Hello dear Garuda Users,
i recently stumbeld over a line in the output of garuda-update that read:
IO Error (.snapshots is not a btrfs subvolume).
After a bit of digging i found out that i seem to still be booted into the snapshot i tried to restore about half a year ago. While trying to resolve this issue i only created more and more snapshots inside the snapshot but could not restore the system to not boot a snapshot.
â•─jarnek@jarnek in ~ as đź§™ took 2s
╰─λ sudo garuda-inxi
Kernel: 6.5.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/restore_backup_@_202859658/boot/vmlinuz-linux-zen
root=UUID=1b45e05e-bac7-4f7b-940e-4f41c6374d09 rw
rootflags=subvol=restore_backup_@_202859658 quiet quiet
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 dm: SDDM
Type: Desktop Mobo: Micro-Star model: MAG X570S TORPEDO MAX (MS-7D54) v: 1.0
serial: <filter> UEFI: American Megatrends LLC. v: A.00 date: 07/09/2021
Info: model: AMD Ryzen 7 5800X socket: AM4 bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4275 min/max: 2200/5456 boost: enabled
base/boost: 4275/4850 scaling: driver: acpi-cpufreq governor: performance
volts: 1.1 V ext-clock: 100 MHz cores: 1: 4275 2: 4275 3: 4275 4: 4275
5: 4275 6: 4275 7: 4275 8: 4275 9: 4275 10: 4275 11: 4275 12: 4275
13: 4275 14: 4275 15: 4275 16: 4275 bogomips: 136803
Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti] driver: nvidia v: 535.113.01
alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-23 pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 2d:00.0 chip-ID: 10de:2486 class-ID: 0300
Display: server: X.Org v: 21.1.8 with: Xwayland v: 23.2.1
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
Screen-1: 0 s-res: 3840x1080 s-dpi: 81 s-size: 1204x343mm (47.40x13.50")
s-diag: 1252mm (49.29")
Monitor-1: Unknown-1 mapped: DP-2 res: 3840x1080 hz: 144 dpi: 82
size: 1196x336mm (47.09x13.23") modes: 3840x1080
API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.113.01 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.264 layers: 4 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Ti driver: nvidia v: 535.113.01 device-ID: 10de:2486
surfaces: xcb,xlib
Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2d:00.1 chip-ID: 10de:228b
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Corsair VIRTUOSO Wireless Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 1b1c:0a42 class-ID: 0300
Device-4: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:2
chip-ID: 0db0:a073 class-ID: 0300
API: ALSA v: k6.5.5-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.80 status: n/a (root, process) with:
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 26:00.0
IF: enp38s0 state: down mac: <filter>
lanes: 1 port: d000 bus-ID: 28:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-3: Qualcomm Atheros AR9271 802.11n driver: ath9k_htc type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-3:3 chip-ID: 0cf3:9271
class-ID: ff00 serial: <filter>
IF: wlp47s0f3u3 state: up mac: <filter>
Device-4: Realtek RTL8812AU 802.11a/b/g/n/ac 2T2R DB WLAN Adapter
driver: rtl88XXau type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 5-4:5 chip-ID: 0bda:8812 class-ID: 0000 serial: <filter>
IF: wlp47s0f3u4 state: up mac: <filter>
IF-ID-1: br-39e90abfd8e6 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-2: br-7d937e02dbd4 state: down mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
IF-ID-4: veth8352a74 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-5: vethd33b60b state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-6: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-7: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Local Storage: total: 3.87 TiB used: 855.36 GiB (21.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD BLACK
SN850X HS 1000GB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 620281WD temp: 33.9 C scheme: GPT
SMART: yes health: PASSED on: 71d 7h cycles: 479
read-units: 74,559,631 [38.1 TB] written-units: 42,350,419 [21.6 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 1000GB
family: Marvell based SSDs size: 931.52 GiB block-size: physical: 512 B
logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 00RL temp: 24 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 217d 15h cycles: 1219
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000LM048-2E7172
family: Barracuda 2.5 5400 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 5400
serial: <filter> fw-rev: SDM1 temp: 25 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 368d 9h cycles: 2330
read: 18.86 TiB written: 17.92 TiB Pre-Fail: attribute: Spin_Retry_Count
ID-4: /dev/sdc maj-min: 8:32 vendor: Intenso model: SSD Sata III
size: 236 GiB block-size: physical: 512 B logical: 512 B sata: 3.1
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 3B temp: 29 C
SMART: yes state: enabled health: PASSED on: 236d 13h cycles: 3157
read: 347.8 MiB written: 395.4 MiB
ID-5: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST1000LM048-2E7172
serial: <filter> fw-rev: SDM1 temp: 26 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 367d 2h cycles: 2327
read: 2.87 TiB written: 3.95 TiB Pre-Fail: attribute: Spin_Retry_Count
ID-1: / raw-size: 931.01 GiB size: 931.01 GiB (100.00%)
used: 855.36 GiB (91.9%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 576 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 931.01 GiB size: 931.01 GiB (100.00%)
maj-min: 259:2
ID-4: /var/log raw-size: 931.01 GiB size: 931.01 GiB (100.00%)
maj-min: 259:2
ID-5: /var/tmp raw-size: 931.01 GiB size: 931.01 GiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: zram size: 31.27 GiB used: 20.2 MiB (0.1%)
System Temperatures: cpu: 34.8 C mobo: N/A gpu: nvidia temp: 44 C
Processes: 440 Uptime: 15m wakeups: 0 Memory: total: 32 GiB
available: 31.27 GiB used: 6.21 GiB (19.9%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 12
clang: 16.0.6 Packages: pm: pacman pkgs: 2534 libs: 493
tools: octopi,paru,yay pm: flatpak pkgs: 0 Shell: garuda-inxi (sudo)
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
System install date: 2023-08-04
Last full system update: 2023-10-01
Windows dual boot: Yes
Failed units: nvidia-powerd.service
â•─jarnek@jarnek in ~ as ď§™ took 2m30s
╰─λ sudo btrfs sub list /
ID 256 gen 179125 top level 5 path restore_backup_restore_backup_@_202859658_213948730_backup_2023240720365717
9
ID 257 gen 179141 top level 5 path @home
ID 258 gen 179125 top level 5 path @root
ID 259 gen 125975 top level 5 path @srv
ID 260 gen 179138 top level 5 path @cache
ID 261 gen 179141 top level 5 path @log
ID 262 gen 179139 top level 5 path @tmp
ID 263 gen 179125 top level 283 path restore_backup_restore_backup_restore_backup_@_202859658_213948730_210944
376/.snapshots
ID 264 gen 127433 top level 263 path restore_backup_restore_backup_restore_backup_@_202859658_213948730_210944
376/.snapshots/1/snapshot
ID 265 gen 127433 top level 263 path restore_backup_restore_backup_restore_backup_@_202859658_213948730_210944
376/.snapshots/2/snapshot
ID 266 gen 127433 top level 263 path restore_backup_restore_backup_restore_backup_@_202859658_213948730_210944
376/.snapshots/3/snapshot
ID 267 gen 127433 top level 263 path restore_backup_restore_backup_restore_backup_@_202859658_213948730_210944
376/.snapshots/4/snapshot
ID 268 gen 127433 top level 263 path restore_backup_restore_backup_restore_backup_@_202859658_213948730_210944
376/.snapshots/5/snapshot
ID 269 gen 127433 top level 263 path restore_backup_restore_backup_restore_backup_@_202859658_213948730_210944
376/.snapshots/6/snapshot
ID 270 gen 127433 top level 263 path restore_backup_restore_backup_restore_backup_@_202859658_213948730_210944
376/.snapshots/7/snapshot
ID 271 gen 127433 top level 263 path restore_backup_restore_backup_restore_backup_@_202859658_213948730_210944
376/.snapshots/8/snapshot
ID 272 gen 152295 top level 263 path restore_backup_restore_backup_restore_backup_@_202859658_213948730_210944
376/.snapshots/9/snapshot
ID 273 gen 127433 top level 263 path restore_backup_restore_backup_restore_backup_@_202859658_213948730_210944
376/.snapshots/10/snapshot
ID 274 gen 127433 top level 263 path restore_backup_restore_backup_restore_backup_@_202859658_213948730_210944
376/.snapshots/11/snapshot
ID 275 gen 127433 top level 263 path restore_backup_restore_backup_restore_backup_@_202859658_213948730_210944
376/.snapshots/12/snapshot
ID 276 gen 170927 top level 5 path @
ID 277 gen 179141 top level 5 path restore_backup_@_202859658
ID 278 gen 127433 top level 5 path restore_backup_restore_backup_@_202859658_213948730_backup_2023240721071801
0
ID 279 gen 127433 top level 5 path restore_backup_restore_backup_restore_backup_@_202859658_213948730_21094437
6_backup_20232407212337461_testing_this_shit
ID 280 gen 127433 top level 5 path restore_backup_restore_backup_@_202859658_213948730
ID 281 gen 127433 top level 5 path restore_backup_restore_backup_restore_backup_@_202859658_213948730_21094437
6_backup_20232407212712363
ID 282 gen 152298 top level 5 path restore_backup_restore_backup_restore_backup_restore_backup_@_202859658_213
948730_210944376_183107159
ID 283 gen 152296 top level 5 path restore_backup_restore_backup_restore_backup_@_202859658_213948730_21094437
6
â•─jarnek@jarnek in ~ as đź§™ took 9ms
╰─λ sudo findmnt --real
TARGET SOURCE FSTYPE OPTIONS
/ /dev/nvme0n1p2[/restore_backup_@_202859658]
btrfs rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,autodefrag,subvolid=277,sub
├─/run/user/1000/doc
│ portal fuse.p rw,nosuid,nodev,relatime,user_id=1000,group_id=1001
├─/home
│ /dev/nvme0n1p2[/@home]
│ btrfs rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,autodefrag,subvolid=257,sub
├─/root
│ /dev/nvme0n1p2[/@root]
│ btrfs rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,autodefrag,subvolid=258,sub
├─/srv /dev/nvme0n1p2[/@srv]
│ btrfs rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,autodefrag,subvolid=259,sub
├─/var/cache
│ /dev/nvme0n1p2[/@cache]
│ btrfs rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,autodefrag,subvolid=260,sub
├─/var/log
│ /dev/nvme0n1p2[/@log]
│ btrfs rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,autodefrag,subvolid=261,sub
├─/var/tmp
│ /dev/nvme0n1p2[/@tmp]
│ btrfs rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,autodefrag,subvolid=262,sub
└─/boot/efi
/dev/nvme0n1p1
vfat rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,err
Any help would be greatly appreciated
