Hi. My system doesn’t boot with nvidia-drm.modeset=1 kernel parameter. With nvidia-drm.modeset=0 system boot normally, but my external monitor doesn’t worked on wayland session
Kernel: 6.7.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=1aad35f5-210c-4a9d-9e0d-add10435614d rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.1 tk: Qt v: N/A info: frameworks v: 6.0.0
wm: kwin_x11 tools: avail: lxlock vt: 2 dm: SDDM Distro: Garuda
Type: Laptop System: HP product: HP Pavilion Notebook
Mobo: HP model: 845E v: 83.62 serial: <superuser required>
part-nu: 2PQ51EA#ACB uuid: <superuser required> UEFI: Insyde v: F.61
date: 03/29/2018
ID-1: BAT0 charge: 44.3 Wh (100.0%) condition: 44.3/44.3 Wh (100.0%)
volts: 12.3 min: 10.9 model: HP Primary type: Li-ion serial: N/A
status: full
Device-1: hidpp_battery_2 model: Logitech G305 Lightspeed Wireless Gaming
Info: model: Intel Core i5-7300HQ bits: 64 type: MCP arch: Kaby Lake
model-id: 0x9E (158) stepping: 9 microcode: 0xF4
desc: 1x6 MiB
Speed (MHz): avg: 951 high: 1006 min/max: 800/3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 1006 2: 1000 3: 1000
4: 800 bogomips: 19999
Device-1: Intel HD Graphics 630 vendor: Hewlett-Packard driver: i915
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:591b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile]
vendor: Hewlett-Packard driver: nvidia v: 550.54.14
2024-02; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1c8c class-ID: 0302
Device-3: Chicony HP Wide Vision HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 04f2:b56d
class-ID: 0e02
s-diag: 1052mm (41.43")
Monitor-1: HDMI-1-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 93
size: 527x293mm (20.75x11.54") diag: 603mm (23.74") modes: N/A
Monitor-2: eDP-1 pos: right res: 1920x1080 hz: 60 dpi: 128
size: 382x215mm (15.04x8.46") diag: 438mm (17.26") modes: N/A
drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.2-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
device-ID: 8086:591b memory: 15.14 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 12 device: 0 type: integrated-gpu
name: Intel HD Graphics 630 (KBL GT2) driver: mesa intel v: 24.0.2-arch1.2
device-ID: 8086:591b surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce GTX 1050 Ti driver: nvidia v: 550.54.14
device-ID: 10de:1c8c surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.2-arch1.2 (LLVM
Device-1: Intel CM238 HD Audio vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a171
Device-2: NVIDIA GP107GL High Definition Audio vendor: Hewlett-Packard
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
API: ALSA v: k6.7.8-zen1-1-zen status: kernel-api tools: N/A
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:095a class-ID: 0280
vendor: Hewlett-Packard RTL8111/8168/8411 driver: r8169 v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 05:00.0
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:5 chip-ID: 8087:0a2a
Local Storage: total: 1.03 TiB used: 423.45 GiB (40.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD9SN8W-128G-1006
size: 119.24 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 3006 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
ID-1: / raw-size: 77.63 GiB size: 77.63 GiB (100.00%)
used: 51.31 GiB (66.1%) fs: btrfs dev: /dev/sdb3 maj-min: 8:19
ID-2: /boot/efi raw-size: 501 MiB size: 500 MiB (99.80%)
used: 584 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 390.62 GiB size: 390.62 GiB (100.00%)
used: 372.14 GiB (95.3%) fs: btrfs dev: /dev/sdb5 maj-min: 8:21
ID-4: /var/log raw-size: 77.63 GiB size: 77.63 GiB (100.00%)
ID-5: /var/tmp raw-size: 77.63 GiB size: 77.63 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.51 GiB used: 34 MiB (0.2%) priority: 100
ID-2: swap-2 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb2 maj-min: 8:18
System Temperatures: cpu: 56.0 C pch: 53.0 C mobo: N/A
Memory: total: 16 GiB available: 15.51 GiB used: 4.65 GiB (30.0%)
Processes: 296 Power: uptime: 1h 11m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.14 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1878 libs: 517 tools: octopi,pamac,paru
Compilers: clang: 17.0.6 gcc: 13.2.1 alt: 12 Shell: garuda-inxi
default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-08-13
Last full system update: 2024-03-08 ↻
