Hello Hyprland folks!
garuda-inxi output:
Kernel: 6.1.57-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=2ca7896b-1e0c-44ec-be37-a1ae812054db rw rootflags=subvol=@
quiet rd.luks.uuid=3fc75493-6430-4d8d-bf8e-8db65f497ecc loglevel=3
Type: Desktop System: Dell product: OptiPlex 5050 v: N/A
Mobo: Dell model: N/A serial: <superuser required> UEFI: Dell v: 1.26.0
date: 08/20/2023
Device-1: hidpp_battery_0 model: Logitech ERGO M575 Trackball
serial: <filter> charge: 100% rechargeable: yes status: discharging
Info: model: Intel Core i7-6700 bits: 64 type: MT MCP arch: Skylake-S
model-id: 0x5E (94) stepping: 3 microcode: 0xF2
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 837 high: 900 min/max: 800/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 900
5: 800 6: 900 7: 800 8: 898 bogomips: 54417
Device-1: Intel HD Graphics 530 vendor: Dell driver: i915 v: kernel
arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: DP-2
empty: DP-1, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:1912 class-ID: 0380
Device-2: AMD Oland [Radeon HD 8570 / R5 430 OEM R7 240/340 Radeon 520
OEM] vendor: Dell driver: radeon v: kernel alternate: amdgpu arch: GCN-1
code: Southern Islands process: TSMC 28nm built: 2011-20 pcie: gen: 3
speed: 8 GT/s lanes: 8 ports: active: DP-4 empty: DVI-I-1 bus-ID: 01:00.0
chip-ID: 1002:6611 class-ID: 0300 temp: 51.0 C
compositor: Hyprland driver: X: loaded: modesetting,radeon
alternate: fbdev,intel,vesa dri: radeonsi,iris gpu: i915,radeon
d-rect: 6400x2160 display-ID: 1
Monitor-1: DP-2 pos: primary,left model: Sceptre Q24 serial: <filter>
built: 2020 res: 2560x1440 hz: 60 dpi: 123 gamma: 1.2 scale: 1
size: 708x398mm (27.87x15.67") diag: 604mm (23.8") ratio: 16:9 modes:
max: 2560x1440 min: 720x400
Monitor-2: DP-4 pos: right model: BenQ EL2870U serial: <filter>
built: 2021 res: 3840x2160 hz: 60 dpi: 157 gamma: 1.2 scale: 1.5
size: 621x341mm (24.45x13.43") diag: 708mm (27.9") ratio: 16:9 modes:
max: 3840x2160 min: 720x400
API: Vulkan v: 1.3.264 layers: 4 device: 0 type: integrated-gpu name: Intel
HD Graphics 530 (SKL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:1912 surfaces: xcb,xlib,wayland device: 1 type: cpu
Device-1: Intel 200 Series PCH HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0 class-ID: 0403
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series] vendor: Dell driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 1002:aab0 class-ID: 0403
API: ALSA v: k6.1.57-1-lts status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.82 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d6 class-ID: 0200
Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:3 chip-ID: 0b05:190e
Local Storage: total: 3.34 TiB used: 427.71 GiB (12.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P5PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P7CR403 temp: 49.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: TeamGroup model: T2531TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 986 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: TeamGroup model: T2531TB
tech: SSD serial: <filter> fw-rev: 6B0 scheme: GPT
model: WDBRPG5000ANC-WRSN size: 465.76 GiB block-size: physical: 512 B
logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0
tech: N/A serial: <filter> fw-rev: 1.00 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: SanDisk model: USB 3.2Gen1
size: 114.61 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
used: 25.86 GiB (2.8%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-3fc75493-6430-4d8d-bf8e-8db65f497ecc
ID-3: /home raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
ID-4: /var/log raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
ID-5: /var/tmp raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
ID-1: swap-1 type: zram size: 23.35 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 34.0 C mobo: N/A gpu: radeon temp: 51.0 C
Processes: 243 Uptime: 8h 51m wakeups: 21 Memory: total: 24 GiB
available: 23.35 GiB used: 2.32 GiB (9.9%) Init: systemd v: 254
pm: pacman pkgs: 1340 libs: 374 tools: paru Shell: fish v: 3.6.1
running-in: kitty inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-10-15
Last full system update: 2023-10-15
I’ve had an ongoing issue that I encountered during a fresh install of Arch a month or two ago, and now seeing on Garuda. I’m not sure it is a Hyprland issue, as I saw it on Arch with both Hyprland and Sway. And a few weeks ago with the Garuda Sway version.
Issue: I can barely use a web browser. Firefox/FireDragon lags, everything on it has a slight delay or hesitation. Scrolling, videos, even moving the mouse. Menus open slowly. Frames are being dropped on YouTube videos, I’m guessing I’m not getting better than 15 fps.
The CPU at this moment is barely doing any work, 7%. Memory is 10% out of 24 GB. So no load on the system.
Even some actions in the terminal are slow. I’m comparing this to a Debian install I tried a few weeks ago with Sway as well as Fedora/KDE that I had installed for several months.
I’m using the latest Hyprland iso, installed this weekend. I’ve installed some software after install, but not much. I’ve installed Garuda hyprland on nvme drive with nothing else installed on that disk. No dual boot windows.
As you’ll see in the inxi output, I’m running the LTS kernel at the moment. I thought that might possibly help. No, it doesn’t. Same problem on Zen kernel.
Any thoughts? Is my 5 year old Dell just not up to the task? Any suggestions would be great. Thanks.
