I’m using Garuda Dr460nized and I’m having an issue I haven’t been able to resolve for over a month.
Background:
I have two 4K monitors and I’m concerned about burn-in. So I set the Screen Energy Saving to switch off the displays after 15 minutes of inactivity. I also set each monitor to use a slideshow for desktop wallpapers that changes every 15 minutes, using a photo folder I have saved in the Home drive. For months this worked perfectly with no problems, but at some point something changed.
Issue description:
When I move my mouse to reactivate the displays there is a weird glitch on the main monitor. Firstly, it won’t let me right click (or left click) on the desktop, though the taskbar and dock still function normally. Secondly, any icons that were on the desktop of the main monitor are now on the secondary monitor. Thirdly, the wallpaper will now either be stuck on the last image and fail to change, or it will be just a black background. The only way to fix these issues is to either logout and log back in, or restart the computer. When I do that I find that the wallpaper settings have been reset to “Image” from “Slideshow,” regardless if there is a visible wallpaper or if it is blank. I then have to set it back to slideshow and find the folder containing my backgrounds again.
I’m sure one solution is reinstalling the OS but I’ve spent a lot of time getting this setup exactly the way I want, so I really don’t want to do that. Not to mention, how do I know it won’t just happen again?
Does anyone have any ideas on what might have changed and how I can fix it?
This seems to be the same issue found in the post below which appears to not have been resolved:
I am using x86_64 Garuda on my laptop running the KDE lite version of Garuda. I am having an external monitor connected to my laptop via the VGA port.
When I start up my machine and log in, the wallpaper on the monitor side of the screen works fine. But on the laptop side of things it doesn't load anything. I am not even able to right click on the laptop wallpaper portion. The start menu and the docks all work fine. The wallpaper portion is the issue.
To fix this I disconnect and reconnect the…
Hi, thanks for taking a look. Here's the output:
Kernel: 5.17.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=642710e8-56f9-4854-9724-36f1318ec366 rw rootflags=subvol=@
resume=UUID=20fb7f3d-2ecf-48cd-ad0a-239e0717e374 loglevel=3
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 1407
date: 04/01/2020
Device-1: hidpp_battery_0 model: Logitech G700s serial: <filter>
charge: 50% (should be ignored) rechargeable: yes status: N/A
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 3596 high: 3690 min/max: 2200/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3588 2: 3606
3: 3583 4: 3591 5: 3690 6: 3599 7: 3590 8: 3592 9: 3594 10: 3578 11: 3592
12: 3594 13: 3591 14: 3592 15: 3593 16: 3590 17: 3590 18: 3591 19: 3594
20: 3593 21: 3600 22: 3595 23: 3592 24: 3594 bogomips: 182058
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
vendor: ASRock driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-1,DP-2 empty: DP-3, DP-4, HDMI-A-1, HDMI-A-2
bus-ID: 0c:00.0 chip-ID: 1002:731f class-ID: 0300
Screen-1: 0 s-res: 7680x2160 s-dpi: 96 s-size: 2032x571mm (80.00x22.48")
s-diag: 2111mm (83.1")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left
model: Acer VG280K serial: <filter> built: 2019 res: 3840x2160 hz: 60
dpi: 157 gamma: 1.2 size: 621x341mm (24.45x13.43") diag: 708mm (27.9")
ratio: 16:9 modes: max: 3840x2160 min: 640x480
Monitor-2: DP-2 mapped: DisplayPort-1 pos: right model: Acer VG280K
serial: <filter> built: 2019 res: 3840x2160 hz: 60 dpi: 157 gamma: 1.2
size: 621x341mm (24.45x13.43") diag: 708mm (27.9") ratio: 16:9 modes:
OpenGL: renderer: AMD Radeon RX 5700 XT (navi10 LLVM 13.0.1 DRM 3.44
5.17.4-zen1-1-zen)
v: 4.6 Mesa 22.0.2 direct render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:ab38
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.17.4-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.50 running: yes
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2526 class-ID: 0280
lanes: 1 port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
v: 0.8 bus-ID: 3-5:4 chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 21.38 TiB used: 4.34 TiB (20.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 1B4QFXO7
temp: 35.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 980 1TB
temp: 34.9 C scheme: GPT
model: WD60EZAZ-00ZGHB0 size: 5.46 TiB block-size: physical: 4096 B
rev: 0A80 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi)
model: HTS721010A9E630 size: 931.51 GiB block-size: physical: 4096 B
rev: A3B0 scheme: MBR
ID-5: /dev/sdc maj-min: 8:32 vendor: Toshiba model: HDWE150
size: 4.55 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: FP2A scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Toshiba model: DT01ACA300
type: HDD rpm: 7200 serial: <filter> rev: ABB0 scheme: GPT
ID-7: /dev/sde maj-min: 8:64 vendor: Western Digital
model: WDS250G1B0A-00H9H0 size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00WD
ID-8: /dev/sdf maj-min: 8:80 vendor: Crucial model: CT250BX100SSD1
type: SSD serial: <filter> rev: MU02 scheme: GPT
ID-9: /dev/sdg maj-min: 8:96 vendor: Western Digital
model: WD60EZRZ-00GZ5B1 size: 5.46 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5700 serial: <filter>
ID-1: / raw-size: 914.16 GiB size: 914.16 GiB (100.00%)
used: 805.78 GiB (88.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
used: 5.5 MiB (2.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
ID-3: /home raw-size: 914.16 GiB size: 914.16 GiB (100.00%)
ID-4: /var/log raw-size: 914.16 GiB size: 914.16 GiB (100.00%)
ID-5: /var/tmp raw-size: 914.16 GiB size: 914.16 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.1 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:4
ID-2: swap-2 type: zram size: 31.33 GiB used: 2.5 MiB (0.0%)
System Temperatures: cpu: 33.5 C mobo: 36.0 C gpu: amdgpu temp: 50.0 C
mem: 56.0 C
Fan Speeds (RPM): fan-1: 794 fan-2: 1351 fan-3: 505 fan-4: 508
fan-5: 3047 fan-6: 0 fan-7: 736 gpu: amdgpu fan: 0
Processes: 443 Uptime: 4h 28m wakeups: 5 Memory: 31.33 GiB
used: 7.48 GiB (23.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1454 lib: 435 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2021-09-22
Last full system update: 2022-04-27
Snapshots: Timeshift (maybe)
Failed units: pacman-files.service
First i would update your system with
garuda-update
as there is a kernel update which may help
petsam
April 29, 2022, 8:38pm
5
I’m afraid not…
Welcome to KDE multi-screen nightmare bugs !
Until KDE resolves these issues (which are created from monitor naming and enable/disable monitors), which is suspected to be with Plasma 6, you can only find workarounds for your system. Unfortunately, there is no one-only solution, since it is related to individual HW/SW combination.
system
Closed
May 13, 2022, 8:38pm
6
