Idk what causes it. I've reinstalled Garuda a couple of times and nothing works.
First i get "Wifi is deactivated" notification, and when i check it there's no wifi visible.
Seconds after, system freezes. I can freely move my mouse but Garuda does not respond when i click with it, nor with keyboard keys. So i left with no option but force power off via button.
inxi
Kernel: 6.3.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=4a4a8e3d-8cd2-4db5-aa34-26dce159b169 rw rootflags=subvol=@
resume=UUID=70b14570-2440-4dd5-891d-0f465e32b535 loglevel=3 ibt=off
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming F15 FX506LI_FX506LI
Mobo: ASUSTeK model: FX506LI v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: FX506LI.310 date: 11/26/2021
ID-1: BAT1 charge: 40.2 Wh (97.3%) condition: 41.3/48.2 Wh (85.6%)
volts: 12.6 min: 11.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: not charging
Info: model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xF6
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1673 high: 2500 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 831 2: 2500 3: 879 4: 878
5: 2500 6: 800 7: 2500 8: 2500 bogomips: 39999
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: ASUSTeK driver: i915
active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: ASUSTeK
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f95 class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:4 chip-ID: 13d3:56a2
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1521 built: 2020 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.2 renderer: Mesa Intel UHD Graphics (CML GT2)
direct-render: Yes
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
Device-3: C-Media USB Audio Device
lanes: 1 mode: 1.1 bus-ID: 1-2:3 chip-ID: 0d8c:0012 class-ID: 0300
API: ALSA v: k6.3.7-zen1-1-zen status: kernel-api tools: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
Local Storage: total: 476.94 GiB used: 15.26 GiB (3.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2210 MTFDHBA512QFD
lanes: 4 tech: SSD serial: <filter> fw-rev: P6MA001 temp: 41.9 C
used: 15.26 GiB (3.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 7.6 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 58.0 C pch: 59.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 272 Uptime: 3m wakeups: 1 Memory: available: 7.6 GiB
used: 2.83 GiB (37.2%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1355
libs: 388 tools: octopi,pamac,paru Shell: fish v: 3.6.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.27
System install date: 2023-06-12
Last full system update: 2023-06-12
journalctl -b -k
İyn 12 22:54:51 aingrace kernel: input: ELAN1203:00 04F3:307A Touchpad as /devices/pci0000:00/0000:00:15.0/i2>
İyn 12 22:54:51 aingrace kernel: hid-generic 0018:04F3:307A.0003: input,hidraw2: I2C HID v1.00 Mouse [ELAN120>
İyn 12 22:54:51 aingrace kernel: RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
İyn 12 22:54:51 aingrace kernel: RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
İyn 12 22:54:51 aingrace kernel: RAPL PMU: hw unit of domain package 2^-14 Joules
İyn 12 22:54:51 aingrace kernel: RAPL PMU: hw unit of domain dram 2^-14 Joules
İyn 12 22:54:51 aingrace kernel: RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
İyn 12 22:54:51 aingrace kernel: RAPL PMU: hw unit of domain psys 2^-14 Joules
İyn 12 22:54:51 aingrace kernel: iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
İyn 12 22:54:51 aingrace kernel: asus_wmi: ASUS WMI generic driver loaded
İyn 12 22:54:51 aingrace kernel: iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
İyn 12 22:54:51 aingrace kernel: spi-nor spi0.0: w25q128 (16384 Kbytes)
İyn 12 22:54:51 aingrace kernel: asus_wmi: Initialization: 0x1
İyn 12 22:54:51 aingrace kernel: asus_wmi: BIOS WMI version: 8.1
İyn 12 22:54:51 aingrace kernel: asus_wmi: SFUN value: 0x4a0061
İyn 12 22:54:51 aingrace kernel: asus-nb-wmi asus-nb-wmi: Detected ATK, not ASUSWMI, use DSTS
İyn 12 22:54:51 aingrace kernel: asus-nb-wmi asus-nb-wmi: Detected ATK, enable event queue
İyn 12 22:54:51 aingrace kernel: proc_thermal 0000:00:04.0: enabling device (0000 -> 0002)
İyn 12 22:54:51 aingrace kernel: asus-nb-wmi asus-nb-wmi: Using throttle_thermal_policy for platform_profile >
İyn 12 22:54:51 aingrace kernel: intel_rapl_common: Found RAPL domain package
İyn 12 22:54:51 aingrace kernel: intel_rapl_common: Found RAPL domain dram
İyn 12 22:54:51 aingrace kernel: input: Asus WMI hotkeys as /devices/platform/asus-nb-wmi/input/input12
İyn 12 22:54:51 aingrace kernel: Creating 1 MTD partitions on "0000:00:1f.5":
İyn 12 22:54:51 aingrace kernel: 0x000000000000-0x000001000000 : "BIOS"
İyn 12 22:54:51 aingrace kernel: r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
İyn 12 22:54:51 aingrace kernel: r8169 0000:03:00.0 eth0: RTL8168h/8111h, f0:2f:74:9f:61:84, XID 541, IRQ 148
İyn 12 22:54:51 aingrace kernel: r8169 0000:03:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
İyn 12 22:54:51 aingrace kernel: r8169 0000:03:00.0 enp3s0: renamed from eth0
İyn 12 22:54:51 aingrace kernel: usbcore: registered new interface driver btusb
İyn 12 22:54:51 aingrace kernel: Bluetooth: hci0: Bootloader revision 0.4 build 0 week 30 2018
İyn 12 22:54:51 aingrace kernel: Bluetooth: hci0: Device revision is 2
İyn 12 22:54:51 aingrace kernel: Bluetooth: hci0: Secure boot is enabled
İyn 12 22:54:51 aingrace kernel: Bluetooth: hci0: OTP lock is enabled
İyn 12 22:54:51 aingrace kernel: Bluetooth: hci0: API lock is enabled
İyn 12 22:54:51 aingrace kernel: Bluetooth: hci0: Debug lock is disabled
İyn 12 22:54:51 aingrace kernel: Bluetooth: hci0: Minimum firmware build 1 week 10 2014
İyn 12 22:54:51 aingrace kernel: asus_wmi: fan_curve_get_factory_default (0x00110024) failed: -19
İyn 12 22:54:51 aingrace kernel: asus_wmi: fan_curve_get_factory_default (0x00110025) failed: -19
İyn 12 22:54:51 aingrace kernel: ACPI: battery: new extension: ASUS Battery Extension
İyn 12 22:54:51 aingrace kernel: iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x351
İyn 12 22:54:51 aingrace kernel: thermal thermal_zone7: failed to read out thermal zone (-61)
İyn 12 22:54:51 aingrace kernel: usb 1-7: Found UVC 1.00 device USB2.0 HD UVC WebCam (13d3:56a2)
İyn 12 22:54:51 aingrace kernel: Bluetooth: hci0: Found device firmware: intel/ibt-19-0-4.sfi
İyn 12 22:54:51 aingrace kernel: Bluetooth: hci0: Boot Address: 0x24800
İyn 12 22:54:51 aingrace kernel: Bluetooth: hci0: Firmware Version: 15-45.22
İyn 12 22:54:51 aingrace kernel: usbcore: registered new interface driver uvcvideo
İyn 12 22:54:51 aingrace kernel: usbcore: registered new interface driver snd-usb-audio
İyn 12 22:54:51 aingrace kernel: input: ELAN1203:00 04F3:307A Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-6/i2c-ELAN1203:00/0018:04F3:307A.0003/input/input13
İyn 12 22:54:51 aingrace kernel: input: ELAN1203:00 04F3:307A Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-6/i2c-ELAN1203:00/0018:04F3:307A.0003/input/input14
İyn 12 22:54:51 aingrace kernel: hid-multitouch 0018:04F3:307A.0003: input,hidraw2: I2C HID v1.00 Mouse [ELAN1203:00 04F3:307A] on i2c-ELAN1203:00
İyn 12 22:54:51 aingrace kernel: snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
İyn 12 22:54:51 aingrace kernel: snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
İyn 12 22:54:51 aingrace kernel: snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
İyn 12 22:54:51 aingrace kernel: intel_tcc_cooling: Programmable TCC Offset detected
İyn 12 22:54:51 aingrace kernel: snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC256: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
İyn 12 22:54:51 aingrace kernel: snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
İyn 12 22:54:51 aingrace kernel: snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
İyn 12 22:54:51 aingrace kernel: snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
İyn 12 22:54:51 aingrace kernel: snd_hda_codec_realtek hdaudioC1D0: inputs:
İyn 12 22:54:51 aingrace kernel: snd_hda_codec_realtek hdaudioC1D0: Headset Mic=0x19
İyn 12 22:54:51 aingrace kernel: snd_hda_codec_realtek hdaudioC1D0: Internal Mic=0x12
İyn 12 22:54:51 aingrace kernel: input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card1/input15
İyn 12 22:54:51 aingrace kernel: input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card1/input16
İyn 12 22:54:51 aingrace kernel: input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card1/input17
İyn 12 22:54:51 aingrace kernel: input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card1/input18
İyn 12 22:54:51 aingrace kernel: iwlwifi 0000:00:14.3: Detected RF HR B3, rfid=0x10a100
İyn 12 22:54:51 aingrace kernel: iwlwifi 0000:00:14.3: base HW address: 8c:55:4a:37:ef:a1
İyn 12 22:54:51 aingrace kernel: iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
İyn 12 22:54:51 aingrace kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
İyn 12 22:54:51 aingrace kernel: Bluetooth: BNEP filters: protocol multicast
İyn 12 22:54:51 aingrace kernel: Bluetooth: BNEP socket layer initialized
İyn 12 22:54:51 aingrace kernel: NET: Registered PF_QIPCRTR protocol family
İyn 12 22:54:51 aingrace kernel: Generic FE-GE Realtek PHY r8169-0-300:00: attached PHY driver (mii_bus:phy_addr=r8169-0-300:00, irq=MAC)
İyn 12 22:54:51 aingrace kernel: r8169 0000:03:00.0 enp3s0: Link is Down
İyn 12 22:54:52 aingrace kernel: snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
İyn 12 22:54:52 aingrace kernel: snd_hda_intel 0000:01:00.1: Disabling MSI
İyn 12 22:54:52 aingrace kernel: snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
İyn 12 22:54:52 aingrace kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input19
İyn 12 22:54:52 aingrace kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input20
İyn 12 22:54:52 aingrace kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input21
İyn 12 22:54:52 aingrace kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input22
İyn 12 22:54:52 aingrace kernel: ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20221020/nsarguments-61)
İyn 12 22:54:53 aingrace kernel: Bluetooth: hci0: Waiting for firmware download to complete
İyn 12 22:54:53 aingrace kernel: Bluetooth: hci0: Firmware loaded in 1583200 usecs
İyn 12 22:54:53 aingrace kernel: Bluetooth: hci0: Waiting for device to boot
İyn 12 22:54:53 aingrace kernel: Bluetooth: hci0: Device booted in 13684 usecs
İyn 12 22:54:53 aingrace kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
İyn 12 22:54:53 aingrace kernel: Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-19-0-4.ddc
İyn 12 22:54:53 aingrace kernel: Bluetooth: hci0: Applying Intel DDC parameters completed
İyn 12 22:54:53 aingrace kernel: Bluetooth: hci0: Firmware revision 0.4 build 15 week 45 2022
İyn 12 22:54:53 aingrace kernel: Bluetooth: MGMT ver 1.22
İyn 12 22:54:53 aingrace kernel: NET: Registered PF_ALG protocol family
İyn 12 22:54:53 aingrace kernel: ucsi_acpi USBC000:00: PPM init failed (-110)
İyn 12 22:55:02 aingrace systemd-journald[396]: File /var/log/journal/7a0ca0a790f049358f07d565cb2427a0/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
İyn 12 22:55:04 aingrace kernel: warning: `kded5' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
İyn 12 22:55:05 aingrace kernel: wlo1: authenticate with a4:81:7a:25:e1:69
İyn 12 22:55:05 aingrace kernel: wlo1: 80 MHz not supported, disabling VHT
İyn 12 22:55:05 aingrace kernel: wlo1: send auth to a4:81:7a:25:e1:69 (try 1/3)
İyn 12 22:55:05 aingrace kernel: Bluetooth: RFCOMM TTY layer initialized
İyn 12 22:55:05 aingrace kernel: Bluetooth: RFCOMM socket layer initialized
İyn 12 22:55:05 aingrace kernel: Bluetooth: RFCOMM ver 1.11
İyn 12 22:55:05 aingrace kernel: wlo1: authenticated
İyn 12 22:55:05 aingrace kernel: wlo1: associate with a4:81:7a:25:e1:69 (try 1/3)
İyn 12 22:55:05 aingrace kernel: wlo1: RX AssocResp from a4:81:7a:25:e1:69 (capab=0x1411 status=0 aid=3)
İyn 12 22:55:05 aingrace kernel: wlo1: associated
İyn 12 22:55:05 aingrace kernel: wlo1: Limiting TX power to 20 (20 - 0) dBm as advertised by a4:81:7a:25:e1:69
İyn 12 22:55:05 aingrace kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
İyn 12 22:55:36 aingrace kernel: BTRFS info: devid 1 device path /dev/nvme0n1p2 changed to /dev/disk/by-uuid/4a4a8e3d-8cd2-4db5-aa34-26dce159b169 scanned by Thread (pooled) (2887)
lspci
00:00.0 Host bridge: Intel Corporation 10th Gen Core Processor Host Bridge/DRAM Registers (rev 02)
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 02)
00:02.0 VGA compatible controller: Intel Corporation CometLake-H GT2 [UHD Graphics] (rev 05)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Ther
mal Subsystem (rev 02)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor
Gaussian Mixture Model
00:12.0 Signal processing controller: Intel Corporation Comet Lake PCH Thermal Controller
00:14.0 USB controller: Intel Corporation Comet Lake USB 3.1 xHCI Host Controller
00:14.2 RAM memory: Intel Corporation Comet Lake PCH Shared SRAM
00:14.3 Network controller: Intel Corporation Comet Lake PCH CNVi WiFi
00:15.0 Serial bus controller: Intel Corporation Comet Lake PCH Serial IO I2C Controller #0
00:16.0 Communication controller: Intel Corporation Comet Lake HECI Controller
00:17.0 SATA controller: Intel Corporation Device 06d3
00:1d.0 PCI bridge: Intel Corporation Comet Lake PCI Express Root Port #9 (rev f0)
00:1d.6 PCI bridge: Intel Corporation Device 06b6 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Comet Lake LPC Controller
00:1f.3 Audio device: Intel Corporation Comet Lake PCH cAVS
00:1f.4 SMBus: Intel Corporation Comet Lake PCH SMBus Controller
00:1f.5 Serial bus controller: Intel Corporation Comet Lake PCH SPI Controller
01:00.0 VGA compatible controller: NVIDIA Corporation TU117M [GeForce GTX 1650 Ti Mobile] (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 10fa (rev a1)
02:00.0 Non-Volatile memory controller: Micron Technology Inc Device 5404 (rev 03)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Co
ntroller (rev 15)
Same issue with Fedora and Manjaro. I really don't knoow what's the issue ![]()
Thanks.
