The top bar in the Plasma desktop randomly loses its transparency and becomes black or sometimes disappears altogether. At times it is fixed by a reboot, at times it's not. Please help me fix this. Thanks!
Output for garuda-inxi
Kernel: 5.16.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=8dcf10f3-a757-48a0-be6b-617f5baccb56 rw rootflags=subvol=@
Type: Laptop System: LENOVO product: 80QQ v: Lenovo ideapad 100-15IBD
serial: <filter> Chassis: type: 10 v: Lenovo ideapad 100-15IBD
Mobo: LENOVO model: Nano 5B6 v: NO DPK serial: <filter>
UEFI-[Legacy]: LENOVO v: E0CN45WW date: 01/13/2016
ID-1: BAT0 charge: 16.8 Wh (100.0%) condition: 16.8/30.1 Wh (55.7%)
volts: 16.1 min: 14.4 model: ANYO 15S4A01 type: Li-poly serial: <filter>
status: Full
Info: model: Intel Core i3-5005U socket: BGA1168 (U3E1) note: check
bits: 64 type: MT MCP arch: Broadwell family: 6 model-id: 0x3D (61)
stepping: 4 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1440 high: 1894 min/max: 500/1900 base/boost: 2000/2000
scaling: driver: intel_cpufreq governor: schedutil volts: 0.8 V
ext-clock: 100 MHz cores: 1: 1098 2: 1611 3: 1159 4: 1894 bogomips: 15963
Device-1: Intel HD Graphics 5500 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
Device-2: IMC Networks Lenovo EasyCamera type: USB driver: uvcvideo
bus-ID: 2-6:3 chip-ID: 13d3:5744 class-ID: 0e02
Display: server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2)
v: 4.6 Mesa 21.3.6 direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Lenovo
Sound Server-1: ALSA v: k5.16.10-zen1-1-zen running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.47 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo
driver: r8169 v: kernel port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8136
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Lenovo
driver: rtl8723be v: kernel port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:b723
Device-1: Realtek RTL8723B Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 2-7:4 chip-ID: 0bda:b728 class-ID: e001 serial: <filter>
Local Storage: total: 409.89 GiB used: 19.36 GiB (4.7%)
model: WDS120G2G0A-00JH30 family: WD Blue / Red / Green SSDs
size: 111.8 GiB block-size: physical: 512 B logical: 512 B sata: 3.2
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0000 temp: 28 C
scheme: MBR
SMART: yes state: enabled health: PASSED on: 225d 22h cycles: 2315
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MK3276GSX
family: 2.5" HDD MK..76GSX size: 298.09 GiB block-size: physical: 512 B
logical: 512 B sata: 2.6 speed: 3.0 Gb/s type: HDD rpm: 5400
serial: <filter> rev: 1X temp: 27 C scheme: MBR
SMART: yes state: enabled health: PASSED cycles: 229
ID-1: / raw-size: 111.79 GiB size: 111.79 GiB (100.00%)
used: 19.36 GiB (17.3%) fs: btrfs block-size: 4096 B dev: /dev/sda1
maj-min: 8:1
ID-2: /home raw-size: 111.79 GiB size: 111.79 GiB (100.00%)
maj-min: 8:1
ID-3: /var/log raw-size: 111.79 GiB size: 111.79 GiB (100.00%)
maj-min: 8:1
ID-4: /var/tmp raw-size: 111.79 GiB size: 111.79 GiB (100.00%)
maj-min: 8:1
ID-1: swap-1 type: zram size: 3.75 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 54.0 C mobo: N/A
Processes: 233 Uptime: 5m wakeups: 1 Memory: 3.75 GiB
used: 1.77 GiB (47.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1487 lib: 362
Shell: garuda-inxi (sudo) default: Bash v: 5.1.16 running-in: alacritty
inxi: 3.3.12
Garuda (2.5.4-2):
System install date: 2022-02-13
Last full system update: 2022-02-19
