Titlebar disappears in fullscreen
Hello
When I maximise windows the titlebar disappears so I can't minimize or close the window.
I tried searching for this and found someone with a similar problem and the solution was to open configure latte but I can't find that at all on my system. I've checked the system settings and can't seem to find the option there.
Any help is appreciated, thanks.
Kernel: 5.19.7-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=58bdd034-3ae9-4042-ae33-4adf92f24d3a rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
Type: Laptop System: Micro-Star product: GF65 Thin 10UE v: REV:1.0
Mobo: Micro-Star model: MS-16W2 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16W2IMS.105 date: 05/14/2021
ID-1: BAT1 charge: 18.7 Wh (93.0%) condition: 20.1/51.3 Wh (39.1%)
volts: 12.6 min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 built: 2020 process: Intel 14nm family: 6 model-id: 0xA5 (165)
stepping: 2 microcode: 0xF0
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3093 high: 4793 min/max: 800/5000 scaling:
driver: intel_pstate governor: performance cores: 1: 4232 2: 4700 3: 4793
4: 2600 5: 2600 6: 2600 7: 2600 8: 2600 9: 2600 10: 2600 11: 2600
12: 2600 bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor: Micro-Star MSI driver: nvidia v: 515.65.01
alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current (as of
2022-07) arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-22
pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
unloaded: nouveau alternate: fbdev,intel,nv,vesa gpu: i915 display-ID: :0
s-diag: 1052mm (41.43")
Monitor-1: HDMI-1-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 55
size: 885x498mm (34.84x19.61") diag: 1015mm (39.98") modes: N/A
Monitor-2: eDP-1 pos: primary,right res: 1920x1080 hz: 144 dpi: 142
size: 344x193mm (13.54x7.6") diag: 394mm (15.53") modes: N/A
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
Device-2: NVIDIA GA106 High Definition Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e
Sound Server-1: ALSA v: k5.19.7-zen2-1-zen running: yes
bus-ID: 1-14:3 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 1.38 TiB used: 564.44 GiB (40.1%)
model: 2210 MTFDHBA512QFD size: 476.94 GiB block-size: physical: 512 B
rev: P6MA001 temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: SSD PLUS
1000GB size: 931.52 GiB block-size: physical: 512 B logical: 512 B
type: SSD serial: <filter> scheme: GPT
ID-1: / raw-size: 78.13 GiB size: 78.13 GiB (100.00%) used: 57.07 GiB
(73.1%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 25.7 MiB
(26.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 78.13 GiB size: 78.13 GiB (100.00%) used: 57.07 GiB
ID-4: /var/log raw-size: 78.13 GiB size: 78.13 GiB (100.00%) used: 57.07
GiB (73.1%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-5: /var/tmp raw-size: 78.13 GiB size: 78.13 GiB (100.00%) used: 57.07
ID-1: swap-1 type: zram size: 15.45 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 76.0 C pch: 61.0 C mobo: N/A
Processes: 326 Uptime: 30m wakeups: 1 Memory: 15.45 GiB used: 4.11 GiB
(26.6%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pacman: 1924 lib: 548 Shell: fish v: 3.5.1
Garuda (2.6.6-2):
System install date:     2022-09-07
Last full system update: 2022-09-07
With Latte, when windows are maximized you should have the buttons on the left of the top panel, and also the windows titles.
If not, you have to reconfigure your panel with right click, configure panel and set the widgets.
The easiest way would be to reset Latte to deafult config with Garuda Assistant.
I forgot to mention I'm using the "breeze dark" global theme. So resetting latte gives me back the minimize button but now i've got the dock covering my taskbar.
Also helpful, on KDE Plasma, the default hotkey to open the context menu to change window properties individually is Alt + F3 with that window active.
Now I’m a bit lost :blush:.
You mean previously you were not using Latte? Or had removed the dock?
In the first case you could set to false the BorderlessMaximizedWindows parameter here, or if you do use Latte you could do it also as a setting in the GUI.
It seems a screenshot would help. I've read elsewhere that this is discouraged on help requests, but i think it could help clear things up.
We love screenshots of the whole monitor, on which you can then read an error message with just one sentence in a pop up window :wink:
And of course we don't like terminal output as a photo. You can't make the text searchable or copy it for internet search.
