Hey guys, a bit new to linux and Arch in general but have some experience with Debian based systems. Everything was running smoothly on my system for about 2 days, updated some packages and whatnot and a day later I had a nap with a stream running and the system was laggy mouse barely moved, audio still played but couldn't navigate it was so bad. So I hard rebooted and everything starts out fine, but as the loading bar on the screen nears 100% the dragon stops animation and everything freezes. I tried restarting and running a memory test also tried to open with other options in advanced and same story...
Aside from plugging in the flash and running terminal what would I be looking for as to what went wrong or why it was/is acting that way??? It's mind boggling because everything was running so smoothly after I set up everything.
Thanks
Why do you not post your inxi?
You do not read the template?
Again, read
Writing a well formatted post in the forum (Discource powered) is important, if you want readers to easily read and understand.
It's especially important for terminal output.
Here is a brief tutorial.
Terminal output
For terminal output, text output with special characters, always use code wrapping (Pre-formated text).
Select all of the text and do one of these:
Hit the </> button in Discource Post Toolbar.
Press CtrlShift+C on your keyboard.
Manually with markdown
After you Copy yo…
please
and post terminal in- and output from
inxi -Fza
as text!
Even if you personally think it is unnecessary.
and
SGS:
inxi -Fza
not sure how to do that when the whole system freezes up, as I said, I’m new but I’m certain pressing anything isn’t doing anything with the system.
Try booting into / restoring a snapshot taken before your latest update and provide the information please.
Sorry guys, Forgive my ignorance, I thought I had tried all previous images. One of them worked. There is the information:
Kernel: 5.13.4-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/timeshift-btrfs/snapshots/2021-07-24_19-00-02/@/boot/vmlinuz-linux-zen
root=UUID=6e068ae4-252a-4678-a46c-8bc955e31d59 quiet splash rd.udev.log_priority=3
vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1
resume=UUID=1be79113-bac2-40b6-88bd-a7a1a209294c loglevel=3
rootflags=defaults,noatime,space_cache,autodefrag,compress=zstd,ssd,subvol=timeshift-btrfs/snapshot
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: ASRock model: X470 Gaming K4 serial: <filter>
UEFI-[Legacy]: American Megatrends v: P1.00 date: 03/27/2018
CPU: Info: 8-Core model: AMD Ryzen 7 2700 bits: 64 type: MT MCP arch: Zen+ family: 17 (23)
model-id: 8 stepping: 2 microcode: 800820D cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 102196
Speed: 2421 MHz min/max: 1550/3200 MHz boost: enabled Core speeds (MHz): 1: 2421 2: 2585
3: 3025 4: 2467 5: 2402 6: 2403 7: 3947 8: 2642 9: 2409 10: 2402 11: 2405 12: 2407 13: 2407
14: 2409 15: 2409 16: 2904
Graphics: Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: eVga.com. driver: nvidia v: 470.57.02
alternate: nouveau,nvidia_drm bus-ID: 26:00.0 chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: X.Org 1.20.12 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0
Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.9x11.9") s-diag: 610mm (24")
Monitor-1: DVI-D-0 res: 1920x1080 hz: 60 dpi: 92 size: 531x298mm (20.9x11.7") diag: 609mm (24")
OpenGL: renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 470.57.02
direct render: Yes
Audio: Device-1: NVIDIA GP106 High Definition Audio vendor: eVga.com. driver: snd_hda_intel v: kernel
bus-ID: 26:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel v: kernel
bus-ID: 28:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.13.4-zen2-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.32 running: no
Network: Device-1: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel port: f000
bus-ID: 1f:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp31s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 2.04 TiB used: 25.52 GiB (1.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G size: 223.57 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 71B1 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM006-2DM164 size: 1.82 TiB
serial: <filter> rev: CC26 scheme: MBR
Partition: ID-1: / raw-size: 206.38 GiB size: 206.38 GiB (100.00%) used: 25.52 GiB (12.4%) fs: btrfs
dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 206.38 GiB size: 206.38 GiB (100.00%) used: 25.52 GiB (12.4%) fs: btrfs
ID-3: /var/log raw-size: 206.38 GiB size: 206.38 GiB (100.00%) used: 25.52 GiB (12.4%)
fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-4: /var/tmp raw-size: 206.38 GiB size: 206.38 GiB (100.00%) used: 25.52 GiB (12.4%)
ID-1: swap-1 type: partition size: 17.19 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda2
maj-min: 8:2
ID-2: swap-2 type: zram size: 15.56 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 32.0 C mobo: N/A gpu: nvidia temp: 52 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 7%
Info: Processes: 360 Uptime: 1m wakeups: 0 Memory: 15.56 GiB used: 1.72 GiB (11.1%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1620 lib: 489 Shell: fish
v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
If you include terminal outputs in your post please use the proper output format in your post. Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look.
now currently restarted after using timeshift to recover an old image and I don't have permission to open certain programs
Please open terminal and start the certain programs in terminal and post in and output from terminal as text, please.
Can you please post the output of
sudo btrfs filesystem usage /
sysctl vm.swappiness
sysctl vm.vfs_cache_pressure
You would also need to monitor your system temps when you experience stutter because higher temps could de-crease performance.
VFS cache and Swappiness - FAQ and Tutorials - Garuda Linux Forum
I apologize i am getting careless.
