Hello
I have been using Garuda, everything is excellent except that half the times I boot my laptop trackpad is disabled and the only way to fix it is to reboot completely. This issue used to occur on Manjaro too, however it was less seen there.
inxi -Fzza
System: Kernel: 5.10.15-120-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=f2947d3f-0ce7-4b11-8892-ceb656679574 rw rootflags=subvol=@ quiet splash rd.udev.log_priority=3
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: ASUSTeK product: TUF Gaming FX505DD_FX505DD v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FX505DD v: 1.0 serial: <filter> UEFI: American Megatrends v: FX505DD.315 date: 09/22/2020
Battery: ID-1: BAT0 charge: 42.3 Wh condition: 42.3/50.6 Wh (84%) volts: 12.6/12.3 model: FX50442 type: Li-ion serial: N/A
status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter> charge: 55% (should be ignored)
rechargeable: yes status: Discharging
CPU: Info: Quad Core model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen/Zen+
note: check family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108102 L2 cache: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 33575
Speed: 3156 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz): 1: 3156 2: 3200 3: 3205 4: 3196 5: 3220
6: 3219 7: 3133 8: 3202
Graphics: Device-1: NVIDIA GP107M [GeForce GTX 1050 3 GB Max-Q] driver: nvidia v: 460.39 alternate: nouveau,nvidia_drm
bus ID: 01:00.0 chip ID: 10de:1c91 class ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Picasso vendor: ASUSTeK driver: amdgpu v: kernel bus ID: 05:00.0
chip ID: 1002:15d8 class ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus ID: 3-1:2 chip ID: 13d3:56a2
class ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: modesetting,nvidia display ID: :0
Monitor-1: eDP-1 res: 1920x1080 hz: 120 dpi: 142 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0 5.10.15-120-tkg-bmq LLVM 11.0.1) v: 4.6 Mesa 20.3.4
direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 05:00.6 chip ID: 1022:15e3 class ID: 0403
Device-2: GN Netcom Jabra EVOLVE 20 MS type: USB driver: jabra,snd-usb-audio,usbhid bus ID: 1-3:3
chip ID: 0b0e:0300 class ID: 0300 serial: <filter>
Sound Server: ALSA v: k5.10.15-120-tkg-bmq
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: e000
bus ID: 02:00.0 chip ID: 10ec:8168 class ID: 0200
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: AzureWave driver: rtw_8822be v: N/A
modules: rtw88_8822be port: d000 bus ID: 04:00.0 chip ID: 10ec:b822 class ID: 0280
Bluetooth: Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8 bus ID: 1-4:2 chip ID: 13d3:3526
class ID: e001 serial: <filter>
Message: Required tool hciconfig not installed. Check --recommends
Drives: Local Storage: total: 1.14 TiB used: 339.12 GiB (29.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520 SDAPNUW-256G-1002 size: 238.47 GiB
block size: physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 rotation: SSD serial: <filter> rev: 20110000
temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: SDM4 scheme: GPT
Partition: ID-1: / raw size: 237.99 GiB size: 237.99 GiB (100.00%) used: 110.03 GiB (46.2%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw size: 500 MiB size: 499 MiB (99.80%) used: 73.2 MiB (14.7%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw size: 237.99 GiB size: 237.99 GiB (100.00%) used: 110.03 GiB (46.2%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-4: /var/log raw size: 237.99 GiB size: 237.99 GiB (100.00%) used: 110.03 GiB (46.2%) fs: btrfs
ID-5: /var/tmp raw size: 237.99 GiB size: 237.99 GiB (100.00%) used: 110.03 GiB (46.2%) fs: btrfs
ID-1: swap-1 type: zram size: 931 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 931 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 931 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 931 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 931 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 931 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 931 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 931 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
Sensors: System Temperatures: cpu: 52.4 C mobo: N/A gpu: amdgpu temp: 52.0 C
Fan Speeds (RPM): cpu: 2800
Info: Processes: 305 Uptime: 4m wakeups: 3 Memory: 7.27 GiB used: 3.21 GiB (44.1%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 clang: 11.0.1 Packages: pacman: 1782 lib: 539 Shell: Zsh v: 5.8 running in: konsole inxi: 3.3.01
sudo journalctl -b
xinput
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ Logitech Wireless Mouse id=12 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Asus Wireless Radio Control id=7 [slave keyboard (3)]
↳ Video Bus id=8 [slave keyboard (3)]
↳ Power Button id=9 [slave keyboard (3)]
↳ Sleep Button id=10 [slave keyboard (3)]
↳ USB2.0 HD UVC WebCam: USB2.0 HD id=11 [slave keyboard (3)]
↳ Asus WMI hotkeys id=13 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=14 [slave keyboard (3)]
↳ GN Netcom A/S Jabra EVOLVE 20 MS id=15 [slave keyboard (3)]
Would appreciate any help
