Hello, I've been using Garuda Linux for quite some time as my main os, but one issue keeps bothering me.
When I open something(program, new directory in doplhin), receive desktop notification my system stutters. My mouse, audio and video lags for a short period of time, and it is very noticeable and annoying. Especially the mouse lag.
It most likely something related to drivers, Xorg or plasma, though it causes such overhead that even the audio lags. But later I had found out that the problem is most likely in xorg.
What I tried:
Nvidia related xorg configuration, running nvidia-xconfiguration, enabling triple buffering, usleep
Messing with compositor settings, forcing and disabling vsync.
But there's a very intersting clue that I've found that probably causes that issue.
When run kwin_x11 --replace from console and I simulate any event that causes stutter it prints these errors:
When I receive a notification(run notify-send 123123)
qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 7654, resource id: 44040535, major code: 14 (GetGeometry), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 7655, resource id: 44040537, major code: 14 (GetGeometry), minor code: 0
When I switch directory to a previously unopened directory dolphin:
kwin_core: XCB error: 152 (BadDamage), sequence: 4540, resource id: 8388812, major code: 143 (DAMAGE), minor c
ode: 2 (Destroy)
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 10924, resource id: 69206024, major code: 18 (
ChangeProperty), minor code: 0
kwin_core: XCB error: 152 (BadDamage), sequence: 18979, resource id: 8389629, major code: 143 (DAMAGE), minor
code: 2 (Destroy)
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 21325, resource id: 69206024, major code: 18 (
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32099, resource id: 69206024, major code: 18 (
When I open application manager:
qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 58030, resource id: 44040571, major code: 14
qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 58032, resource id: 44040573, major code: 14
qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 58033, resource id: 44040575, major code: 14
qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 58034, resource id: 44040577, major code: 14
qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 58035, resource id: 44040579, major code: 14
qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 58036, resource id: 44040581, major code: 14
qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 58037, resource id: 44040583, major code: 14
qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 58038, resource id: 44040569, major code: 14
qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 58039, resource id: 44040571, major code: 14
These are not the only errors that kwin_x11 prints, I included full log in privatebin.
I think it's something qt related, I tried searching these errors, but no success.
But that must be the problem.
To note I did use any themes or anything apart from what comes preinstalled with garuda dragonized. I only tweaked x11 to show titlebar with menu and using standard taskbar dock which is included in latte.
Full log:
System: Kernel: 5.14.9-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=85c6b4f2-2c87-4216-916b-e06ea2ae41e5
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: ASUSTeK model: B150M-PLUS v: Rev X.0x serial: <filter>
UEFI-[Legacy]: American Megatrends v: 2003 date: 09/21/2016
Battery: ID-1: hidpp_battery_1 charge: N/A condition: N/A volts: 4.1 min: N/A
model: Logitech G703 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A serial: <filter>
status: Discharging
CPU: Info: Quad Core model: Intel Core i7-7700 bits: 64 type: MT MCP arch: Kaby Lake family: 6
model-id: 9E (158) stepping: 9 microcode: EA cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 57600
Speed: 4103 MHz min/max: 800/4200 MHz Core speeds (MHz): 1: 4103 2: 4098 3: 4105 4: 4198
5: 4104 6: 4191 7: 4101 8: 4182
Graphics: Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: Micro-Star MSI driver: nvidia v: 470.74
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1b81 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0
Screen-1: 0 s-res: 1920x1080 s-dpi: 95 s-size: 513x292mm (20.2x11.5") s-diag: 590mm (23.2")
Monitor-1: DVI-D-0 res: 1920x1080 hz: 60 dpi: 96 size: 510x290mm (20.1x11.4")
diag: 587mm (23.1")
OpenGL: renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 470.74 direct render: Yes
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-3: Generalplus USB Audio Device type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-7:5 chip-ID: 1b3f:2008 class-ID: 0300
Sound Server-1: ALSA v: k5.14.9-zen2-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel port: f000
bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Microsoft Xbox 360 Wireless Adapter type: USB driver: xpad bus-ID: 1-5:4
chip-ID: 045e:0719 class-ID: ff00 serial: <filter>
Drives: Local Storage: total: 1.02 TiB used: 102 GiB (9.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: GOODRAM model: N/A size: 111.79 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 10.6 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB
serial: <filter> rev: CC43 scheme: GPT
Partition: ID-1: / raw-size: 239.99 GiB size: 239.99 GiB (100.00%) used: 102 GiB (42.5%) fs: btrfs
dev: /dev/sdb4 maj-min: 8:20
ID-2: /home raw-size: 239.99 GiB size: 239.99 GiB (100.00%) used: 102 GiB (42.5%) fs: btrfs
ID-3: /var/log raw-size: 239.99 GiB size: 239.99 GiB (100.00%) used: 102 GiB (42.5%) fs: btrfs
ID-4: /var/tmp raw-size: 239.99 GiB size: 239.99 GiB (100.00%) used: 102 GiB (42.5%) fs: btrfs
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 51 C
Info: Processes: 244 Uptime: 22m wakeups: 4 Memory: 15.55 GiB used: 2.59 GiB (16.7%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 alt: 10 clang: 12.0.1 Packages: pacman: 1602
lib: 493 Shell: fish v: 3.3.1 running-in: konsole inxi: 3.3.06
