Hi there, complete newbie here.
Main issue: Any update or upgrade commands result in the same issue, failing to fetch garuda.db from any mirror.
I have tried garuda-update, update, sudo pacman -Syu, and other commands to upgrade and update the system with no luck.
Below is the error:
garuda.db failed to download
core is up to date
extra is up to date
multilib is up to date
chaotic-aur is up to date
error: failed retrieving file 'garuda.db' from mirrors.qontinuum.space : The requested URL returned error: 404
error: failed retrieving file 'garuda.db' from mirror.mirohost.net : The requested URL returned error: 404
error: failed retrieving file 'garuda.db' from is.mirror.flokinet.net : The requested URL returned error: 404
error: failed retrieving file 'garuda.db' from archlinux.grena.ge : The requested URL returned error: 404
error: failed retrieving file 'garuda.db' from mirror.ditatompel.com : The requested URL returned error: 404
error: failed retrieving file 'garuda.db' from mirror.t-home.mk : The requested URL returned error: 404
error: failed retrieving file 'garuda.db' from ftp.rnl.tecnico.ulisboa.pt : The requested URL returned error: 404
error: failed retrieving file 'garuda.db' from tux.rainside.sk : The requested URL returned error: 404
error: failed retrieving file 'garuda.db' from mirrors.pidginhost.com : The requested URL returned error: 404
error: failed retrieving file 'garuda.db' from md.mirrors.hacktegic.com : The requested URL returned error: 404
error: failed retrieving file 'garuda.db' from mirror.hostart.az : The requested URL returned error: 404
error: failed retrieving file 'garuda.db' from mirror.efect.ro : The requested URL returned error: 404
error: failed retrieving file 'garuda.db' from archimonde.ts.si : The requested URL returned error: 404
error: failed retrieving file 'garuda.db' from mirror.digitalnova.at : The requested URL returned error: 404
error: failed retrieving file 'garuda.db' from archlinux.koyanet.lv : The requested URL returned error: 404
error: failed retrieving file 'garuda.db' from europe.mirror.pkgbuild.com : The requested URL returned error: 404
error: failed retrieving file 'garuda.db' from mirror.sunred.org : The requested URL returned error: 404
error: failed retrieving file 'garuda.db' from nox.panibrez.com : The requested URL returned error: 404
A bit more context:
I have not done a full system upgrade in a while.
Any idea what might be causing this?
