Kernel: 5.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=58203bda-e2e2-4c32-a006-c91d933cad4e rw [email protected]
loglevel=3 quiet intel_iommu=on iommu=pt
Type: Laptop System: Acer product: Predator PH315-53 v: V1.01
Mobo: CML model: QX50_CMS v: V1.01 serial: <superuser required>
UEFI: Insyde v: 1.01 date: 04/27/2020
ID-1: BAT1 charge: 42.7 Wh (100.0%) condition: 42.7/58.8 Wh (72.7%)
volts: 16.5 min: 15.4 model: SMP AP18E7M type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 2 microcode: 0xF0
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3403 high: 4541 min/max: 800/5000 scaling:
driver: intel_pstate governor: performance cores: 1: 1734 2: 4426 3: 4405
4: 4481 5: 4392 6: 4541 7: 3114 8: 3637 9: 2931 10: 1254 11: 3710
12: 2211 bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics]
vendor: Acer Incorporated ALI driver: i915 v: kernel ports: active: none
off: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 515.43.04
alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Turing pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none
off: HDMI-A-2 empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:1f15
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 0408:a061 class-ID: 0e02
gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Monitor-1: HDMI-A-2 mapped: HDMI-0 note: disabled pos: primary
model: Samsung serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 40
gamma: 1.2 size: 1210x680mm (47.64x26.77") diag: 1168mm (46") ratio: 16:9
Monitor-2: eDP-1 mapped: eDP-1-1 note: disabled
model: AU Optronics 0x82ed built: 2018 res: 1920x1080 dpi: 142 gamma: 1.2
size: 344x194mm (13.54x7.64") diag: 394mm (15.5") ratio: 16:9
modes: 1920x1080
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
v: 4.6.0 NVIDIA 515.43.04 direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Acer Incorporated ALI
Device-2: NVIDIA TU106 High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Texas Instruments PCM2900B Audio CODEC type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1.3:9 chip-ID: 08bb:29b0
Sound Server-1: ALSA v: k5.17.9-zen1-1-zen running: yes
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 07:00.0
chip-ID: 10ec:2600 class-ID: 0200
IF-ID-3: virbr1 state: down mac: <filter>
bus-ID: 1-14:5 chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
Local Storage: total: 5.26 TiB used: 1.21 TiB (23.0%)
model: PC SN730 SDBQNTY-512G-1014 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 11101100 temp: 24.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A3J0
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT275MX300SSD4
size: 256.17 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: R060 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital
model: WD Elements 2620 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 1023 scheme: GPT
ID-1: / raw-size: 468.84 GiB size: 468.84 GiB (100.00%)
used: 389.79 GiB (83.1%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:3
used: 51.2 MiB (53.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 468.84 GiB size: 468.84 GiB (100.00%)
ID-4: /var/log raw-size: 468.84 GiB size: 468.84 GiB (100.00%)
ID-5: /var/tmp raw-size: 468.84 GiB size: 468.84 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.46 GiB used: 1.91 GiB (12.3%)
System Temperatures: cpu: 78.0 C pch: 78.0 C mobo: N/A gpu: nvidia
temp: 71 C
Processes: 408 Uptime: 6d 2h 18m wakeups: 6 Memory: 15.46 GiB
used: 4.28 GiB (27.7%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1867 lib: 506 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2021-11-24
Last full system update: 2022-05-29 ↻
Failed units: systemd-networkd-wait-online.service systemd-sysctl.service
