Kernel: 6.8.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=a7a0db96-c8e3-4e7e-b2d7-5d9e61a7a07c rw rootflags=subvol=@
Type: Laptop System: Acer product: Aspire A515-51 v: V1.18
Mobo: KBL model: Charmander_KL v: V1.18 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 1.18
date: 03/29/2018
ID-1: BAT1 charge: 8.5 Wh (19.4%) condition: 43.8/48.9 Wh (89.5%)
volts: 14.3 min: 15.2 model: LG 004B384234314341 type: Li-ion
Info: model: Intel Core i7-7500U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 note: check built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
microcode: 0xF4
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 570 high: 782 min/max: 400/2700 scaling:
driver: intel_pstate governor: powersave cores: 1: 782 2: 400 3: 700 4: 400
bogomips: 23199
Device-1: Intel HD Graphics 620 vendor: Acer Incorporated ALI driver: i915
active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5916
Device-2: Sunplus Innovation HD WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:4 chip-ID: 1bcf:2ca0
class-ID: 0e02
Monitor-1: eDP-1 res: 1536x864 size: N/A modes: N/A
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.6-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 620 (KBL GT2)
device-ID: 8086:5916 memory: 7.45 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 620 (KBL GT2) driver: mesa intel v: 24.0.6-arch1.2
device-ID: 8086:5916 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.6-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
API: ALSA v: k6.8.7-zen1-2-zen status: kernel-api tools: N/A
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.1 chip-ID: 10ec:8168
IF: enp1s0f1 state: down mac: <filter>
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.0
lmp-v: 6 status: discoverable: no pairing: no class-ID: 6c010c
Device-2: Intel Wireless-AC 3168 Bluetooth driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 8087:0aa7
Report: ID: hci1 rfk-id: 3 state: up address: <filter> bt-v: 4.2 lmp-v: 8
Local Storage: total: 1.02 TiB used: 10.06 GiB (1.0%)
ID-1: /dev/sda maj-min: 8:0 model: SATA SSD size: 111.79 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 13.3 scheme: GPT
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: N/A serial: <filter> fw-rev: 1.00 scheme: GPT
used: 10.06 GiB (1.1%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 584 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: zram size: 7.63 GiB used: 117.5 MiB (1.5%)
System Temperatures: cpu: 52.0 C mobo: N/A
Memory: total: 8 GiB available: 7.63 GiB used: 2.94 GiB (38.5%)
Processes: 221 Power: uptime: 12m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.04 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1261 libs: 373 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.34
System install date: 2024-04-20
Last full system update: 2024-04-29
My system freezes when I close my laptop lid. I searched the forum for this issue and this is the closest one to my issue, but not what I was looking for.
I ran ‘systemctl suspend’ and my system froze the same as closing the lid to suspend the laptop.
