Hello everyone.
I’ve been banging my head on this since my initial install of garuda. I am a Windows user primarily who has tried a few times over the years to migrate to linux.
I’m incredibly pleased with my system performance, gaming performance etc. since I installed garuda. Other than the KDE janky animations that I attribute to X11 (I use an NVIDIA RTX3080, Wayland is an issue) my games run smoothly, fast, and without issue.
However, no matter what I try, I cannot suspend or hibernate my system. When I choose to suspend, my keyboard/mouse lighting will switch off, the screens will go dark, and after about 30-45 seconds the speakers will “pop”. However, the system power will remain on. If I hit a key on my keyboard, the system will return to the lock screen as if it was turning back on for the first time.
```text
Kernel: 6.5.7-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
available: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=16e6b88c-2d5c-4fda-8cab-7cb7346a56c2 rw rootflags=subvol=@ quiet quiet
rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3 ibt=off module_blacklist=r8169
mem_sleep_default=s2idle
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 dm: SDDM Distro: Garuda Linux
Type: Desktop System: Alienware product: Alienware Aurora R11 v: 1.0.21 serial: <filter> Chassis:
type: 3 serial: <filter>
Mobo: Alienware model: 0N43JM v: A00 serial: <filter> UEFI: Alienware v: 1.0.21
date: 07/04/2023
Info: model: Intel Core i7-10700 socket: U3E1 bits: 64 type: MT MCP arch: Comet Lake gen: core 10
level: v3 note: check built: 2020 process: Intel 14nm family: 6 model-id: 0xA5 (165) stepping: 5
microcode: 0xF8
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2718 high: 4699 min/max: 800/4800 base/boost: 2871/8300 scaling:
driver: intel_pstate governor: powersave volts: 0.8 V ext-clock: 100 MHz cores: 1: 4699 2: 4602
3: 4602 4: 800 5: 800 6: 4605 7: 800 8: 800 9: 4616 10: 800 11: 4602 12: 800 13: 4666 14: 4696
15: 800 16: 800 bogomips: 92796
Device-1: NVIDIA GA102 [GeForce RTX 3080] vendor: Dell driver: nvidia v: 535.113.01
alternate: nouveau,nvidia_drm non-free: 535.xx+ status: current (as of 2023-09) arch: Ampere
code: GAxxx process: TSMC n7 (7nm) built: 2020-23 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2206 class-ID: 0300
Display: server: X.Org v: 21.1.8 with: Xwayland v: 23.2.1 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 90 s-size: 1084x301mm (42.68x11.85")
s-diag: 1125mm (44.29")
Monitor-1: DP-4 pos: primary,left res: 1920x1080 hz: 60 dpi: 90 size: 544x303mm (21.42x11.93")
diag: 623mm (24.52") modes: N/A
Monitor-2: HDMI-0 pos: right res: 1920x1080 hz: 60 dpi: 92 size: 531x299mm (20.91x11.77")
diag: 609mm (23.99") modes: N/A
Monitor-3: None-1-1 size-res: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2 drv: swrast gbm:
drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 535.113.01 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2 memory: 9.77 GiB
API: Vulkan v: 1.3.264 layers: 1 device: 0 type: discrete-gpu name: NVIDIA GeForce RTX 3080
driver: nvidia v: 535.113.01 device-ID: 10de:2206 surfaces: xcb,xlib
Device-1: Intel Comet Lake PCH cAVS vendor: Dell driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA GA102 High Definition Audio vendor: Dell driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:1aef class-ID: 0403
API: ALSA v: k6.5.7-zen2-1-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
Server-1: PipeWire v: 0.3.82 status: n/a (root, process) with: 1: pipewire-pulse status: active
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:06f0 class-ID: 0280
Device-2: Realtek Killer E3000 2.5GbE vendor: Dell driver: N/A modules: r8169 pcie: gen: 2
speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID
: 10ec:3000 class-ID: 0200
Device-3: ASIX AX88179 Gigabit Ethernet driver: ax88179_178a type: USB rev: 3.0 speed: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-1:2 chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
IF: enp0s20f0u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2 lmp-v: 11 status:
discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 2.73 TiB used: 1.2 TiB (43.9%)
ID-1: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB size: 931.51 GiB
fw-rev: 2B4QFXO7 temp: 31.9 C scheme: GPT
SMART: yes health: PASSED on: 9d 4h cycles: 695 read-units: 20,602,315 [10.5 TB]
written-units: 16,084,543 [8.23 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
family: BarraCuda 3.5 (SMR) size: 1.82 TiB block-size: physical: 4096 B logical: 512 B sata: 3.1
speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter> fw-rev: 1003 temp: 39 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 10554h+06m+59.913s cycles: 2206 read: 12.71 TiB
written: 12.99 TiB Pre-Fail: attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
ID-1: / raw-size: 734.95 GiB size: 734.95 GiB (100.00%) used: 150.44 GiB (20.5%) fs: btrfs
block-size: 4096 B dev: /dev/nvme1n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: N/A size: 96 MiB used: 42.3 MiB (44.1%) fs: vfat block-size: 512 B
dev: /dev/nvme0n1p1
ID-3: /home raw-size: 734.95 GiB size: 734.95 GiB (100.00%) used: 150.44 GiB (20.5%) fs: btrfs
ID-4: /var/log raw-size: 734.95 GiB size: 734.95 GiB (100.00%) used: 150.44 GiB (20.5%)
fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p2 maj-min: 259:2
ID-5: /var/tmp raw-size: 734.95 GiB size: 734.95 GiB (100.00%) used: 150.44 GiB (20.5%)
ID-1: swap-1 type: zram size: 15.42 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 16 dev: /dev/zram0
System Temperatures: cpu: 47.0 C pch: 35.0 C mobo: N/A gpu: nvidia temp: 37 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 32%
Processes: 394 Uptime: 1h 1m wakeups: 1 Memory: total: 16 GiB available: 15.42 GiB
used: 4.52 GiB (29.3%) Init: systemd v: 254 default: graphical tool: systemctl Compilers:
gcc: 13.2.1 Packages: 1452 pm: pacman pkgs: 1442 libs: 454 tools: octopi,paru pm: flatpak
pkgs: 10 Client: shell wrapper v: 5.1.16-release inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-10-16
Last full system update: 2023-10-17 ↻
Windows dual boot: No/Undetected **my note: I am dual boot**
I have tried many different solutions from two days of googling and scouring the internet, from the LTS kernel, to modifications to various services, none of which are of any help. I have also ensured that windows fast boot options are disabled.
I suspect one of my hardware are at fault, based on my logs I’ve parsed:
Oct 17 15:00:00 JMLinux systemd-logind[803]: The system will suspend now!
Oct 17 15:00:00 JMLinux ModemManager[874]: <msg> [sleep-monitor-systemd] system is about to suspend
Oct 17 15:00:00 JMLinux NetworkManager[849]: <info> [1697565600.3608] manager: sleep: sleep requested (sleeping: no enabled: yes)
Oct 17 15:00:00 JMLinux NetworkManager[849]: <info> [1697565600.3609] device (wlo1): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Oct 17 15:00:00 JMLinux NetworkManager[849]: <info> [1697565600.3757] device (wlo1): set-hw-addr: reset MAC address to DC:41:A9:17:61:87 (unmanage)
Oct 17 15:00:00 JMLinux NetworkManager[849]: <info> [1697565600.3854] device (p2p-dev-wlo1): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Oct 17 15:00:00 JMLinux NetworkManager[849]: <info> [1697565600.3855] manager: NetworkManager state is now ASLEEP
Oct 17 15:00:00 JMLinux NetworkManager[849]: <info> [1697565600.3855] device (enp0s20f0u1): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Oct 17 15:00:00 JMLinux wpa_supplicant[888]: p2p-dev-wlo1: CTRL-EVENT-DSCP-POLICY clear_all
Oct 17 15:00:00 JMLinux wpa_supplicant[888]: nl80211: deinit ifname=p2p-dev-wlo1 disabled_11b_rates=0
Oct 17 15:00:00 JMLinux kded5[1305]: org.kde.plasma.nm.kded: Unhandled active connection state change: 3
Oct 17 15:00:00 JMLinux dbus-daemon[794]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.7' (uid=0 pid=849 comm="/usr/bin/NetworkManager --no-daemon")
Oct 17 15:00:00 JMLinux surfsharkd.js[1790]: {"event":"update","state":{"network_manager_state":10,"openvpn_vpn_state":0,"openvpn_vpn_reason":0,"openvpn_active_connection_state":4,"openvpn_active_connection_reason":0,"wg_active_connection_state":4,"wg_active_connection_reason":0,"user_locked":false,"current_physical_connection":{"id":"Wired Connection","type":"802-3-ethernet","uuid":"8b13c543-d8dd-4803-81f2-ecf175dac5fa","wireless_security":null,"internal_networks":[{"gateway":"192.168.2.1","protocol":"ipv4","address":"192.168.2.37","family":24,"_noncompliant":false}],"interface_name":"enp0s20f0u1","_noncompliant":false}}}
Oct 17 15:00:00 JMLinux systemd[1]: Starting Network Manager Script Dispatcher Service...
Oct 17 15:00:00 JMLinux wpa_supplicant[888]: wlo1: CTRL-EVENT-DSCP-POLICY clear_all
Oct 17 15:00:00 JMLinux dbus-daemon[794]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Oct 17 15:00:00 JMLinux systemd[1]: Started Network Manager Script Dispatcher Service.
Oct 17 15:00:00 JMLinux NetworkManager[849]: <info> [1697565600.4184] device (enp0s20f0u1): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Oct 17 15:00:00 JMLinux avahi-daemon[792]: Withdrawing address record for fe80::2593:aa6d:b89c:a174 on enp0s20f0u1.
Oct 17 15:00:00 JMLinux avahi-daemon[792]: Leaving mDNS multicast group on interface enp0s20f0u1.IPv6 with address fe80::2593:aa6d:b89c:a174.
Oct 17 15:00:00 JMLinux NetworkManager[849]: <info> [1697565600.4185] dhcp4 (enp0s20f0u1): canceled DHCP transaction
Oct 17 15:00:00 JMLinux avahi-daemon[792]: Interface enp0s20f0u1.IPv6 no longer relevant for mDNS.
Oct 17 15:00:00 JMLinux NetworkManager[849]: <info> [1697565600.4185] dhcp4 (enp0s20f0u1): activation: beginning transaction (timeout in 45 seconds)
Oct 17 15:00:00 JMLinux NetworkManager[849]: <info> [1697565600.4185] dhcp4 (enp0s20f0u1): state changed no lease
Oct 17 15:00:00 JMLinux DiscoverNotifier[1532]: packagekitqt.offline: Cannot process "org.freedesktop.PackageKit" as "org.freedesktop.PackageKit.Offline"
Oct 17 15:00:00 JMLinux avahi-daemon[792]: Withdrawing address record for 192.168.2.37 on enp0s20f0u1.
Oct 17 15:00:00 JMLinux avahi-daemon[792]: Leaving mDNS multicast group on interface enp0s20f0u1.IPv4 with address 192.168.2.37.
Oct 17 15:00:00 JMLinux avahi-daemon[792]: Interface enp0s20f0u1.IPv4 no longer relevant for mDNS.
Oct 17 15:00:00 JMLinux wpa_supplicant[888]: nl80211: deinit ifname=wlo1 disabled_11b_rates=0
Oct 17 15:00:00 JMLinux NetworkManager[849]: <info> [1697565600.4432] device (enp0s20f0u1): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Oct 17 15:00:00 JMLinux plasmashell[1367]: qt.svg: <input>:510:9: Could not resolve property: #paint4_linear_678_483
Oct 17 15:00:00 JMLinux PackageKit[1601]: get-updates transaction /4_dcbedcba from uid 1000 finished with success after 0ms
Oct 17 15:00:00 JMLinux kwin_x11[1306]: kwin_core: XCB error: 152 (BadDamage), sequence: 34891, resource id: 14683049, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Oct 17 15:00:00 JMLinux kscreenlocker_greet[2945]: Qt: Session management error: networkIdsList argument is NULL
Oct 17 15:00:00 JMLinux kscreenlocker_greet[2945]: kscreenlocker_greet: Lockscreen QML outdated, falling back to default
Oct 17 15:00:01 JMLinux kscreenlocker_greet[2945]: kf.kirigami: Failed to find a Kirigami platform plugin
Oct 17 15:00:01 JMLinux kscreenlocker_greet[2945]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:8:1: module "QtQuick.VirtualKeyboard" is not installed
Oct 17 15:00:01 JMLinux kscreenlocker_greet[2945]: qt.svg: <input>:304:9: Could not resolve property: #paint1_linear_909_67
Oct 17 15:00:01 JMLinux kscreenlocker_greet[2945]: qt.svg: <input>:304:9: Could not resolve property: #paint3_linear_909_67
Oct 17 15:00:01 JMLinux kscreenlocker_greet[2945]: qt.svg: <input>:304:9: Could not resolve property: #paint1_linear_650_128
Oct 17 15:00:01 JMLinux kscreenlocker_greet[2945]: qt.svg: <input>:304:9: Could not resolve property: #paint1_linear_905_67
Oct 17 15:00:01 JMLinux kscreenlocker_greet[2945]: qt.svg: <input>:304:9: Could not resolve property: #paint1_linear_637_218
Oct 17 15:00:01 JMLinux systemd[1]: Reached target Sleep.
Oct 17 15:00:01 JMLinux systemd[1]: Starting NVIDIA system suspend actions...
Oct 17 15:00:01 JMLinux suspend[2990]: nvidia-suspend.service
Oct 17 15:00:01 JMLinux logger[2990]: <13>Oct 17 15:00:01 suspend: nvidia-suspend.service
Oct 17 15:00:01 JMLinux kernel: snd_hda_codec_hdmi hdaudioC1D0: HDMI: invalid ELD data byte 12
Oct 17 15:00:01 JMLinux bluetoothd[793]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/ldac
Oct 17 15:00:01 JMLinux bluetoothd[793]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSink/aptx_hd
Oct 17 15:00:01 JMLinux bluetoothd[793]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/aptx_hd
Oct 17 15:00:01 JMLinux bluetoothd[793]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSink/aac
Oct 17 15:00:01 JMLinux bluetoothd[793]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/aac
Oct 17 15:00:01 JMLinux bluetoothd[793]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSink/sbc
Oct 17 15:00:01 JMLinux bluetoothd[793]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/sbc
Oct 17 15:00:01 JMLinux bluetoothd[793]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSink/sbc_xq
Oct 17 15:00:01 JMLinux bluetoothd[793]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/sbc_xq
Oct 17 15:00:01 JMLinux bluetoothd[793]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/aptx_ll_1
Oct 17 15:00:01 JMLinux bluetoothd[793]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/aptx_ll_0
Oct 17 15:00:01 JMLinux bluetoothd[793]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Oct 17 15:00:01 JMLinux bluetoothd[793]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Oct 17 15:00:01 JMLinux bluetoothd[793]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/faststream
Oct 17 15:00:01 JMLinux bluetoothd[793]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/faststream_duplex
Oct 17 15:00:01 JMLinux bluetoothd[793]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSink/opus_05
Oct 17 15:00:01 JMLinux bluetoothd[793]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/opus_05
Oct 17 15:00:01 JMLinux bluetoothd[793]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Oct 17 15:00:01 JMLinux bluetoothd[793]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Oct 17 15:00:02 JMLinux systemd[1]: nvidia-suspend.service: Deactivated successfully.
Oct 17 15:00:02 JMLinux systemd[1]: Finished NVIDIA system suspend actions.
Oct 17 15:00:02 JMLinux systemd[1]: Starting System Suspend...
Oct 17 15:00:02 JMLinux systemd-sleep[3004]: Entering sleep state 'suspend'...
Oct 17 15:00:02 JMLinux kernel: PM: suspend entry (s2idle)
Oct 17 15:00:02 JMLinux kernel: Filesystems sync: 0.187 seconds
Oct 17 15:01:15 JMLinux kernel: Freezing user space processes
Oct 17 15:01:15 JMLinux kernel: Freezing user space processes completed (elapsed 0.001 seconds)
Oct 17 15:01:15 JMLinux kernel: OOM killer disabled.
Oct 17 15:01:15 JMLinux kernel: Freezing remaining freezable tasks
Oct 17 15:01:15 JMLinux kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
Oct 17 15:01:15 JMLinux kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Oct 17 15:01:15 JMLinux kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
Oct 17 15:01:15 JMLinux kernel: sd 0:0:0:0: [sda] Stopping disk
Oct 17 15:01:15 JMLinux kernel: intel_pch_thermal 0000:00:12.0: CPU-PCH is cool [36C]
Oct 17 15:01:15 JMLinux kernel: pci 0000:04:00.0: Unable to change power state from unknown to D0, device inaccessible
Oct 17 15:01:15 JMLinux kernel: pcieport 0000:00:1b.0: broken device, retraining non-functional downstream link at 2.5GT/s
Oct 17 15:01:15 JMLinux kernel: pcieport 0000:00:1b.0: retraining failed
Oct 17 15:01:15 JMLinux kernel: nvme 0000:03:00.0: not ready 1023ms after resume; waiting
Oct 17 15:01:15 JMLinux kernel: nvme 0000:03:00.0: not ready 2047ms after resume; waiting
Oct 17 15:01:15 JMLinux kernel: nvme 0000:03:00.0: not ready 4095ms after resume; waiting
Oct 17 15:01:15 JMLinux kernel: nvme 0000:03:00.0: not ready 8191ms after resume; waiting
Oct 17 15:01:15 JMLinux kernel: nvme 0000:03:00.0: not ready 16383ms after resume; waiting
Oct 17 15:01:15 JMLinux kernel: nvme 0000:03:00.0: not ready 32767ms after resume; waiting
Oct 17 15:01:15 JMLinux kernel: nvme 0000:03:00.0: not ready 65535ms after resume; giving up
Oct 17 15:01:15 JMLinux kernel: nvme 0000:03:00.0: Unable to change power state from D3cold to D0, device inaccessible
Oct 17 15:01:15 JMLinux kernel: nvme nvme0: Disabling device after reset failure: -19
Oct 17 15:01:15 JMLinux kernel: nvme nvme1: Shutdown timeout set to 8 seconds
Oct 17 15:01:15 JMLinux kernel: nvme nvme1: 12/0/0 default/read/poll queues
Oct 17 15:01:15 JMLinux kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Oct 17 15:01:15 JMLinux kernel: ata3: SATA link down (SStatus 4 SControl 300)
Oct 17 15:01:15 JMLinux kernel: ata2: SATA link down (SStatus 4 SControl 300)
Oct 17 15:01:15 JMLinux kernel: ata4: SATA link down (SStatus 4 SControl 300)
Oct 17 15:01:15 JMLinux kernel: OOM killer enabled.
Oct 17 15:01:15 JMLinux rtkit-daemon[1267]: The canary thread is apparently starving. Taking action.
Oct 17 15:01:15 JMLinux rtkit-daemon[1267]: Demoting known real-time threads.
Oct 17 15:01:15 JMLinux rtkit-daemon[1267]: Demoted 0 threads.
Oct 17 15:01:15 JMLinux kernel: Restarting tasks ... done.
Oct 17 15:01:15 JMLinux kernel: random: crng reseeded on system resumption
Oct 17 15:01:15 JMLinux systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Oct 17 15:01:15 JMLinux systemd-sleep[3004]: System returned from sleep state.
Oct 17 15:01:15 JMLinux bluetoothd[793]: Controller resume with wake event 0x0
Oct 17 15:01:15 JMLinux kernel: PM: suspend exit
Oct 17 15:01:15 JMLinux surfsharkd.js[1790]: JS LOG: Error: Parsing Error: Invalid arguments:
Oct 17 15:01:15 JMLinux surfsharkd.js[1790]: {"event":"update","state":{"network_manager_state":10,"openvpn_vpn_state":0,"openvpn_vpn_reason":0,"openvpn_active_connection_state":4,"openvpn_active_connection_reason":0,"wg_active_connection_state":4,"wg_active_connection_reason":0,"user_locked":false,"current_physical_connection":null}}
Oct 17 15:01:16 JMLinux systemd[1]: systemd-suspend.service: Deactivated successfully.
Oct 17 15:01:16 JMLinux systemd[1]: Finished System Suspend.
Oct 17 15:01:16 JMLinux systemd[1]: Stopped target Sleep.
Oct 17 15:01:16 JMLinux systemd[1]: Reached target Suspend.
Oct 17 15:01:16 JMLinux systemd-logind[803]: Operation 'sleep' finished.
Oct 17 15:01:16 JMLinux NetworkManager[849]: <info> [1697565676.1666] manager: sleep: wake requested (sleeping: yes enabled: yes)
Oct 17 15:01:16 JMLinux NetworkManager[849]: <info> [1697565676.1667] device (enp0s20f0u1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Oct 17 15:01:16 JMLinux ModemManager[874]: <msg> [sleep-monitor-systemd] system is resuming
Oct 17 15:01:16 JMLinux kdeconnectd[1513]: Error sending UDP packet: QAbstractSocket::NetworkError
Oct 17 15:01:16 JMLinux systemd[1]: Starting NVIDIA system resume actions...
Oct 17 15:01:16 JMLinux systemd[1]: Stopped target Suspend.
Oct 17 15:01:16 JMLinux suspend[3167]: nvidia-resume.service
Oct 17 15:01:16 JMLinux logger[3167]: <13>Oct 17 15:01:16 suspend: nvidia-resume.service
Oct 17 15:01:16 JMLinux systemd[1]: nvidia-resume.service: Deactivated successfully.
Oct 17 15:01:16 JMLinux systemd[1]: Finished NVIDIA system resume actions.
Oct 17 15:01:16 JMLinux bluetoothd[793]: Endpoint registered: sender=:1.89 path=/MediaEndpoint/A2DPSource/ldac
Oct 17 15:01:16 JMLinux bluetoothd[793]: Endpoint registered: sender=:1.89 path=/MediaEndpoint/A2DPSink/aptx_hd
Oct 17 15:01:16 JMLinux bluetoothd[793]: Endpoint registered: sender=:1.89 path=/MediaEndpoint/A2DPSource/aptx_hd
Oct 17 15:01:16 JMLinux bluetoothd[793]: Endpoint registered: sender=:1.89 path=/MediaEndpoint/A2DPSink/aac
Oct 17 15:01:16 JMLinux bluetoothd[793]: Endpoint registered: sender=:1.89 path=/MediaEndpoint/A2DPSource/aac
Oct 17 15:01:16 JMLinux bluetoothd[793]: Endpoint registered: sender=:1.89 path=/MediaEndpoint/A2DPSink/sbc
Oct 17 15:01:16 JMLinux bluetoothd[793]: Endpoint registered: sender=:1.89 path=/MediaEndpoint/A2DPSource/sbc
Oct 17 15:01:16 JMLinux bluetoothd[793]: Endpoint registered: sender=:1.89 path=/MediaEndpoint/A2DPSink/sbc_xq
Oct 17 15:01:16 JMLinux bluetoothd[793]: Endpoint registered: sender=:1.89 path=/MediaEndpoint/A2DPSource/sbc_xq
Oct 17 15:01:16 JMLinux bluetoothd[793]: Endpoint registered: sender=:1.89 path=/MediaEndpoint/A2DPSource/aptx_ll_1
Oct 17 15:01:16 JMLinux bluetoothd[793]: Endpoint registered: sender=:1.89 path=/MediaEndpoint/A2DPSource/aptx_ll_0
Oct 17 15:01:16 JMLinux bluetoothd[793]: Endpoint registered: sender=:1.89 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Oct 17 15:01:16 JMLinux bluetoothd[793]: Endpoint registered: sender=:1.89 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Oct 17 15:01:16 JMLinux bluetoothd[793]: Endpoint registered: sender=:1.89 path=/MediaEndpoint/A2DPSource/faststream
Oct 17 15:01:16 JMLinux bluetoothd[793]: Endpoint registered: sender=:1.89 path=/MediaEndpoint/A2DPSource/faststream_duplex
Oct 17 15:01:16 JMLinux bluetoothd[793]: Endpoint registered: sender=:1.89 path=/MediaEndpoint/A2DPSink/opus_05
Oct 17 15:01:16 JMLinux bluetoothd[793]: Endpoint registered: sender=:1.89 path=/MediaEndpoint/A2DPSource/opus_05
Oct 17 15:01:16 JMLinux bluetoothd[793]: Endpoint registered: sender=:1.89 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Oct 17 15:01:16 JMLinux bluetoothd[793]: Endpoint registered: sender=:1.89 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Oct 17 15:01:16 JMLinux NetworkManager[849]: <info> [1697565676.4910] device (wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Oct 17 15:01:16 JMLinux NetworkManager[849]: <info> [1697565676.4914] device (p2p-dev-wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Oct 17 15:01:16 JMLinux NetworkManager[849]: <info> [1697565676.4916] manager: NetworkManager state is now DISCONNECTED
I would appreciate any help you all can provide. If I can get this fixed, I think I will finally be able to ditch windows for good.
