Did this in /.profile . What it did is, after logout or reboot, Garuda assistant will open with the dark theme (Sweet in my case) but wonβt load XFCE desktop.
Restoring snapshot wonβt help obviously.
Anyways , donβt bother about the issue. Iβm currently installing your Sway latest
Good thing I backed up my PDFs just minutes before doing this
β¦but there was an identical error in the terminal for all themes tried:
(garuda-assistant:3511): Gtk-WARNING **: 09:29:25.253: Theme parsing error: gtk.css:4283:35: '-2px' is not a valid color name
(garuda-assistant:3511): Gtk-WARNING **: 09:29:25.253: Theme parsing error: gtk.css:4287:35: '-1px' is not a valid color name
QMetaObject::connectSlotsByName: No matching signal for on_checkBox_clicked(QWidget*)
I cannot imagine any possible way these two things could be related. My guess is this was only a coincidence, and some other configuration change was responsible for the issue you encountered.
As a side note, restoring a snapshot would not be needed to revert a change to ~/.profile; instead, you could just edit the file from a TTY before signing in if it were causing a problem.
I believe these errors are related to some messiness in the actual code of the application. It should be cleaned up at some point, but that would be more appropriate to raise as an issue on GitLab. If everything is working normally I wouldnβt worry about it too much for now.
I donβt think this particular environment variable is risky to set. It just announces how Qt apps should be themed.
Just a quick note to say the guide at the top of the page has now been completed. A ton of stuff has been added and it now provides a unique take on an Xfce desktop. A brief video has been added to the end of the guide to demonstrate some of the aspects.
I have moved the video to the top of the article and added a couple of pieces at the bottom which help to remove unused data.
Unfortunately Iβve found that the tip for /etc/systemd/journald.conf isnβt working and Iβm wondering if anyone knows the reason why as these files can take up a huge amount of drive space. If it could be kept to 50 MB it would be much better.
If you are just looking at the size of the /var/log/journal directory in a file manager or something, you should be aware that the file sizes here are not actually reported in an accurate way. That may be why you are thinking it is not working, when really it probably is.
The journal files are often sparse, meaning they take up less space on disk than their reported size, and they are also compressed but may be reporting their uncompressed size. There is also metadata in these directories which does not count against the total journal size, and probably other factors contribute to it as well.
If you look inside the actual directory you will see it is kind of weird looking. Here is mine, which shows I have 31 journal files that are oddly each 6.6M in size:
β― exa -TalL2 --total-size /var/log/journal/
drwxr-sr-x@ 203M root 14 Dec 2023 /var/log/journal
drwxr-sr-x@ 203M root 21 Feb 21:26 βββ 541b848588a74934987d67f2c44000df
.rw-r-----@ 6.6M root 21 Feb 22:25 β βββ system.journal
.rw-r-----@ 6.6M root 21 Feb 21:26 β βββ system@1fd05eb187d048e5a11d8fc9aa0e2a02-000000000002e31a-000611ef21361cd9.journal
.rw-r-----@ 6.6M root 18 Feb 11:21 β βββ system@9a96cbd3c9c64fc0b259df06e3fc37b2-0000000000026b6b-000611aa5c15cf29.journal
.rw-r-----@ 6.6M root 18 Feb 11:21 β βββ system@9a96cbd3c9c64fc0b259df06e3fc37b2-0000000000027424-000611aa5d242f28.journal
.rw-r-----@ 6.6M root 18 Feb 11:46 β βββ system@9a96cbd3c9c64fc0b259df06e3fc37b2-00000000000276f6-000611aa6036c6ab.journal
.rw-r-----@ 6.6M root 18 Feb 12:10 β βββ system@9a96cbd3c9c64fc0b259df06e3fc37b2-0000000000028a48-000611aab6f559b6.journal
.rw-r-----@ 6.6M root 18 Feb 21:17 β βββ system@9a96cbd3c9c64fc0b259df06e3fc37b2-0000000000029700-000611ab0c71e096.journal
.rw-r-----@ 6.6M root 19 Feb 07:20 β βββ system@24a8e91d09474308b46685c8fa69f110-000000000002a624-000611b2b5e703c4.journal
.rw-r-----@ 6.6M root 18 Feb 21:18 β βββ system@24a8e91d09474308b46685c8fa69f110-0000000000029d68-000611b2b2f205dc.journal
.rw-r-----@ 6.6M root 20 Feb 20:40 β βββ system@55a4ca6a66f249f1a5680e615d48ddf2-000000000002cf68-000611da669c1292.journal
.rw-r-----@ 6.6M root 21 Feb 21:23 β βββ system@55a4ca6a66f249f1a5680e615d48ddf2-000000000002d83f-000611da68beab36.journal
.rw-r-----@ 6.6M root 19 Feb 20:51 β βββ system@473ef83cc7774f5796f8a3ee026131c2-000000000002bc0f-000611c67067cd09.journal
.rw-r-----@ 6.6M root 20 Feb 20:39 β βββ system@473ef83cc7774f5796f8a3ee026131c2-000000000002c4dd-000611c674aa9f39.journal
.rw-r-----@ 6.6M root 17 Feb 20:03 β βββ system@c498f41a2b914240ad883bf7edb5e11b-0000000000024a01-00061197fba82c3a.journal
.rw-r-----@ 6.6M root 17 Feb 13:25 β βββ system@c498f41a2b914240ad883bf7edb5e11b-00000000000240cc-00061197b3b6bcf0.journal
.rw-r-----@ 6.6M root 18 Feb 11:20 β βββ system@c498f41a2b914240ad883bf7edb5e11b-0000000000025a74-0006119d8d46ddd1.journal
.rw-r-----@ 6.6M root 19 Feb 07:21 β βββ system@d7e867ad0f344459a458bfe19394bde3-000000000002aab1-000611bb1f0637fb.journal
.rw-r-----@ 6.6M root 19 Feb 20:50 β βββ system@d7e867ad0f344459a458bfe19394bde3-000000000002b35d-000611bb2108f6b8.journal
.rw-r-----@ 6.6M root 21 Feb 22:20 β βββ user-1000.journal
.rw-r-----@ 6.6M root 18 Feb 11:21 β βββ user-1000@9a96cbd3c9c64fc0b259df06e3fc37b2-0000000000027423-000611aa5d23f3f7.journal
.rw-r-----@ 6.6M root 18 Feb 11:46 β βββ user-1000@9a96cbd3c9c64fc0b259df06e3fc37b2-0000000000027792-000611aa633b2f68.journal
.rw-r-----@ 6.6M root 18 Feb 21:18 β βββ user-1000@9a96cbd3c9c64fc0b259df06e3fc37b2-0000000000029bcb-000611ab33cd5666.journal
.rw-r-----@ 6.6M root 18 Feb 12:10 β βββ user-1000@9a96cbd3c9c64fc0b259df06e3fc37b2-0000000000029147-000611aae79e5fba.journal
.rw-r-----@ 6.6M root 19 Feb 07:21 β βββ user-1000@24a8e91d09474308b46685c8fa69f110-000000000002a623-000611b2b5e6cb03.journal
.rw-r-----@ 6.6M root 21 Feb 21:26 β βββ user-1000@55a4ca6a66f249f1a5680e615d48ddf2-000000000002d83e-000611da68be6942.journal
.rw-r-----@ 6.6M root 20 Feb 20:40 β βββ user-1000@473ef83cc7774f5796f8a3ee026131c2-000000000002c4dc-000611c674aa5f7f.journal
.rw-r-----@ 6.6M root 17 Feb 13:05 β βββ user-1000@c498f41a2b914240ad883bf7edb5e11b-0000000000023dcb-000611979b1eedea.journal
.rw-r-----@ 6.6M root 17 Feb 20:03 β βββ user-1000@c498f41a2b914240ad883bf7edb5e11b-0000000000024f18-0006119825571d1a.journal
.rw-r-----@ 6.6M root 17 Feb 13:25 β βββ user-1000@c498f41a2b914240ad883bf7edb5e11b-000000000002440d-00061197cfb6118f.journal
.rw-r-----@ 6.6M root 18 Feb 11:21 β βββ user-1000@c498f41a2b914240ad883bf7edb5e11b-0000000000025b67-0006119d8da38134.journal
.rw-r-----@ 6.6M root 19 Feb 20:51 β βββ user-1000@d7e867ad0f344459a458bfe19394bde3-000000000002b35c-000611bb2108ba12.journal
drwxr-sr-x 0 root 14 Dec 2023 βββ remote
According to that, this directory weighs in at a whopping 203M, which is obviously way over the 50M limit.
To get a more accurate picture of the journalβs disk usage, run journalctl --disk-usage. Here is mine, on the same system:
β― journalctl --disk-usage
Archived and active journals take up 43.7M in the file system.
