timeshift-autosnap not working , and pacman is not installing anything
E: System disk not found!
Unable to run timeshift-autosnap! Please close Timeshift and try again. Script will now exit...
error: failed to commit transaction (failed to run transaction hooks)
(1/1) Creating Timeshift snapshot before upgrade...
E: ts: Failed to get partition list.
First run mode (config file not found)
Selected default snapshot type: BTRFS
Do not type/post like in chat style, please
If you include terminal outputs in your post please use the proper output format in your post. Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look.
This is really strange.
They are not shown above and also no btrfs partition is shown.
Did you happen to make any important update recently?
Especially a BIOS update, that might have reset some important parameters?
I remember some systems need certain settings to show nvme disks, like Sata mode ahci or vdm off.
Maybe also a Windows update can do such nasty things.
