Stuck on "Loading initial ramdisk..."
I installed the dragonized version of garuda and when I start my PC its stuck on "Loading initial ramdisk..." :<
Read
please
and post
inxi -Fxxxza
as text! Even if you personally think it is unnecessary.
and
:slight_smile:
I'm having same issue, here's my inxi output, I really appreciate the help, please let me know if this is the right place to add my stuff.
âžś  ~ inxi -Fxxxza
System:    Kernel: 5.11.16-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
           parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=663c3018-28fe-47e4-ac2f-8282f1e10769
           Desktop: GNOME 40.1 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0 Distro: Garuda Linux
Machine:   Type: Laptop System: ASUSTeK product: ZenBook UX334FLC_UX334FL v: 1.0 serial: <filter>
           Mobo: ASUSTeK model: UX334FLC v: 1.0 serial: <filter> UEFI: American Megatrends v: UX334FLC.306
           date: 05/12/2020
Battery:   ID-1: BAT0 charge: 45.5 Wh (98.9%) condition: 46.0/50.0 Wh (91.9%) volts: 11.9 min: 11.9
           model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Charging cycles: 44
CPU:       Info: Quad Core model: Intel Core i7-10510U bits: 64 type: MT MCP arch: Kaby Lake note: check
           family: 6 model-id: 8E (142) stepping: C (12) microcode: DE cache: L2: 8 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 36799
           Speed: 4837 MHz min/max: 400/4900 MHz Core speeds (MHz): 1: 4837 2: 4499 3: 4904 4: 4854
           5: 4423 6: 4801 7: 4871 8: 4347
Graphics:  Device-1: Intel UHD Graphics vendor: ASUSTeK driver: i915 v: kernel bus-ID: 00:02.0
           Device-2: NVIDIA GP108BM [GeForce MX250] vendor: ASUSTeK driver: nouveau v: kernel
           bus-ID: 02:00.0 chip-ID: 10de:1d52 class-ID: 0302
           Device-3: IMC Networks USB2.0 HD IR UVC WebCam type: USB driver: uvcvideo bus-ID: 1-5:4
           chip-ID: 13d3:56cb class-ID: 0e02 serial: <filter>
           Device-4: Logitech OrbiCam type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-6.2.2:10
           chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
           Display: x11 server: X.Org 1.20.11 compositor: gnome-shell driver:
           loaded: intel,modesetting,nouveau alternate: fbdev,nv,vesa display-ID: :1 screens: 1
           Screen-1: 0 s-res: 6400x1440 s-dpi: 96 s-size: 1693x381mm (66.7x15.0") s-diag: 1735mm (68.3")
           Monitor-1: HDMI2 res: 2560x1440 hz: 60 dpi: 93 size: 700x390mm (27.6x15.4") diag: 801mm (31.5")
           Monitor-2: DVI-I-3-2 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7")
           diag: 604mm (23.8")
           Monitor-3: DVI-I-2-1 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7")
           diag: 604mm (23.8")
           OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.0.3 direct render: Yes
Audio:     Device-1: Intel Comet Lake PCH-LP cAVS vendor: ASUSTeK driver: snd_hda_intel v: kernel
           alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0403
           Device-2: Logitech OrbiCam type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-6.2.2:10
           Device-3: DisplayLink Dell Universal Dock D6000 type: USB driver: cdc_ncm,snd-usb-audio,usbfs
           bus-ID: 2-4.1:3 chip-ID: 17e9:6006 class-ID: 0a00 serial: <filter>
           Sound Server-1: ALSA v: k5.11.16-zen1-1-zen running: yes
           Sound Server-4: PipeWire v: 0.3.26 running: no
Network:   Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel port: 4000
           bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
           IF-ID-2: enp0s20f0u4u1i5 state: down mac: <filter>
Bluetooth: Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-10:6 chip-ID: 8087:0026 class-ID: e001
Drives:    Local Storage: total: 476.94 GiB used: 37.45 GiB (7.9%)
           ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8 size: 476.94 GiB
           block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
           serial: <filter> rev: 002C temp: 43.9 C scheme: GPT
Partition: ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 37.44 GiB (7.9%) fs: btrfs
           ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 560 KiB (0.2%) fs: vfat
           ID-3: /home raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 37.44 GiB (7.9%) fs: btrfs
           ID-4: /var/log raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 37.44 GiB (7.9%) fs: btrfs
           ID-5: /var/tmp raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 37.44 GiB (7.9%) fs: btrfs
Swap:      Kernel: swappiness: 10 (default 60) cache-pressure: 75 (default 100)
           ID-1: swap-1 type: zram size: 1.93 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
           ID-2: swap-2 type: zram size: 1.93 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
           ID-3: swap-3 type: zram size: 1.93 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
           ID-4: swap-4 type: zram size: 1.93 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
           ID-5: swap-5 type: zram size: 1.93 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
           ID-6: swap-6 type: zram size: 1.93 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
           ID-7: swap-7 type: zram size: 1.93 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
           ID-8: swap-8 type: zram size: 1.93 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
Sensors:   System Temperatures: cpu: 57.0 C mobo: N/A gpu: nouveau temp: 56.0 C
           Fan Speeds (RPM): cpu: 3500
Info:      Processes: 314 Uptime: 24m wakeups: 40 Memory: 15.43 GiB used: 3.83 GiB (24.8%) Init: systemd
           v: 248 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1354 lib: 363
           Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.04
