sudo downgrade <package>
You can also wait a while, bluez version 5.81-1 is currently in extra-testing and should be in the extra repo soon, maybe the new version will fix your issue.
Thanks for the Help!
Downgrading worked, and thanks for being nice even if im not the biggest expert :slight_smile:
We always mark here the solution and not the implementation. :wink:
@tbg gave you the tip to downgrade, not me. That’s why I corrected the marked solution.
Edit: @PlayerNoName bluez version 5.82-1 is available, try to update bluez and check if you have issues with the new version.
