Simple problem. My cd commands are running slow on all terminal clients. The "cd" command has a 0.5s delay before it completes. It happened over night. I dont know why.
My bashrc:
# ~/.bashrc
# If not running interactively, don't do anything
[[ $- != *i* ]] && return
alias ls='ls --color=auto'
PS1='[\[email protected]\h \W]\$ '
fish
My alacritty (Terminal app)config:
key_bindings:
- { key: V, mods: Control, action: Paste }
- { key: C, mods: Control, action: Copy }
- { key: Q, mods: Control, action: Quit }
- { key: W, mods: Command, action: Quit }
- { key: Home, chars: "\eOH", mode: AppCursor }
- { key: Home, chars: "\e[H", mode: ~AppCursor }
- { key: End, chars: "\eOF", mode: AppCursor }
- { key: End, chars: "\e[F", mode: ~AppCursor }
- { key: Key0, mods: Command, action: ResetFontSize }
- { key: Equals, mods: Command, action: IncreaseFontSize }
- { key: Minus, mods: Command, action: DecreaseFontSize }
- { key: PageUp, mods: Shift, chars: "\e[5;2~" }
- { key: PageUp, mods: Control, chars: "\e[5;5~" }
- { key: PageUp, chars: "\e[5~" }
- { key: PageDown, mods: Shift, chars: "\e[6;2~" }
# How do I set a key binding for Alacritty to interpret `alt+l` on macOS
window:
opacity: 0.85
colors:
author: Chris Kempson
primary:
background: "#16181a"
foreground: "#c5c8c6"
cursor:
text: "#1d1f21"
cursor: "#c5c8c6"
normal:
black: "#1d1f21"
red: "#cc6666"
green: "#b5bd68"
yellow: "#f0c674"
blue: "#81a2be"
magenta: "#b294bb"
cyan: "#8abeb7"
white: "#c5c8c6"
bright:
black: "#969896"
red: "#cc6666"
green: "#b5bd68"
yellow: "#f0c674"
blue: "#81a2be"
magenta: "#b294bb"
cyan: "#8abeb7"
white: "#ffffff"
theme: Tomorrow.dark
My fish config:
if status is-interactive
# Commands to run in interactive sessions can go here
end
# Define alias in shell
# Define alias in config file ( `~/.config/fish/config.fish` )
# This is equivalent to entering the following function:
function rmi
rm -i $argv
end
# Then, to save it across terminal sessions:
funcsave rmi
#### >>>> ALIAS <<<< #####
alias jv="java"
alias ja="java"
alias pi="sudo pacman -S"
alias pu="sudo pacman -Syu"
alias hs="history"
alias prez="kquitapp5 plasmashell"
alias lamp="sudo /opt/lampp/lampp start"
alias pr="python"
alias py="python"
alias yi="yay -S"
alias rb="reboot"
alias yu="yay -Syyu"
alias cat="ccat"
#### NAV ####
alias ff="fg"
alias rr="ranger"
alias hd="cd /home/aegir/"
alias c="cd"
alias .="cd .."
alias ..="cd ../../"
alias v="nvim"
alias sv="nvim"
mcfly init fish | source
clear
Kernel: 6.1.5-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=bd716b39-6313-4def-bb78-fea6f3782898 rw [email protected]
loglevel=3 ibt=off
Type: Desktop Mobo: ASUSTeK model: PRIME B450M-A v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3604
date: 02/25/2022
Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ gen: 2
model-id: 8 stepping: 2 microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2306 high: 3700 min/max: 2200/3700 boost: disabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
3: 2200 4: 2200 5: 3700 6: 2200 7: 2200 8: 2200 9: 2722 10: 1879 11: 2200
12: 2200 13: 2200 14: 2200 15: 2200 16: 2200 bogomips: 118399
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Micro-Star MSI
driver: nvidia v: 525.78.01 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 09:00.0 chip-ID: 10de:1c03 class-ID: 0300
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-8:4 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
compositor: kwin_x11 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1200 s-dpi: 93 s-size: 1049x321mm (41.30x12.64")
s-diag: 1097mm (43.19")
Monitor-1: DVI-D-0 pos: primary,right res: 1920x1200 hz: 60 dpi: 94
size: 518x324mm (20.39x12.76") diag: 611mm (24.05") modes: N/A
Monitor-2: HDMI-0 pos: left res: 1920x1200 hz: 60 dpi: 94
API: OpenGL v: 4.6.0 NVIDIA 525.78.01 renderer: NVIDIA GeForce GTX 1060
6GB/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel bus-ID: 1-8:4 v: kernel chip-ID: 046d:0825 pcie:
gen: 3 class-ID: 0102 speed: 8 GT/s serial: <filter> lanes: 16
bus-ID: 09:00.1 chip-ID: 10de:10f1 class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0b:00.3
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Device-4: C-Media CM6631A Audio Processor type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-3:3 chip-ID: 0d8c:0004
Sound API: ALSA v: k6.1.5-zen2-1-zen running: yes
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter driver: ath9k
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 07:00.0
chip-ID: 168c:002b class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 08:00.0 chip-ID: 10ec:8168
driver: btusb v: 0.8 bus-ID: 1-2:3 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 2.62 TiB used: 48.84 GiB (1.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Silicon Power
model: SPCC M.2 PCIe SSD size: 476.94 GiB block-size: physical: 512 B
rev: H211011a temp: 41.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: M4-CT128M4SSD2
type: SSD serial: <filter> rev: 000F scheme: GPT
model: WD20EARX-00PASB0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: AB51
scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Kingston model: SUV400S37240G
size: 223.57 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 96R9 scheme: GPT
ID-1: / raw-size: 243.65 GiB size: 243.65 GiB (100.00%)
used: 48.81 GiB (20.0%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
used: 28.1 MiB (9.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 243.65 GiB size: 243.65 GiB (100.00%)
ID-4: /var/log raw-size: 243.65 GiB size: 243.65 GiB (100.00%)
ID-5: /var/tmp raw-size: 243.65 GiB size: 243.65 GiB (100.00%)
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.53 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 43.0 C mobo: N/A gpu: nvidia temp: 29 C
Processes: 340 Uptime: 54m wakeups: 0 Memory: 15.53 GiB used: 4 GiB (25.7%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 Packages: pm: pacman pkgs: 1387 libs: 340 tools: octopi,paru,yay
pm: rpm pkgs: 0 Shell: fish v: 3.5.1 default: Bash v: 5.1.16
running-in: alacritty inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2023-01-05
Last full system update: 2023-01-15
