Hello folks. It’s the first time ever IIRC that I’ve not been able to update on Garuda. Here’s the upd
terminal output:
Total Installed Size: 1684.90 MiB
Net Upgrade Size: 104.88 MiB
(60/60) checking keys in keyring [------------------------------------------] 100%
(60/60) checking package integrity [------------------------------------------] 100%
(60/60) loading package files [------------------------------------------] 100%
(60/60) checking for file conflicts [------------------------------------------] 100%
spice-vdagent: /usr/lib/systemd/user/graphical-session.target.wants/spice-vdagent.service exists in filesystem (owned by garuda-hardware-profile-vm)
A web search found posts about the vdagent but not specifically this issue. Any thoughts on a fix for this issue? I suppose there’s uninstalling the VM software but if there’s a cleaner option I’ll try that.
My inxi:
Kernel: 6.16.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=b71c31f1-55e9-4354-a076-2d2364f5e63d rw rootflags=subvol=@
nvidia-drm.modeset=1 nouveau.modeset=0 nvidia.NVreg_EnableGpuFirmware=0
drm.edid_firmware=DP-1:edid/AOC_edid.bin mt7921e.disable_aspm=Y quiet
loglevel=3 sysrq_always_enabled=1
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA506QM_TUF506QM
Mobo: ASUSTeK model: FA506QM v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: FA506QM.314
date: 01/07/2023
ID-1: BAT1 charge: 43.4 Wh (60.4%) condition: 71.8/90 Wh (79.8%)
volts: 15.44 min: 15.86 model: ASUS A32-K55 type: Li-ion serial: N/A
charging: status: not charging control: start: N/A end: 60% cycles: N/A
microcode: 0xA500012
Speed (MHz): avg: 2397 min/max: 403/3201 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2397 2: 2397 3: 2397
4: 2397 5: 2397 6: 2397 7: 2397 8: 2397 9: 2397 10: 2397 11: 2397 12: 2397
13: 2397 14: 2397 15: 2397 16: 2397 bogomips: 102212
ssse3 svm
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 580.82.09 alternate: nouveau,nvidia_drm
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1 empty: none bus-ID: 01:00.0 chip-ID: 10de:2520
Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5
lanes: 16 ports: active: HDMI-A-1 off: eDP-1 empty: none bus-ID: 06:00.0
chip-ID: 1002:1638 class-ID: 0300 temp: 54.0 C
Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 322e:202c
class-ID: 0e02
compositor: kwin_wayland driver:
gpu: amdgpu,nv_platform,nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: DP-1 model: AOC CQ27G4 serial: <filter> built: 2024 res:
mode: 2560x1440 hz: 144 scale: 100% (1) dpi: 109 gamma: 1.2
max: 2560x1440 min: 640x480
Monitor-2: HDMI-A-1 model: Sony TV serial: <filter> built: 2010 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 30 gamma: 1.2
size: 1600x900mm (62.99x35.43") diag: 1836mm (72.3") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-3: eDP-1 model: Najing CEC Panda 0x004d built: 2019 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
drv: kms_swrast surfaceless: drv: nvidia wayland: drv: radeonsi x11:
drv: radeonsi inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.2.3-arch1.2
renoir ACO DRM 3.64 6.16.8-zen1-1-zen) device-ID: 1002:1638
memory: 500 MiB unified: no display-ID: :0.0
API: Vulkan v: 1.4.321 layers: 14 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 25.2.3-arch1.2
device-ID: 1002:1638 surfaces: N/A device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 Laptop GPU driver: nvidia v: 580.82.09
device-ID: 10de:2520 surfaces: N/A device: 2 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.2.3-arch1.2 (LLVM
de: kscreen-console,kscreen-doctor gpu: lact, nvidia-settings, nvidia-smi
Device-2: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio
lanes: 16 bus-ID: 06:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Audio Coprocessor driver: N/A
snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63,
snd_sof_amd_acp70 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 06:00.5
lanes: 16 bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.16.8-zen1-1-zen status: kernel-api tools: N/A
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:3 chip-ID: 8087:0032
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.4
lmp-v: 13 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 3.25 TiB used: 1.37 TiB (42.1%)
fw-rev: 2B2QEXM7 temp: 48.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung
fw-rev: FXM7201Q temp: 43.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: A-Data model: USB Flash Drive
size: 58.88 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: 1.00 scheme: MBR
model: WD10EAVS-00D7B1 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0
tech: N/A serial: <filter> fw-rev: 1.75 scheme: MBR
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 75.68 GiB (75.7%)
fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:2
ID-2: /boot/efi raw-size: 1.95 GiB size: 1.95 GiB (99.80%)
used: 1.35 GiB (69.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:5
ID-3: /home raw-size: 100 GiB size: 100 GiB (100.00%)
used: 75.68 GiB (75.7%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:2
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.02 GiB used: 514 MiB (3.3%) priority: 100
System Temperatures: cpu: 60.0 C mobo: N/A gpu: amdgpu temp: 55.0 C
Memory: total: 16 GiB note: est. available: 15.02 GiB used: 7.41 GiB (49.3%)
Processes: 455 Power: uptime: 1h 19m states: freeze,mem,disk
suspend, test_resume image: 5.94 GiB services: org_kde_powerdevil,
Packages: 1822 pm: pacman pkgs: 1791 libs: 491 tools: octopi,pacseek,paru
pm: flatpak pkgs: 31 Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Bash
v: 5.3.3 default: fish v: 4.0.8 running-in: yakuake inxi: 3.3.39
Garuda (2.8.3-2):
System install date: 2024-08-27
Garuda release: 240428
Last full system update: 2025-09-22
23/24 checks run in 1.47 seconds ⌛
Powered by garuda-health 🦅
--- LOW ---
