hello! I noticed my touchpad speed settings do not persist and reset everytime I restart or shut down, anyway to fix this?
Kernel: 5.16.1-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=9909eebf-09bb-400d-b4b0-9ff63a8076ea rw rootflags=subvol=@
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Mobo: ASUSTeK model: PRIME Z590-A v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 0402
date: 01/08/2021
Device-1: hid-04:4b:ed:eb:cc:93-battery model: Claudia's Trackpad
serial: N/A charge: N/A status: Discharging
Device-2: hid-e0:eb:40:cd:73:bd-battery model: Claudia Cho’s Keyboard
Info: model: 11th Gen Intel Core i9-11900K bits: 64 type: MT MCP
arch: Rocket Lake family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x40
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 5100 high: 5299 min/max: 800/5300 scaling:
driver: intel_pstate governor: performance cores: 1: 5091 2: 4963 3: 5010
4: 5138 5: 5158 6: 5234 7: 5010 8: 5240 9: 4747 10: 5192 11: 4897
12: 5269 13: 5164 14: 4946 15: 5242 16: 5299 bogomips: 112128
Device-1: Intel RocketLake-S GT1 [UHD Graphics 750] vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:4c8a class-ID: 0300
Device-2: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel bus-ID: 01:00.0
Device-3: Logitech BRIO Ultra HD Webcam type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 2-6:2
chip-ID: 046d:085e class-ID: 0300 serial: <filter>
loaded: amdgpu,ati,intel unloaded: modesetting alternate: fbdev,vesa
Screen-1: 0 s-res: 3000x1920 s-dpi: 96 s-size: 791x506mm (31.1x19.9")
s-diag: 939mm (37")
Monitor-1: DisplayPort-3 res: 1920x1080 hz: 60 dpi: 70
size: 698x393mm (27.5x15.5") diag: 801mm (31.5")
Monitor-2: HDMI-A-2 res: 1080x1920
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
chip-ID: 8086:43c8 class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-3: Blue Microphones Yeti Stereo Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-13:9 chip-ID: b58e:9e84
Device-4: Logitech BRIO Ultra HD Webcam type: USB
Sound Server-1: ALSA v: k5.16.1-zen1-1-zen running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-5: PipeWire v: 0.3.43 running: yes
Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
port: N/A bus-ID: 03:00.0 chip-ID: 8086:15f3 class-ID: 0200
Device-2: Broadcom BCM4352 802.11ac Wireless Network Adapter
vendor: ASUSTeK driver: wl v: kernel modules: bcma bus-ID: 05:00.0
chip-ID: 14e4:43b1 class-ID: 0280
IF: wlan0 state: up mac: <filter>
Device-1: Dynex Bluetooth 4.0 Adapter [Broadcom 1.12 BCM20702A0] type: USB
driver: btusb v: 0.8 bus-ID: 1-11:8 chip-ID: 19ff:0239 class-ID: fe01
Local Storage: total: 11.85 TiB used: 421.41 GiB (3.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 type: SSD serial: <filter> rev: 3B2QGXA7 temp: 37.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
type: SSD serial: <filter> rev: 1B6Q scheme: MBR
model: WD100EZAZ-11TDBA0 size: 9.1 TiB block-size: physical: 4096 B
rev: 0A83 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Walgreen model: Infinitive
size: 28.65 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 410.42 GiB (22.0%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 25.8 MiB (8.6%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
ID-1: swap-1 type: zram size: 31.1 GiB used: 2.5 MiB (0.0%) priority: 100
System Temperatures: cpu: 48.0 C mobo: N/A gpu: amdgpu temp: 38.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 709
Processes: 488 Uptime: 29m wakeups: 6 Memory: 31.1 GiB
used: 9.18 GiB (29.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1788 lib: 463 Shell: fish
v: 3.3.1 running-in: konsole inxi: 3.3.11
â•─cc@cc in ~ via  v17.3.0 took 979ms
╰─λ ### Post your terminal/konsole in- and output as text (***no*** ***pictures***) from:
╰─λ ~~~
find-the-command: "~~~" is not found locally, searching in repositories...
find-the-command: command not found: ~~~
â•─cc@cc in ~ via  v17.3.0 took 299ms
[🔍] × inxi -Faz
date: 01/08/2021
microcode: 0x40
Speed (MHz): avg: 4676 high: 5259 min/max: 800/5300 scaling:
driver: intel_pstate governor: performance cores: 1: 5117 2: 3460 3: 4938
4: 5227 5: 4901 6: 4961 7: 5121 8: 4947 9: 3135 10: 5259 11: 5004
12: 2709 13: 5011 14: 5022 15: 5052 16: 4960 bogomips: 112128
s-diag: 939mm (37")
maj-min: 259:2
maj-min: 259:1
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
Processes: 488 Uptime: 30m wakeups: 6 Memory: 31.1 GiB
used: 9.21 GiB (29.6%) Init: systemd v: 250 tool: systemctl Compilers:
