scro
15 October 2021 13:08
#1
Sweet Home 3D (SW3D) has been causing me problems with Garuda for a long time now. I can't say that the problems lie with Garuda alone, probably not, but the program runs at least reasonably well under Windoof.
Problems:
At the moment the program cannot be started under Garuda Linux, that is to say, a small program start window appears, but then the program tab disappears from the bar and the dock and only the start window remains permanently burned into the screen and can not be closed. Only a restart or logout then deletes the SW3D start screen.
This problem started with an garuda update about 2 days ago but after deinstallation and reinstallation of SW3D as well as the installation of Java it worked again. After another update today, the same game, only now nothing starts, even after deinstallation and reinstallation.
The second and older problem with SW3D is that the program window (SW3D) freezes after some time of use and can not be closed. Sometimes other program besides SW3D are still accesseble but sometimes all of the system is frozen and even the keyboard and only a hot reset over the power button and a restart than lets the PC work again.
As I said, I don't necessarily assume that the problem is Garuda himself, but maybe someone has a suggestion on how to get SW3D to run reasonably stable and safely on Garuda.
scro
#2
my sys-infos are:
System: Kernel: 5.14.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=40141552-e6a3-48ef-ade6-40c1a5425fd6 rw [email protected] quiet splash
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Dell product: Precision M6700 v: 01 serial: <filter> Chassis:
type: 9 serial: <filter>
Mobo: Dell model: 096J9P v: A00 serial: <filter> UEFI: Dell v: A20 date: 11/30/2018
Battery: ID-1: BAT0 charge: 62.2 Wh (100.0%) condition: 62.2/98.2 Wh (63.3%) volts: 12.6
min: 11.1 model: Samsung SDI DELL 1C75X2B type: Li-ion serial: <filter> status: Full
CPU: Info: Quad Core model: Intel Core i7-3720QM bits: 64 type: MT MCP arch: Ivy Bridge
family: 6 model-id: 3A (58) stepping: 9 microcode: 21 cache: L2: 6 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 41467
Speed: 3445 MHz min/max: 1200/3600 MHz Core speeds (MHz): 1: 3445 2: 3411 3: 3391
4: 3396 5: 3523 6: 3446 7: 3442 8: 3401
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP:
conditional, RSB filling
Graphics: Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: NVIDIA GK104GLM [Quadro K3000M] vendor: Dell driver: nouveau v: kernel
bus-ID: 01:00.0 chip-ID: 10de:11be class-ID: 0300
Device-3: Microdia Dell Integrated HD Webcam type: USB driver: uvcvideo bus-ID: 1-1.5:4
chip-ID: 0c45:643f class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel,nouveau
unloaded: modesetting alternate: fbdev,nv,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: LVDS1 res: 1920x1080 hz: 60 dpi: 128 size: 380x210mm (15.0x8.3")
diag: 434mm (17.1")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 21.2.3
compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20 class-ID: 0403
Device-2: NVIDIA GK104 HDMI Audio vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:0e0a class-ID: 0403
Sound Server-1: ALSA v: k5.14.12-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Intel 82579LM Gigabit Network vendor: Dell driver: e1000e v: kernel
port: f080 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
Device-2: Intel Centrino Ultimate-N 6300 driver: iwlwifi v: kernel port: e000
bus-ID: 03:00.0 chip-ID: 8086:422b class-ID: 0280
Drives: Local Storage: total: 2.55 TiB used: 582.06 GiB (22.3%)
ID-1: /dev/sda maj-min: 8:0 model: SATA SSD size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: BA.3
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: P3-1TB size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 117D
ID-3: /dev/sdc maj-min: 8:32 vendor: Micron model: MT-256 size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s type: SSD serial: <filter> rev: 117D
ID-4: /dev/sdd maj-min: 8:48 vendor: SanDisk model: Ultra II 500GB size: 465.76 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s type: SSD serial: <filter>
rev: 10WD scheme: MBR
Partition: ID-1: / raw-size: 953.61 GiB size: 953.61 GiB (100.00%) used: 313.36 GiB (32.9%)
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 562 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 953.61 GiB size: 953.61 GiB (100.00%) used: 313.36 GiB (32.9%)
ID-4: /var/log raw-size: 953.61 GiB size: 953.61 GiB (100.00%) used: 313.36 GiB (32.9%)
ID-5: /var/tmp raw-size: 953.61 GiB size: 953.61 GiB (100.00%) used: 313.36 GiB (32.9%)
ID-1: swap-1 type: zram size: 31.26 GiB used: 1.5 MiB (0.0%) priority: 100
Sensors: System Temperatures: cpu: 62.0 C mobo: 49.0 C sodimm: SODIMM C gpu: nouveau
temp: 38.0 C
Fan Speeds (RPM): cpu: 2595
Info: Processes: 281 Uptime: 8m wakeups: 2 Memory: 31.26 GiB used: 3.97 GiB (12.7%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages:
pacman: 1538 lib: 359 Client: Unknown Client: garuda-assistant inxi: 3.3.06
SGS
15 October 2021 13:11
#3
What was updated?
Use snapshot that work and wait for fix
scro
15 October 2021 13:12
#4
and some Diagnostic data with error message:
-- Journal begins at Mon 2021-10-11 15:30:01 KST, ends at Fri 2021-10-15 22:08:55 KST. --
Okt 15 21:33:42 eric-precisionm6700 systemd-modules-load[306]: Failed to find module 'vboxpci'
Okt 15 21:33:42 eric-precisionm6700 systemd-udevd[351]: vboxdrv: /usr/lib/udev/rules.d/60-vboxdrv.rules:1 Only network interfaces can be renamed, ignoring NAME="vboxdrv".
Okt 15 21:33:42 eric-precisionm6700 systemd-udevd[346]: vboxdrvu: /usr/lib/udev/rules.d/60-vboxdrv.rules:2 Only network interfaces can be renamed, ignoring NAME="vboxdrvu".
Okt 15 21:33:42 eric-precisionm6700 systemd-udevd[354]: vboxdrv: /usr/lib/udev/rules.d/60-vboxdrv.rules:1 Only network interfaces can be renamed, ignoring NAME="vboxdrv".
Okt 15 21:33:42 eric-precisionm6700 systemd-udevd[367]: vboxdrvu: /usr/lib/udev/rules.d/60-vboxdrv.rules:2 Only network interfaces can be renamed, ignoring NAME="vboxdrvu".
Okt 15 21:33:42 eric-precisionm6700 systemd-udevd[339]: vboxnetctl: /usr/lib/udev/rules.d/60-vboxdrv.rules:3 Only network interfaces can be renamed, ignoring NAME="vboxnetctl".
Okt 15 21:33:42 eric-precisionm6700 systemd-udevd[354]: host6: /usr/lib/udev/rules.d/50-sata.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.2/3-4.2:1.2/host6/scsi_host/host6/link_power_management_policy}, ignoring: No such file or directory
Okt 15 21:33:43 eric-precisionm6700 systemd-tmpfiles[556]: Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operation not permitted
Okt 15 21:33:44 eric-precisionm6700 kernel: Bluetooth: hci0: command 0x0c23 tx timeout
Okt 15 21:33:44 eric-precisionm6700 kernel: Bluetooth: hci0: sending frame failed (-19)
Okt 15 21:33:46 eric-precisionm6700 kernel: Bluetooth: hci0: command 0x0c14 tx timeout
Okt 15 21:33:46 eric-precisionm6700 kernel: Bluetooth: hci0: sending frame failed (-19)
Okt 15 21:33:47 eric-precisionm6700 smbd[3083]: [2021/10/15 21:33:47.726990, 0] ../../source3/smbd/server.c:1738(main)
Okt 15 21:33:47 eric-precisionm6700 smbd[3083]: smbd version 4.15.0 started.
Okt 15 21:33:47 eric-precisionm6700 smbd[3083]: Copyright Andrew Tridgell and the Samba Team 1992-2021
Okt 15 21:33:48 eric-precisionm6700 kernel: Bluetooth: hci0: command 0x0c25 tx timeout
Okt 15 21:33:48 eric-precisionm6700 kernel: Bluetooth: hci0: sending frame failed (-19)
Okt 15 21:33:50 eric-precisionm6700 kernel: Bluetooth: hci0: command 0x0c38 tx timeout
Okt 15 21:33:50 eric-precisionm6700 kernel: Bluetooth: hci0: sending frame failed (-19)
Okt 15 21:33:51 eric-precisionm6700 udev-configure-printer[627]: no corresponding CUPS device found
Okt 15 21:33:52 eric-precisionm6700 kernel: Bluetooth: hci0: command 0x0c39 tx timeout
Okt 15 21:33:52 eric-precisionm6700 kernel: Bluetooth: hci0: sending frame failed (-19)
Okt 15 21:33:53 eric-precisionm6700 colord-sane[3162]: io/hpmud/pp.c 627: unable to read device-id ret=-1
Okt 15 21:34:38 eric-precisionm6700 systemd[6969]: Failed to start Profile-sync-daemon.
Okt 15 21:34:44 eric-precisionm6700 kernel: nouveau 0000:01:00.0: msvld: unable to load firmware data
Okt 15 21:34:44 eric-precisionm6700 kernel: nouveau 0000:01:00.0: msvld: init failed, -19
Okt 15 21:34:45 eric-precisionm6700 kernel: nouveau 0000:01:00.0: msvld: unable to load firmware data
Okt 15 21:34:45 eric-precisionm6700 kernel: nouveau 0000:01:00.0: msvld: init failed, -19
scro
15 October 2021 13:16
#5
what was updated? good question!
just run the command 'upd' and let the system or better said Garuda decide. and normally I take a short overlook over the updates but hell, I can't remember them all at least I remember it was a Kernel update, as usual and a libreoffice update in it too.
filo
15 October 2021 13:21
#6
You should rummage into your pacman.log, with something like
cat /var/log/pacman.log | grep 2021-10-15 | grep upgraded
changing the date of course, or using installed, etc...
scro
15 October 2021 13:28
#7
filo:
rummage
snapshot OK
oh shit (sorry)
its because since I've deinstalled and reinstalled many times snapshot isn't an option anymore because it gives me only options from my last 10 attempts of today
scro
15 October 2021 13:29
#8
[2021-10-15T21:02:59+0900] [ALPM] upgraded aom (3.1.3-1 -> 3.1.3-2)
[2021-10-15T21:02:59+0900] [ALPM] upgraded bison (3.8.1-1 -> 3.8.2-1)
[2021-10-15T21:02:59+0900] [ALPM] upgraded systemd-libs (249.4-2 -> 249.5-1)
[2021-10-15T21:02:59+0900] [ALPM] upgraded bluez (5.61-1 -> 5.62-1)
[2021-10-15T21:02:59+0900] [ALPM] upgraded libnghttp2 (1.45.0-1 -> 1.45.1-1)
[2021-10-15T21:03:00+0900] [ALPM] upgraded systemd (249.4-2 -> 249.5-1)
[2021-10-15T21:03:00+0900] [ALPM] upgraded bluez-cups (5.61-1 -> 5.62-1)
[2021-10-15T21:03:00+0900] [ALPM] upgraded bluez-hid2hci (5.61-1 -> 5.62-1)
[2021-10-15T21:03:00+0900] [ALPM] upgraded bluez-libs (5.61-1 -> 5.62-1)
[2021-10-15T21:03:00+0900] [ALPM] upgraded bluez-plugins (5.61-1 -> 5.62-1)
[2021-10-15T21:03:00+0900] [ALPM] upgraded bluez-utils (5.61-1 -> 5.62-1)
[2021-10-15T21:03:00+0900] [ALPM] upgraded game-devices-udev (0.15-1 -> 0.16-1)
[2021-10-15T21:03:00+0900] [ALPM] upgraded garuda-welcome (1.0.11-1 -> 1.0.12-1)
[2021-10-15T21:03:00+0900] [ALPM] upgraded git (2.33.0-1 -> 2.33.1-1)
[2021-10-15T21:03:00+0900] [ALPM] upgraded gmic (2.9.9-1 -> 2.9.9-2)
[2021-10-15T21:03:01+0900] [ALPM] upgraded jre-openjdk-headless (16.0.2.u7-1 -> 17.u35-1)
[2021-10-15T21:03:01+0900] [ALPM] upgraded jre-openjdk (16.0.2.u7-1 -> 17.u35-1)
[2021-10-15T21:03:01+0900] [ALPM] upgraded jdk-openjdk (16.0.2.u7-1 -> 17.u35-1)
[2021-10-15T21:03:01+0900] [ALPM] upgraded qt5-svg (5.15.2+kde+r7-1 -> 5.15.2+kde+r13-1)
[2021-10-15T21:03:01+0900] [ALPM] upgraded qt5-declarative (5.15.2+kde+r32-1 -> 5.15.2+kde+r33-1)
[2021-10-15T21:03:01+0900] [ALPM] upgraded krita-plugin-gmic (2.9.9-1 -> 2.9.9-2)
[2021-10-15T21:03:02+0900] [ALPM] upgraded libfprint (1.94.0-1 -> 1.94.1-1)
[2021-10-15T21:03:02+0900] [ALPM] upgraded libpamac-aur (11.1.0-1 -> 11.1.0-2)
[2021-10-15T21:03:02+0900] [ALPM] upgraded libqalculate (3.20.1-1 -> 3.21.0-1)
[2021-10-15T21:03:05+0900] [ALPM] upgraded libreoffice-fresh (7.2.1-3 -> 7.2.2-1)
[2021-10-15T21:03:05+0900] [ALPM] upgraded libreoffice-fresh-de (7.2.1-1 -> 7.2.2-1)
[2021-10-15T21:03:06+0900] [ALPM] upgraded linux-lts (5.10.72-1 -> 5.10.73-1)
[2021-10-15T21:03:11+0900] [ALPM] upgraded linux-lts-headers (5.10.72-1 -> 5.10.73-1)
[2021-10-15T21:03:11+0900] [ALPM] upgraded linux-wifi-hotspot (4.2.0-1 -> 4.2.1-1)
[2021-10-15T21:03:13+0900] [ALPM] upgraded linux-zen (5.14.11.zen1-1 -> 5.14.12.zen1-1)
[2021-10-15T21:03:17+0900] [ALPM] upgraded linux-zen-headers (5.14.11.zen1-1 -> 5.14.12.zen1-1)
[2021-10-15T21:03:17+0900] [ALPM] upgraded neard (0.16-2 -> 0.17-1)
[2021-10-15T21:03:17+0900] [ALPM] upgraded openjdk-src (16.0.2.u7-1 -> 17.u35-1)
[2021-10-15T21:03:17+0900] [ALPM] upgraded pamac-aur (10.2.0-2 -> 10.2.1-2)
[2021-10-15T21:03:17+0900] [ALPM] upgraded python-reportlab (3.6.1-1 -> 3.6.2-1)
[2021-10-15T21:03:18+0900] [ALPM] upgraded skypeforlinux-stable-bin (8.75.0.140-1 -> 8.77.0.97-1)
[2021-10-15T21:03:18+0900] [ALPM] upgraded strawberry (0.9.3-3 -> 1.0.0-1)
[2021-10-15T21:03:18+0900] [ALPM] upgraded systemd-sysvcompat (249.4-2 -> 249.5-1)
[2021-10-15T21:03:18+0900] [ALPM] upgraded yay (10.3.1-2 -> 11.0.1-1)
[2021-10-15T21:29:13+0900] [ALPM] upgraded mlt (7.0.1-1 -> 7.0.1-2)
filo
15 October 2021 13:32
#9
scro:
openjdk-src
This could be a candidate for problems since that should be a Java application?
scro
15 October 2021 13:35
#11
thought the same but have no idea how to fix it
scro
15 October 2021 13:39
#12
ok I think we're coming closer since this is the terminal reply:
OpenJDK 64-Bit Server VM warning: Ignoring option --illegal-access=permit; support was removed in 17.0
Java 3D: implicit antialiasing enabled
Exception in thread "J3D-Renderer-1" java.lang.IllegalAccessError: class javax.media.j3d.X11NativeConfigTempla
te3D (in unnamed module @0x57829d67 ) cannot access class sun.awt.X11GraphicsConfig (in module java.desktop) be
cause module java.desktop does not export sun.awt to unnamed module @0x57829d67
at javax.media.j3d.X11NativeConfigTemplate3D.isGraphicsConfigSupported(X11NativeConfigTemplate3D.java:
180)
at javax.media.j3d.NativePipeline.isGraphicsConfigSupported(NativePipeline.java:3341)
at javax.media.j3d.Renderer.doWork(Renderer.java:533)
at javax.media.j3d.J3dThread.run(J3dThread.java:275)
filo
15 October 2021 13:41
#13
Have you tried the suggestions of the upstream site?
http://sweethome3d.com/faq.jsp
E.g.
Try to run the script SweetHome3D-Java3D-1_5_2
which is available in the Linux installer and runs with an older version of Java 3D.
If this solution doesn't work, you may still want to use Sweet Home 3D without 3D features, by reading the answer to the next question .
SGS
15 October 2021 13:46
#14
I edit one post above, now you post terminal output again in not nice form, please, edit your post.
Writing a well formatted post in the forum (Discource powered) is important, if you want readers to easily read and understand.
It's especially important for terminal output.
Here is a brief tutorial.
Terminal output
For terminal output, text output with special characters, always use code wrapping (Pre-formated text).
Select all of the text and do one of these:
Hit the </> button in Discource Post Toolbar.
Press CtrlShift+C on your keyboard.
Manually with markdown
After you Copy yo…
scro
15 October 2021 14:50
#16
Finally a running program again at least the downloaded one. Hopefully the install version get fixed soon too.
A big thank you for your prompt and good help.
filo
15 October 2021 14:54
#17
Sorry, I didn't get you.
You mean you fixed it by reinstalling?
scro
16 October 2021 05:18
#18
no not reinstalling. Its just that the downloaded versions of SW3D from the SW3D homepage with the embedded Java is working. So it is not fixed but atm I can work with it
system
closed
30 October 2021 05:18
#19
