Hi.
I want to know if there is any way to add taskbar in Gnome Edition of Garuda Linux.
Alternatively, there is also Dash to Panel for more of a "taskbar" style.
thanks
thanks, also how can i add apps to desktop? it feels like cage idk why maybe its too clean...
Maybe this extension?
https://extensions.gnome.org/extension/2087/desktop-icons-ng-ding/
But Gnome is Gnome, although I don't use it, I wouldn't add this one....
I think GNOME do not like icons on desktop, but times change.
Explore your desktop. Learn it. You'll find that most of your initial questions will be answered by simple exploration and Googling. Plus wikis.
Googling especially.
Hmm. Well i have another question. Like ubuntu, is their any app store?
I had tried but google doesn't really help too much.
Thankyou for the help. Also will these changes make my system slower?
First thing in Linux world is
Just test your self, every different hardware got other results.
and will break the extensions ![]()
No. You install via terminal / pacman:
https://wiki.archlinux.org/title/Pacman
If you’re that new to the whole Arch-Linux / Garuda-Linux experience, try “first steps” in the wiki: After installing / Garuda apps | Garuda Linux wiki
