Hey everyone I am updating my system for the first time after September. I am seeing some conflicts that are causing the update failure. I tried searching the forum and I see a few more have faced similar issue. Though the suggestions there didn’t help. Hence posting it here for help.
Kernel: 6.4.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e08e8206-5d13-4e01-89e5-8f08e622ebd5 rw rootflags=subvol=@
quiet rd.udev.log_priority=3 vt.global_cursor_default=0
resume=UUID=348a3f97-571a-42b1-a086-75c438dd0c8b loglevel=3 ibt=off
Type: Portable System: Dell product: Inspiron 3543 v: A13
serial: <superuser required> Chassis: type: 8 serial: <superuser required>
Mobo: Dell model: 03YYK8 v: A00 serial: <superuser required> UEFI: Dell
v: A13 date: 09/02/2020
ID-1: BAT0 charge: 41.5 Wh (100.0%) condition: 41.5/41.6 Wh (99.8%)
volts: 16.4 min: 14.6 model: SMP-LG2.85 DELL 1C12X31 type: Unknown
serial: <filter> status: full
Info: model: Intel Core i5-5200U bits: 64 type: MT MCP arch: Broadwell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2573 high: 2700 min/max: 500/2700 scaling:
driver: intel_cpufreq governor: performance cores: 1: 2700 2: 2700 3: 2195
4: 2700 bogomips: 17558
Device-1: Intel HD Graphics 5500 vendor: Dell driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
Device-2: NVIDIA GK208BM [GeForce 920M] vendor: Dell driver: N/A
alternate: nouveau, nvidia_drm, nvidia non-free: series: 470.xx+
status: legacy-active (EOL~2023/24) arch: Kepler code: GKxxx
process: TSMC 28nm built: 2012-18 pcie: speed: Unknown lanes: 63 link-max:
gen: 6 speed: 64 GT/s bus-ID: 08:00.0 chip-ID: 10de:1299 class-ID: 0302
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.5:3
chip-ID: 0c45:670b class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: modesetting dri: iris gpu: i915
Screen-1: 0 s-res: 1280x720 s-dpi: 96 s-size: 338x190mm (13.31x7.48")
s-diag: 388mm (15.27")
Monitor-1: eDP-1 model: Samsung 0x5441 built: 2013 res: 1280x720 hz: 60
dpi: 95 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 23.1.6-arch1.4 renderer: Mesa Intel HD Graphics
5500 (BDW GT2) direct-render: Yes
Device-1: Intel Broadwell-U Audio vendor: Dell driver: snd_hda_intel
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Dell
Device-3: NVIDIA GK208 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s bus-ID: 08:00.1
chip-ID: 10de:0e0f class-ID: 0403
API: ALSA v: k6.4.12-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.79 status: active with: 1: pipewire-pulse
Device-1: Broadcom BCM43142 802.11b/g/n vendor: Dell Wireless 1704 802.11n
+ BT 4.0 driver: wl v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 06:00.0 chip-ID: 14e4:4365 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000
bus-ID: 07:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF-ID-1: enp0s29u1u3 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Broadcom BCM43142 Bluetooth 4.0 driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.6:4
chip-ID: 0a5c:21d7 class-ID: fe01 serial: <filter>
Local Storage: total: 670.7 GiB used: 545.65 GiB (81.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SQ500S37480G
tech: SSD serial: <filter> fw-rev: B1H5 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37240G
tech: SSD serial: <filter> fw-rev: 0102 scheme: GPT
ID-1: / raw-size: 150 GiB size: 150 GiB (100.00%) used: 64.52 GiB (43.0%)
fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 501 MiB size: 500 MiB (99.80%)
used: 580 KiB (0.1%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 292.64 GiB size: 292.64 GiB (100.00%)
used: 264.8 GiB (90.5%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-4: /var/log raw-size: 150 GiB size: 150 GiB (100.00%)
used: 64.52 GiB (43.0%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-5: /var/tmp raw-size: 150 GiB size: 150 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.67 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 53.0 C mobo: 50.0 C
Fan Speeds (rpm): cpu: 0
Processes: 238 Uptime: 10m wakeups: 1 Memory: total: 8 GiB
available: 7.67 GiB used: 2.75 GiB (35.8%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1802 libs: 421 tools: octopi,paru Shell: fish
v: 3.6.1 running-in: konsole inxi: 3.3.29
System install date: 2023-08-02
Last full system update: 2023-09-07
Failed units: nmb.service smb.service
Below is the terminal output of the failure
garuda is up to date
core is up to date
extra 8.2 MiB 757 KiB/s 00:11 [------------------------------------] 100%
multilib is up to date
chaotic-aur 2.6 MiB 193 KiB/s 00:14 [------------------------------------] 100%
--> Refreshing mirrorlists using reflector, please be patient..🍵
[2023-10-31 18:44:17] WARNING: failed to rate http(s) download (https://mirror.f4st.host/archlinux/extra/os/x86_64/extra.db): The read operation timed out
[2023-10-31 18:44:29] WARNING: failed to rate http(s) download (https://mirror.ufscar.br/archlinux/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2023-10-31 18:44:47] WARNING: failed to rate http(s) download (https://america.mirror.pkgbuild.com/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2023-10-31 18:44:54] WARNING: failed to rate http(s) download (https://md.mirrors.hacktegic.com/archlinux/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
:: Replace attica with extra/attica5? [Y/n] y
:: Replace baloo with extra/baloo5? [Y/n] y
:: Replace bluez-qt with extra/bluez-qt5? [Y/n] y
:: Replace exa with extra/eza? [Y/n] y
y
:: Replace frameworkintegration with extra/frameworkintegration5? [Y/n] y
:: Replace kactivities with extra/kactivities5? [Y/n] y
:: Replace kactivities-stats with extra/kactivities-stats5? [Y/n] y
:: Replace karchive with extra/karchive5? [Y/n] y
:: Replace kauth with extra/kauth5? [Y/n] y
:: Replace kbookmarks with extra/kbookmarks5? [Y/n] y
:: Replace kcalendarcore with extra/kcalendarcore5? [Y/n] y
:: Replace kcmutils with extra/kcmutils5? [Y/n] y
:: Replace kcodecs with extra/kcodecs5? [Y/n] y
:: Replace kcompletion with extra/kcompletion5? [Y/n] y
:: Replace kconfig with extra/kconfig5? [Y/n] y
:: Replace kconfigwidgets with extra/kconfigwidgets5? [Y/n] y
:: Replace kcontacts with extra/kcontacts5? [Y/n] y
:: Replace kcoreaddons with extra/kcoreaddons5? [Y/n] y
:: Replace kcrash with extra/kcrash5? [Y/n] y
:: Replace kdbusaddons with extra/kdbusaddons5? [Y/n] y
:: Replace kde-servicemenus-pdf with chaotic-aur/kf5-servicemenus-pdf? [Y/n] y
warning: kde-servicemenus-pdf-encrypt-decrypt: local (1-1.3) is newer than chaotic-aur (1-1)
:: Replace kdeclarative with extra/kdeclarative5? [Y/n] y
:: Replace kded with extra/kded5? [Y/n] y
:: Replace kdesu with extra/kdesu5? [Y/n] y
:: Replace kdnssd with extra/kdnssd5? [Y/n] y
:: Replace kdoctools with extra/kdoctools5? [Y/n] y
:: Replace kfilemetadata with extra/kfilemetadata5? [Y/n] y
:: Replace kglobalaccel with extra/kglobalaccel5? [Y/n] y
:: Replace kguiaddons with extra/kguiaddons5? [Y/n] y
:: Replace kholidays with extra/kholidays5? [Y/n] y
:: Replace ki18n with extra/ki18n5? [Y/n] y
:: Replace kiconthemes with extra/kiconthemes5? [Y/n] y
:: Replace kidletime with extra/kidletime5? [Y/n] y
:: Replace kimageformats with extra/kimageformats5? [Y/n] y
:: Replace kio with extra/kio5? [Y/n] y
:: Replace kirigami-addons with extra/kirigami-addons5? [Y/n] y
:: Replace kitemmodels with extra/kitemmodels5? [Y/n] y
:: Replace kitemviews with extra/kitemviews5? [Y/n] y
:: Replace kjobwidgets with extra/kjobwidgets5? [Y/n] y
:: Replace knewstuff with extra/knewstuff5? [Y/n] y
:: Replace knotifications with extra/knotifications5? [Y/n] y
:: Replace knotifyconfig with extra/knotifyconfig5? [Y/n] y
:: Replace kpackage with extra/kpackage5? [Y/n] y
:: Replace kparts with extra/kparts5? [Y/n] y
:: Replace kpeople with extra/kpeople5? [Y/n] y
:: Replace kpty with extra/kpty5? [Y/n] y
:: Replace kquickcharts with extra/kquickcharts5? [Y/n] y
:: Replace krunner with extra/krunner5? [Y/n] y
:: Replace kservice with extra/kservice5? [Y/n] y
:: Replace ktexteditor with extra/ktexteditor5? [Y/n] y
:: Replace ktextwidgets with extra/ktextwidgets5? [Y/n] y
:: Replace kunitconversion with extra/kunitconversion5? [Y/n] y
:: Replace kwallet with extra/kwallet5? [Y/n] y
:: Replace kwayland with extra/kwayland5? [Y/n] y
:: Replace kwidgetsaddons with extra/kwidgetsaddons5? [Y/n] y
:: Replace kwindowsystem with extra/kwindowsystem5? [Y/n] y
:: Replace kxmlgui with extra/kxmlgui5? [Y/n] y
y:: Replace libinput_gestures_qt with chaotic-aur/libinput-gestures-qt? [Y/n]
y:: Replace modemmanager-qt with extra/modemmanager-qt5? [Y/n]
:: Replace networkmanager-qt with extra/networkmanager-qt5? [Y/n] y
y:: Replace plasma-framework with extra/plasma-framework5? [Y/n]
:: Replace prison with extra/prison5? [Y/n] y
:: Replace purpose with extra/purpose5? [Y/n] y
y:: Replace qqc2-desktop-style with extra/qqc2-desktop-style5? [Y/n]
:: Replace solid with extra/solid5? [Y/n] y
:: Replace sonnet with extra/sonnet5? [Y/n] y
:: Replace sweet-kde-theme-git with chaotic-aur/plasma5-themes-sweet-kde-git? [Y/n] y
:: Replace sweet-theme-full-git with chaotic-aur/plasma5-themes-sweet-full-git? [Y/n] y
:: Replace syndication with extra/syndication5? [Y/n] y
:: Replace syntax-highlighting with extra/syntax-highlighting5? [Y/n] y
:: Replace threadweaver with extra/threadweaver5? [Y/n] y
warning: virt-manager-meta: local (5-4.2) is newer than garuda (5-4)
warning: whoogle-git: local (_r749.g92e8ede-1) is newer than chaotic-aur (0.8.3.r25.gcdf0b50-1)
yresolving dependencies...
:: removing kio breaks dependency 'kio' required by kipi-plugins
:: removing plasma-framework breaks dependency 'plasma-framework' required by latte-dock-git
:: removing knewstuff breaks dependency 'knewstuff' required by latte-dock-git
:: removing kxmlgui breaks dependency 'kxmlgui' required by libkipi
:: removing kservice breaks dependency 'kservice' required by libkipi
:: removing kauth breaks dependency 'kauth' required by samba-mounter-git
:: removing kcmutils breaks dependency 'kcmutils' required by samba-mounter-git
:: removing kconfig breaks dependency 'kconfig' required by samba-mounter-git
:: removing kio breaks dependency 'kio' required by samba-mounter-git
:: removing ki18n breaks dependency 'ki18n' required by samba-mounter-git
:: removing solid breaks dependency 'solid' required by samba-mounter-git
