Hi there Garuda staff and members,
I’m a total noob here, after only a few days of installing Dr460nized KDE on my old desktop PC (see specs below).
When I tried the live USB suspend/sleep seemed to work pretty well, and so it did for a day or two. After that, maybe for sume update, suspend seems to be broken.
I updated all the updatable (I think, with the System Update Assistant), but my suspend just won’t work anymore.
Keyboard and mouse stay lights on, monitor goes black for a while and then goes back to login screen. Or, more rarely, it seems to suspend and then never wake the monitor up.
After a suspend fail I rebooted and logged the journal here, as suggested by a kind Garuda Telegram channel member: https://termbin.com/uqfv
You can find my garuda-inxi info below.
Thanks for your help in advance!
Ezahn
root=UUID=1930b164-e875-487b-9e15-d08dfb606021 rw rootflags=subvol=@
Type: Desktop Mobo: ASRock model: P67 Extreme4 serial: <superuser required>
BIOS: American Megatrends v: P3.10 date: 04/24/2012
Info: model: Intel Core i5-2500K bits: 64 type: MCP arch: Sandy Bridge
desc: 1x6 MiB
Speed (MHz): avg: 1598 high: 1600 min/max: 1600/5900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1600 2: 1600 3: 1596
4: 1596 bogomips: 26339
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: ZOTAC driver: nvidia
v: 545.29.02 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2023-10; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:13c2 class-ID: 0300
Screen-1: 0 s-res: 1920x1080 s-dpi: 97 s-size: 503x283mm (19.80x11.14")
s-diag: 577mm (22.72")
Monitor-1: DP-1 size-res: N/A modes: N/A
Monitor-2: DVI-I-1 pos: primary res: 1920x1080 dpi: 96
size: 510x287mm (20.08x11.3") diag: 585mm (23.04") modes: N/A
Monitor-3: None-1-1 size-res: N/A modes: N/A
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 970/PCIe/SSE2
memory: 3.91 GiB
API: Vulkan v: 1.3.269 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 970 driver: nvidia v: 545.29.02
device-ID: 10de:13c2 surfaces: xcb,xlib
vendor: ASRock 6 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GM204 High Definition Audio vendor: ZOTAC
bus-ID: 01:00.1 chip-ID: 10de:0fbb class-ID: 0403
Device-3: Logitech G430 Surround Sound Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 2-1.2:4 chip-ID: 046d:0a4d class-ID: 0300
Device-4: M-Audio AIR 192 6 driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.3:4 chip-ID: 0763:410c
class-ID: fe01
Server-1: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: b000 bus-ID: 0c:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp12s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.6:4
lmp-v: 6 status: discoverable: no pairing: no class-ID: 1c0104
Local Storage: total: 2.85 TiB used: 586.28 GiB (20.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: M4-CT128M4SSD2
tech: SSD serial: <filter> fw-rev: 070H scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000DX001-1NS164
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC41 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Generic model: Flash Disk
size: 3.73 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter> fw-rev: 8.07
ID-1: / raw-size: 50 GiB size: 46.57 GiB (93.13%) used: 16.35 GiB (35.1%)
ID-2: /home raw-size: 431.51 GiB size: 431.51 GiB (100.00%)
used: 148.23 GiB (34.4%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-3: /var/log raw-size: 50 GiB size: 46.57 GiB (93.13%)
used: 16.35 GiB (35.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/tmp raw-size: 50 GiB size: 46.57 GiB (93.13%)
ID-1: swap-1 type: zram size: 15.58 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 38.0 C mobo: N/A gpu: nvidia temp: 36 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 32%
Processes: 221 Uptime: 15m wakeups: 0 Memory: total: 16 GiB
available: 15.58 GiB used: 3.24 GiB (20.8%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1421 libs: 444 tools: octopi,paru Shell: fish
v: 3.6.1 default: Bash v: 5.2.15 running-in: konsole inxi: 3.3.31
Garuda (2.6.17-1):
System install date: 2023-10-26
Last full system update: 2023-11-07 ↻
Failed units: systemd-suspend.service
