Bluetooth mouse not detected
Hello here,
During the liveUSB session, I was able to add my mouse (a logitech MX master 3S) in Bluetooth without problem.
Since I use the installed Garuda however, I can’t find the same mouse in the Bluetooth search function.
Here is the full Garuda-inxi
Kernel: 6.7.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=21a3c4fd-2895-4651-81e7-b9de4386ced8 rw rootflags=subvol=@
quiet resume=UUID=e6e1c3b7-1697-40f6-840e-325760da7891 loglevel=3 ibt=off
v: 5.115.0 wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Garuda
Type: Desktop Mobo: Micro-Star model: PRO B650M-A WIFI (MS-7D77) v: 1.0
Megatrends LLC. v: 1.C0 date: 11/22/2023
Info: model: AMD Ryzen 5 7600 bits: 64 type: MT MCP arch: Zen 4 gen: 5
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 6 MiB desc: 6x1024 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4564 high: 4949 min/max: 400/5170 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 4948 2: 4949 3: 4942
4: 4948 5: 4949 6: 4932 7: 4935 8: 4948 9: 400 10: 4949 11: 4932 12: 4945
bogomips: 91206
Device-1: NVIDIA GM200 [GeForce GTX 980 Ti] vendor: Gigabyte driver: nvidia
(as of 2024-02; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: DP-1,HDMI-A-1 empty: DP-2,DP-3,DVI-I-1
bus-ID: 01:00.0 chip-ID: 10de:17c8 class-ID: 0300
Device-2: AMD Raphael vendor: Micro-Star MSI driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-4, DP-5,
DP-6, HDMI-A-2 bus-ID: 10:00.0 chip-ID: 1002:164e class-ID: 0300
temp: 37.0 C
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2:3
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 110 s-size: 1034x333mm (40.71x13.11")
s-diag: 1086mm (42.77")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary,left
model: Dell S2721D serial: <filter> built: 2020 res: 2560x1440 hz: 60
dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 676mm (26.6")
Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: right
model: Asus VX239 serial: <filter> built: 2013 res: 1920x1080 hz: 60 dpi: 96
gamma: 1.2 size: 510x290mm (20.08x11.42") diag: 587mm (23.1") ratio: 16:9
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 980 Ti/PCIe/SSE2
memory: 5.86 GiB
API: Vulkan v: 1.3.276 layers: 14 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 980 Ti driver: nvidia v: 545.29.06 device-ID: 10de:17c8
surfaces: xcb,xlib device: 1 type: integrated-gpu name: AMD Radeon
Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv v: 24.0.1-arch1.1
device-ID: 1002:164e surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 24.0.1-arch1.1 (LLVM
Device-1: NVIDIA GM200 High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:0fb0 class-ID: 0403
Device-2: AMD Rembrandt Radeon High Definition Audio
speed: 16 GT/s lanes: 16 bus-ID: 10:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
bus-ID: 10:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.7.6-zen1-1-zen status: kernel-api with: aoss
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0c:00.0
IF: enp12s0 state: down mac: <filter>
bus-ID: 0d:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp13s0 state: up mac: <filter>
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:4 chip-ID: 0e8d:0616
Local Storage: total: 3.43 TiB used: 180.46 GiB (5.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S1000G
lanes: 4 tech: SSD serial: <filter> fw-rev: SBM02103 temp: 44.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 830 Series
tech: SSD serial: <filter> fw-rev: 3B1Q scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 500GB
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000DM001-1ER164
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC26 scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 vendor: Generic model: USB Flash
size: 14.84 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
fw-rev: 0.00 scheme: MBR
ID-1: / raw-size: 897.62 GiB size: 897.62 GiB (100.00%)
used: 113.82 GiB (12.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 897.62 GiB size: 897.62 GiB (100.00%)
ID-4: /var/log raw-size: 897.62 GiB size: 897.62 GiB (100.00%)
ID-5: /var/tmp raw-size: 897.62 GiB size: 897.62 GiB (100.00%)
ID-1: swap-1 type: partition size: 33.6 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 30.54 GiB used: 894.5 MiB (2.9%)
System Temperatures: cpu: 42.1 C mobo: 42.0 C
GPU: device: nvidia screen: :0.0 temp: 56 C fan: 37% device: amdgpu
temp: 37.0 C
Memory: total: 32 GiB note: est. available: 30.54 GiB used: 11.7 GiB (38.3%)
Processes: 404 Power: uptime: 1h 35m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.17 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1841 libs: 564 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0 running-in: konsole
inxi: 3.3.33
Garuda (2.6.23-1):
System install date:     2024-02-23
Last full system update: 2024-02-24 ↻
Would anyone have any idea why I can’t see this mouse where I was able to use it live?
Thanks for reading
Please, reboot.
Install solaar,
What’s about Bolt?
Solaar recognizes my K800 keyboard & MX Master 2/2S.
Be sure that Bluetooth is enabled in KDE Settings and in systemd (sudo systemctl enable bluetooth).
EDIT: Also, ensure the pkgs bluez & bluez-utils are installed.
Solaar is Installed, but the mouse is just not recognized by the system. On the live session, I didn’t had solar and it was working.
Bluetooth is working, I was able to pair my phone and some audio device without problem.
Does the 3S also have wireless or is it BT-only? If it can be connected by wireless, try doing that first, then pairing w/BT.
Found the solution, since that slot was attributed to the live-session, my current session couldn’t recognize it as available.
Thanks all for the support!
