Hello, today I updated my system and while shutting down, I noticed a strange error like “No EFI device found”. Then when I rebooted, the grub entry for Garuda Linux was gone. I made a Garuda USB and booted into a live session, then restored the snapshot from before the update, but the grub entry was still missing. Now, I do have a very peculiar system setup, so let me explain.
My /boot and /home directories are located on a 500GB SATA SSD, while my root partition and everything else is on a 1TB NVME SSD installed using a PCIe adapter. This setup is necessary because my motherboard is too old to natively support booting from NVME drives, but from what I understand, GRUB can load the necessary drivers to interface with the drive and load the operating system from it. I assume that the latest update messed up my GRUB config somehow, and perhaps my /boot directory is excluded from snapshots since it’s on another partition/device which would explain why restoring a snapshot didn’t fix it.
I’m currently in a live session using a USB with a Garuda ISO on it. The NVME drive is listed in the partition manager, so it’s likely still functional. My SATA drive shows up too, and I can mount the drive and browse the GRUB configuration files, but I’m not sure what to do. I searched for other related topics, and one suggested to use the Garuda Boot Options tool, but the “Boot to” dropdown doesn’t list any options. Another suggestion was to use the Garuda Boot Repair tool, but I’m hesitant to take any course of action that might break my configuration further.
In my two years of using Garuda (exactly two years, funny enough… this issue happened almost down to the hour of the day I installed it) I’ve never had any serious issues like this. Any advice would be appreciated, and I’d be happy to provide any additional information. Here is the output of garuda-inxi below:
Kernel: 5.19.7-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
misobasedir=garuda misolabel=GARUDA_DR460NIZEDGAMING_TALON quiet
systemd.show_status=1 driver=nonfree nouveau.modeset=0 i915.modeset=1
radeon.modeset=1
Type: Desktop Mobo: ASUSTeK model: P6T SE v: Rev 1.xx
serial: <superuser required> BIOS: American Megatrends v: 0908
date: 09/21/2010
Info: model: Intel Core i7 920 bits: 64 type: MT MCP arch: Nehalem
gen: core 1 built: 2008-10 process: Intel 45nm family: 6
model-id: 0x1A (26) stepping: 5 microcode: 0x1D
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1906 high: 2668 min/max: 1600/2668 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1604 2: 2668
3: 1604 4: 1602 5: 1899 6: 1604 7: 1605 8: 2668 bogomips: 42763
vulnerable
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
vendor: Gigabyte driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: DP-2,DP-3
empty: DP-1,HDMI-A-1 bus-ID: 02:00.0 chip-ID: 1002:67df class-ID: 0300
s-diag: 1055mm (41.54")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,left
model: Acer XF243Y serial: <filter> built: 2021 res: 1920x1080 hz: 60
dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 604mm (23.8")
Monitor-2: DP-3 mapped: DisplayPort-2 pos: right model: Acer XF243Y P
serial: <filter> built: 2021 res: 1920x1080 hz: 144 dpi: 93 gamma: 1.2
OpenGL: renderer: AMD Radeon RX 580 Series (polaris10 LLVM 14.0.6 DRM
3.47 5.19.7-zen2-1-zen) v: 4.6 Mesa 22.1.7 direct render: Yes
Device-1: Intel 82801JI HD Audio vendor: ASUSTeK driver: snd_hda_intel
bus-ID: 7-1:2 v: kernel bus-ID: 00:1b.0 chip-ID: 0951:16a4
chip-ID: 8086:3a3e class-ID: 0300 serial: <filter> class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 02:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-3: Kingston HyperX 7.1 Audio type: USB
Sound Server-1: ALSA v: k5.19.7-zen2-1-zen running: yes
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e800
bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.31 TiB used: 0 KiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Addlink model: M.2 PCIE G3x4
NVMe size: 953.87 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: ECFM32.1
temp: 27.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
speed: 1.5 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC43
scheme: MBR
model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: SSD serial: <filter> rev: 20WD
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk
model: Cruzer Force size: 14.32 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 1.00
scheme: MBR
ID-1: swap-1 type: zram size: 11.68 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 36.5 C mobo: 37.0 C gpu: amdgpu temp: 51.0 C
Fan Speeds (RPM): cpu: 1795 psu: 0 case-1: 1328 case-2: 803 gpu: amdgpu
fan: 770
Power: 12v: 12.14 5v: N/A 3.3v: 3.30 vbat: N/A gpu: amdgpu watts: 30.08
Processes: 244 Uptime: 39m wakeups: 0 Memory: 11.68 GiB used: 3.2 GiB
(27.4%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pacman: 1837 lib: 515 Shell: fish v: 3.5.1
Garuda (2.6.7-1):
System install date: 2023-09-22
Last full system update: 2023-09-22 ↻
