Managed to get VapourSynth to run my complex denoising script. Video encoding runs for a while and then.... "System hang prevention" kills my hard work!!
OK how do I slap his fingers to not touch it?
And what service is killing it to begin with. Searching about "system hang prevention" only returns people complaining about their system hanging.
My script and encoding process is using the memory. All of it. I put the laptop on Turbo mode and let it run all night. Memory usage is pretty stable as it processes the video; so if it starts fine, it should continue fine. Unless "system hang prevention" has a word in it.
and if one of the plugins has a bug and it really freezes, then I'd want to know.
Disabling nohang allows it to go about twice further before being killed again.
Memory usage is pretty high, but that's on script start. It remains stable.
I'm wondering whether zram can cause issues by letting VapourSynth think that it can use a lot more space for cache? I'm playing around with cache settings. But anyway; memory doesn't go up, it just decides to kill it at some point. Perhaps at some spikes. It goes up and down in spikes.
Perhaps if you disable zram temporarily it will give you enough cushion to finish your operation. However, if as suggested you have a memory leak it may still exhaust your ram.
Posting your script might help.
BTW, please do not post pictures of textual outputs.
@Hanuman I would bet on those spikes too.
Perhaps rather than disabling it altogether try see if you can configure it for your purpose,
Customizing corrective actions: if the name or control group of the victim matches a certain regex pattern, you can run any command instead of sending the SIGTERM signal
Now I'm playing with thread count of both VPY script and FFMPEG, and max_cache_size.
What's strange is that I was running the same script on Windows on 5K footage with x265 encoding. That was hungry. Now it's only 2.7K with x264 encoding.
It starts at about 2.6fps and then steadily go down to ~.8fps when it crashes. Now I see that "swp" in htop was in the red. If I reduce the thread count, swp has some room and it should avoid the crashes, but at lower performance. On Windows I ran 5K footage with x265 at about 0.5fps
It would seem you will need to lower the requirements of the operation you are performing. Perhaps using less threads would allow the operation to complete, although it would take much longer.
OK got it running stable at 1.1fps... System Monitor reports 20-50% CPU usage. I'll let this script run (4.5h), then see if I can do better. Disable zram perhaps.
Investigating how to disable zram before the next video (this one will actually take 9h). Just a yes/no... do I just need to run this to disable, and then reboot to re-enable?
Denoising raw cilp... it's too noisy due to lack of lighting, and it does a very good job. Normally it would take 4.5h per 9m clip segments in 5K ... but instead, now it's taking 9h per 9m segment in 2.7K at 60fps. Shouldn't be that slow.
