Hi y'all - usually by the time I have a package conflict issue when running update from command-line and/or clicking on System update in Garuda Assistant, someone else has posted it and there's already a solution. I've checked the two other posts that are related to audio package conflicts, but I'm not sure I found what I'm looking for. This is what happens when I try to run update or click on System update:
resolving dependencies...
:: pipewire-support and pipewire-pulse are in conflict (pulseaudio). Remove pipewire-pulse? [y/N] y
:: pipewire-support and pipewire-alsa are in conflict (pulseaudio-alsa). Remove pipewire-alsa? [y/N] y
:: unable to satisfy dependency 'pipewire-alsa' required by pipewire-support
:: unable to satisfy dependency 'pipewire-pulse' required by pipewire-support
:: removing pipewire-pulse breaks dependency 'pulseaudio' required by plasma-pa
Here's my garuda-inxi
❯ garuda-inxi
Kernel: 5.15.3-2-cacule x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-cacule
root=UUID=12979374-b0c5-4bc8-8f21-3b53bd02741b rw rootflags=subvol=@
systemd.unified_cgroup_hierarchy=1 loglevel=3 sysrq_always_enabled=1
intel_iommu=on iommu=pt acpi_backlight=vendor delayacct
intel_pstate=passive
Console: pty pts/0 wm: kwin_x11 DM: SDDM Distro: Garuda Linux
Type: Laptop System: LENOVO product: 20175 v: Lenovo IdeaPad Yoga 13
serial: <filter> Chassis: type: 10 v: Lenovo IdeaPad Yoga 13
Mobo: LENOVO model: INVALID v: 31900003WIN8 STD MLT serial: <filter>
UEFI: LENOVO v: 66CN55WW date: 02/28/2013
ID-1: BAT1 charge: 38.1 Wh (99.2%) condition: 38.4/49.3 Wh (78.0%)
volts: 16.1 min: 14.8 model: Lenovo IdeaPad Mocca2 type: Unknown
serial: <filter> status: N/A
Info: model: Intel Core i7-3537U socket: rPGA988B (U3E1) note: check
bits: 64 type: MT MCP arch: Ivy Bridge family: 6 model-id: 0x3A (58)
stepping: 9 microcode: 0x21
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2754 high: 2855 min/max: 800/3100 base/boost: 1900/4000
scaling: driver: intel_cpufreq governor: performance volts: 0.8 V
ext-clock: 100 MHz cores: 1: 2798 2: 2855 3: 2741 4: 2622 bogomips: 19974
Type: l1tf
Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: Chicony Lenovo EasyCamera type: USB driver: uvcvideo
bus-ID: 2-1.7:4 chip-ID: 04f2:b322 class-ID: 0e02
Display: server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4")
s-diag: 485mm (19.1")
Monitor-1: LVDS1 res: 1600x900 hz: 60 dpi: 140
size: 290x170mm (11.4x6.7") diag: 336mm (13.2")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 21.3.4 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
Sound Server-1: ALSA v: k5.15.3-2-cacule running: yes
Sound Server-3: PipeWire v: 0.3.43 running: yes
Message: No device data found.
IF-ID-2: virbr1 state: down mac: <filter>
IF-ID-3: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-4: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-5: wlp0s26u1u4i2 state: up mac: <filter>
Device-1: Realtek RTL8723AU 802.11n WLAN Adapter type: USB
driver: btusb,rtl8723au bus-ID: 1-1.4:5 chip-ID: 0bda:1724 class-ID: e001
address: <filter>
Local Storage: total: 1.14 TiB used: 527.73 GiB (45.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZMTD256HAGM-000L1
size: 238.47 GiB block-size: physical: 512 B logical: 512 B sata: 3.1
speed: 3.0 Gb/s type: SSD serial: <filter> rev: 2L0Q temp: 25 C
SMART: yes state: enabled health: PASSED on: 1y 307d 18h cycles: 2084
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
model: WD My Passport 0820 drive model: WD10JMVW-11AJGS2
family: Elements / My Passport (USB, AF) size: 931.48 GiB block-size:
physical: 4096 B logical: 512 B sata: 3.0 speed: 3.0 Gb/s type: HDD
rpm: 5400 serial: <filter> drive serial: <filter> rev: 1007
drive rev: 01.01A01 temp: 36 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 260d 22h cycles: 169
used: 337.83 GiB (36.3%) fs: btrfs block-size: 4096 B dev: /dev/sdb2
maj-min: 8:18
used: 562 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sdb1
maj-min: 8:17
maj-min: 8:18
maj-min: 8:18
maj-min: 8:18
Alert: No swap data was found.
System Temperatures: cpu: 64.0 C mobo: N/A
Processes: 265 Uptime: 21h 41m wakeups: 1 Memory: 7.64 GiB
used: 3.15 GiB (41.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: 1963 pacman: 1957 lib: 495 flatpak: 6
Shell: garuda-inxi (sudo) default: Bash v: 5.1.16 running-in: alacritty
inxi: 3.3.12
Garuda:
System install date: 2021-08-19
Last full system update: 2022-01-26
Is partially upgraded: Yes
Using TLP: No
Windows dual boot: Yes
I've even tried to remove those packages first with paru -Rns but that didn't work either and I got a similar error output of unable to satisfy dependencies, etc.
Thank you!!
you folks and this distro!!! First time in a long time I've stuck with a distro THIS long....lol
