Kernel: 5.16.4-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=f1250705-50f0-494d-af74-04602be03ceb rw rootflags=subvol=@
resume=UUID=4be56dd4-ede9-43d7-b8ee-2e20c33d086d loglevel=3
Type: Desktop Mobo: ASUSTeK model: ROG STRIX Z370-E GAMING v: Rev X.0x
serial: UEFI-[Legacy]: American Megatrends v: 0408
date: 08/31/2017
Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4701 high: 4704 min/max: 800/4700 scaling:
driver: intel_pstate governor: performance cores: 1: 4702 2: 4703 3: 4700
4: 4702 5: 4701 6: 4701 7: 4703 8: 4700 9: 4704 10: 4701 11: 4701
12: 4700 bogomips: 88796
Type: l1tf
Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: Gigabyte
driver: nvidia v: 510.47.03 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1b06 class-ID: 0300
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 3440x2208 s-dpi: 107 s-size: 817x524mm (32.2x20.6")
s-diag: 971mm (38.2")
Monitor-1: HDMI-1 res: 1366x768 hz: 60 dpi: 158
size: 220x132mm (8.7x5.2") diag: 257mm (10.1")
Monitor-2: DP-2 res: 3440x1440 dpi: 109 size: 798x335mm (31.4x13.2")
diag: 865mm (34.1")
OpenGL: renderer: NVIDIA GeForce GTX 1080 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 510.47.03 direct render: Yes
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
Device-2: NVIDIA GP102 HDMI Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:10ef class-ID: 0403
Device-3: Creative Sound BlasterX G1 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-13.1:7
chip-ID: 041e:3249 class-ID: 0300 serial:
Device-4: Kingston HyperX 7.1 Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-13.3:9
chip-ID: 0951:16a4 class-ID: 0300 serial:
Sound Server-1: ALSA v: k5.16.4-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.44 running: yes
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac:
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: ASUSTeK
driver: rtw_8822be v: N/A modules: rtw88_8822be port: d000 bus-ID: 04:00.0
chip-ID: 10ec:b822 class-ID: 0280
IF: wlp4s0 state: down mac:
IF-ID-1: anbox0 state: down mac:
Device-1: ASUSTek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-7:3 chip-ID: 0b05:185c class-ID: e001 serial:
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address:
Local Storage: total: 939.14 GiB used: 289.61 GiB (30.8%)
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial:
rev: 2B2QEXM7 temp: 46.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
type: SSD serial: rev: 1B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
type: SSD serial: rev: 2B6Q scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: SMI (STMicroelectronics)
model: USB DISK size: 7.61 GiB block-size: physical: 512 B logical: 512 B
type: N/A serial: rev: 1100 scheme: MBR
ID-1: / raw-size: 431.35 GiB size: 431.35 GiB (100.00%)
used: 289.61 GiB (67.1%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 431.35 GiB size: 431.35 GiB (100.00%)
ID-3: /var/log raw-size: 431.35 GiB size: 431.35 GiB (100.00%)
ID-4: /var/tmp raw-size: 431.35 GiB size: 431.35 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.4 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 31.28 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 47 C
Processes: 314 Uptime: 15m wakeups: 0 Memory: 31.28 GiB
used: 4.04 GiB (12.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1834 lib: 536 Shell: fish v: 3.3.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.12
Garuda (2.5.4-1):
System install date: 2022-02-02
Last full system update: 2022-02-03
Windows dual boot:
So i login in my machine, i change password with passwd or the garuda settings manager, and after that everything constantly says i have the password wrong, i cant add an user cause it also freezes.
Basicly im stuck with a weird bug that allows me to login but doesnt allow me to do anything else.
