Hello, first of all, I would like to point out that I am a new Linux user, so I would appreciate it if you could simplify your answers ![]()
My problem is that sometimes my taskbar freezes. Even if I close an app it appears open. For example, I opened OBS Studio and closed it after I was done, but it did not disappear from my taskbar. Also, my taskbar no longer moves up and down, it suddenly appears when I hover over it, and some applications cannot be clicked. To solve this problem, I tried switching to X11 but the same thing happened again. I went into the taskbar settings and tried turning some settings on and off, but it still didn’t work.
Kernel: 6.6.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=40a1b073-0fd3-4276-b76e-b74cd211bf9b rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Desktop System: Gigabyte product: H610M H DDR4 v: -CF
Mobo: Gigabyte model: H610M H DDR4 serial: <superuser required>
UEFI: American Megatrends LLC. v: FSa date: 10/19/2023
Info: model: 12th Gen Intel Core i5-12400F bits: 64 type: MT MCP
microcode: 0x32
L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB desc: 6x1.2 MiB
L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 926 high: 1785 min/max: 800/4400 scaling:
driver: intel_pstate governor: powersave cores: 1: 1331 2: 800 3: 800 4: 800
5: 1785 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
bogomips: 59904
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: Gigabyte
status: current (as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: HDMI-A-2 empty: DP-1,DP-2,HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:2504 class-ID: 0300
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: 0
Monitor-1: HDMI-A-2 res: 1920x1080 size: N/A modes: N/A
x11: drv: zink inactive: device-1
API: Vulkan v: 1.3.274 layers: 11 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 545.29.06
device-ID: 10de:2504 surfaces: xcb,xlib,wayland
Device-2: NVIDIA GA106 High Definition Audio vendor: Gigabyte
Device-3: C-Media SN-RGW9 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:4
chip-ID: 0d8c:0012 class-ID: 0300 serial: <filter>
API: ALSA v: k6.6.7-zen1-1-zen status: kernel-api with: aoss
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.36 TiB used: 43.65 GiB (3.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: MLD M300 NVMe SSD
lanes: 4 tech: SSD serial: <filter> fw-rev: EDFMF0.0 temp: 34.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: HD105SI
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
used: 43.65 GiB (9.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.44 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 34.0 C mobo: 31.0 C
Processes: 326 Uptime: 1m wakeups: 0 Memory: total: 16 GiB
available: 15.45 GiB used: 3.08 GiB (20.0%) Init: systemd v: 255
pm: pacman pkgs: 1777 libs: 519 tools: octopi,paru Shell: fish v: 3.6.4
Garuda (2.6.21-1):
System install date: 2023-12-23
Last full system update: 2023-12-23
