so after I installed garuda linux I went through the setup assistant and updated the system and I noticed that the
the usb device isn't showing up in the nautilus
fixed It after installing xhci_pci module
https://aur.archlinux.org/packages/upd72020x-fw/
That's awesome to read. You do know, now, that you'll possibly probably need to add that module wherever you go in Linux--Arch, anyway.
