Sudden amdgpu glx/renderer failure?
Hi all, this issue appeared out of the blue – basically no 3D game will launch, steam won’t even launch, and certain browser tabs will repeatedly crash. i have tried ditching amdgpu-pro, as well as switching to mesa-tkg-bin, then back to regular mesa-bin… issue also persists through different kernels (xanmod, zen, xanmod-rt, amd)
inxi:
Kernel: 6.6.13-x64v-xanmod1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-xanmod
root=UUID=23b243a1-ac0c-43c8-873b-adaaa1e61825 rw rootflags=subvol=@
quiet ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 dm: SDDM
Type: Desktop Mobo: Micro-Star model: PRO X670-P WIFI (MS-7D67) v: 1.0
serial: <filter> UEFI: American Megatrends LLC. v: 1.D1 date: 09/26/2023
Info: model: AMD Ryzen 7 7700X socket: AM5 bits: 64 type: MT MCP arch: Zen 4
gen: 5 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
family: 0x19 (25) model-id: 0x61 (97) stepping: 2 microcode: 0xA601206
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4190 high: 5438 min/max: 400/5573 base/boost: 4500/5550
scaling: driver: amd-pstate-epp governor: powersave volts: 1.3 V
ext-clock: 100 MHz cores: 1: 4529 2: 3969 3: 3913 4: 3871 5: 4356 6: 3779
7: 3604 8: 4351 9: 4046 10: 3695 11: 5185 12: 5319 13: 3699 14: 5438
15: 3677 16: 3611 bogomips: 144011
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX] vendor: ASRock
driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1
empty: DP-2,DP-3,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:744c
Device-2: AMD Raphael vendor: Micro-Star MSI driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-4, DP-5,
DP-6, HDMI-A-2 bus-ID: 19:00.0 chip-ID: 1002:164e class-ID: 0300
temp: 36.0 C
Display: server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
s-diag: 777mm (30.58")
Monitor-1: DP-1 mapped: DisplayPort-0 model: 27E6QC serial: <filter>
built: 2023 res: 2560x1440 hz: 165 dpi: 109 gamma: 1.2
max: 2560x1440 min: 720x400
API: EGL v: N/A platforms:
inactive: gbm,wayland,x11,surfaceless,device-0,device-1,device-2
API: OpenGL Message: GL data unavailable for root.
zswap: no
ID-1: swap-1 type: zram size: 30.54 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 46.2 C mobo: 36.0 C
GPU: device: amdgpu temp: 37.0 C device: amdgpu temp: 39.0 C mem: 56.0 C
fan: 1 watts: 30.00
Processes: 591 Uptime: 8m wakeups: 0 Memory: total: 32 GiB note: est.
available: 30.54 GiB used: 5.54 GiB (18.2%) Init: systemd v: 255
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: N/A
Packages: pm: pacman pkgs: 2056 libs: 483 tools: octopi,paru,yay
Shell: garuda-inxi (sudo) default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.31
Garuda (2.6.22-1):
System install date:     2023-10-15
Last full system update: 2024-01-23
Windows dual boot:       Yes
Failed units:            fix-bt-a2dp.service
also i’m sure this is relevant –
╰─λ glxinfo
name of display: :0
Error: couldn't find RGB GLX visual or fbconfig
╰─λ amdgpu-arch
amdgpu-arch: error while loading shared libraries: libLLVM-16.so: cannot open shared object file: No such fileor directory
╰─λ radeontop
Unknown Radeon card. <= R500 won't work, new cards might.
Collecting data, please wait....
radeontop 1.4, running on UNKNOWN_CHIP bus 03, 120 samples/sec
any ideas?
thanks everyone :melting_face:
ended up restoring a snap from 1/15… issue is of course gone… just wondering if anyone could glean anything – like I said this happened out of the blue, not during some video package tomfoolery :smiley:
:military_helmet: :no_bell:
hmm, issue actually returned as soon as i did a full garuda-update :frowning:
any ideas?
Not sure but could it be related to what is mentioned here?
https://wiki.archlinux.org/title/AMDGPU_PRO#Firmware_and_AMD_drivers
