Hey everyone,
I have Garuda Dragonized installed on my laptop, which hasn't been updated for over a month. Now when I try to update, the system gets stuck on loading initial ramdisk. If I revert to the latest snapshot from last month, everything works fine.
Any clues?
Thanks in advance for any help!
filo
22 July 2021 08:57
3
Normally, Iâd check the pacman.log to see what was updated and try understand what might have an impact on the boot process, but I think that skipping updates for over a month would make it a mission impossible.
I think you should try to re-execute the update and then start troubleshooting with:
While there are many potential reasons why your installation doesnât boot to a desktop, the primary reason is that the graphics drivers havenât loaded correctly so your login/display manager (DM) doesnât start. This is why you get a âblack screenâ or stuck at an
[ OK ] Started some service
message.
The normal reason for this is that you have the incorrect driver version for the kernel. This can happens when the mirror you are updating from is not fully synchronised, or times out, and so yâŚ
I would suggest one thing. Read the post in announcements about the changes to garuda common settings and make sure you don't have the zram setter which was used initially if you have uninstall it then update your system
filo
22 July 2021 09:59
5
Rather than unistalling, I'd say make sure to "Press yes to the systemd-swap removal (to make sure not two applications are setting up ZRAM)"
XerXes:
Always use the terminal and pacman update commands when updating after long time. GUI applications are not always handling pacman interactivity properly (except octopi that I know of).
If you did use pacman in terminal, then post the output of the installation process (only), so we can see the possible problem. (use text, not images)
@petsam
Here is my terminal output:
(1/5) Creating Timeshift snapshot before upgrade...
Using system disk as snapshot device for creating snapshots in BTRFS mode
Mounted '/dev/sda2' at '/run/timeshift/backup'
Creating new backup...(BTRFS)
Saving to device: /dev/sda2, mounted at path: /run/timeshift/backup
Created directory: /run/timeshift/backup/timeshift-btrfs/snapshots/2021-07-22_16-55-15
Created subvolume snapshot: /run/timeshift/backup/timeshift-btrfs/snapshots/2021-07-22_16-55-15/@
Created control file: /run/timeshift/backup/timeshift-btrfs/snapshots/2021-07-22_16-55-15/info.json
BTRFS Snapshot saved successfully (0s)
Tagged snapshot '2021-07-22_16-55-15''cp /etc/skel/.config/fish/config.fish ~/.config/fish/config.fish'
(192/363) upgrading kvantum-qt5 [------------------------------------] 100%
(193/363) upgrading kvantum-theme-sweet-git [------------------------------------] 100%
(194/363) upgrading sweet-kde-git [------------------------------------] 100%
(195/363) upgrading kactivities-stats [------------------------------------] 100%
(196/363) upgrading kactivitymanagerd [------------------------------------] 100%
(197/363) upgrading ktexteditor [------------------------------------] 100%
(198/363) upgrading kdesu [------------------------------------] 100%
(199/363) upgrading kde-cli-tools [------------------------------------] 100%
(200/363) upgrading knotifyconfig [------------------------------------] 100%
(201/363) upgrading libksysguard [------------------------------------] 100%
(202/363) upgrading ksystemstats [------------------------------------] 100%
(203/363) upgrading kholidays [------------------------------------] 100%
(204/363) upgrading kirigami2 [------------------------------------] 100%
(205/363) upgrading plasma-framework [------------------------------------] 100%
(206/363) upgrading threadweaver [------------------------------------] 100%
(207/363) upgrading krunner [------------------------------------] 100%
(208/363) upgrading milou [------------------------------------] 100%
(209/363) upgrading pipewire [------------------------------------] 100%
(210/363) upgrading layer-shell-qt [------------------------------------] 100%
(211/363) upgrading kscreenlocker [------------------------------------] 100%
(212/363) upgrading kwayland-server [------------------------------------] 100%
(213/363) upgrading kwin [------------------------------------] 100%
(214/363) upgrading qqc2-desktop-style [------------------------------------] 100%
(215/363) upgrading plasma-integration [------------------------------------] 100%
(216/363) upgrading kpeople [------------------------------------] 100%
(217/363) upgrading libkscreen [------------------------------------] 100%
(218/363) upgrading kquickcharts [------------------------------------] 100%
(219/363) upgrading plasma-workspace [------------------------------------] 100%
(220/363) upgrading kunitconversion [------------------------------------] 100%
(221/363) upgrading kemoticons [------------------------------------] 100%
(222/363) upgrading kdelibs4support [------------------------------------] 100%
(223/363) upgrading systemsettings [------------------------------------] 100%
(224/363) upgrading kmenuedit [------------------------------------] 100%
(225/363) upgrading polkit-kde-agent [------------------------------------] 100%
(226/363) upgrading plasma-desktop [------------------------------------] 100%
(227/363) upgrading garuda-dr460nized [------------------------------------] 100%
==> Updating font cache..
==> Performing misc postinstall operations..
==> Done. Relog to apply changes & unleash the dragon! đ
==> To follow user config changes open up Garuda Assistant & hit apply configs.
(228/363) upgrading garuda-gamer-git [------------------------------------] 100%
(229/363) installing garuda-hotfixes [------------------------------------] 100%
(230/363) installing garuda-system-maintenance [------------------------------------] 100%
(231/363) upgrading garuda-wallpapers [------------------------------------] 100%
(232/363) upgrading garuda-welcome-git [------------------------------------] 100%
(233/363) upgrading garuda-zsh-config [------------------------------------] 100%
==> To follow zsh config changes execute 'cp /etc/skel/.zshrc ~/.zshrc'
(234/363) upgrading libavif [------------------------------------] 100%
(235/363) upgrading gd [------------------------------------] 100%
(236/363) upgrading imath [------------------------------------] 100%
(237/363) upgrading openexr [------------------------------------] 100%
(238/363) upgrading poppler-glib [------------------------------------] 100%
(239/363) upgrading lapack [------------------------------------] 100%
(240/363) upgrading gegl [------------------------------------] 100%
(241/363) upgrading graphviz [------------------------------------] 100%
(242/363) upgrading gimp [------------------------------------] 100%
(243/363) upgrading glu [------------------------------------] 100%
(244/363) upgrading gnome-disk-utility [------------------------------------] 100%
(245/363) upgrading xorg-xwayland [------------------------------------] 100%
(246/363) upgrading libnm [------------------------------------] 100%
(247/363) upgrading mutter [------------------------------------] 100%
(248/363) upgrading pipewire-media-session [------------------------------------] 100%
(249/363) upgrading gst-plugin-pipewire [------------------------------------] 100%
(250/363) upgrading gst-plugins-bad-libs [------------------------------------] 100%
(251/363) upgrading vulkan-headers [------------------------------------] 100%
(252/363) upgrading gnome-shell [------------------------------------] 100%
(253/363) upgrading groff [------------------------------------] 100%
(254/363) upgrading mpg123 [------------------------------------] 100%
(255/363) upgrading hwloc [------------------------------------] 100%
(256/363) upgrading imagemagick [------------------------------------] 100%
(257/363) upgrading gst-plugins-bad [------------------------------------] 100%
(258/363) upgrading libkipi [------------------------------------] 100%
(259/363) upgrading libkdcraw [------------------------------------] 100%
(260/363) upgrading purpose [------------------------------------] 100%
(261/363) upgrading gwenview [------------------------------------] 100%
(262/363) upgrading perl-http-message [------------------------------------] 100%
(263/363) upgrading perl-libwww [------------------------------------] 100%
(264/363) upgrading hwinfo [------------------------------------] 100%
(265/363) upgrading iio-sensor-proxy [------------------------------------] 100%
(266/363) upgrading inxi [------------------------------------] 100%
(267/363) upgrading iproute2 [------------------------------------] 100%
(268/363) upgrading jre-openjdk-headless [------------------------------------] 100%
(269/363) upgrading jre-openjdk [------------------------------------] 100%
(270/363) upgrading jdk-openjdk [------------------------------------] 100%
(271/363) upgrading kaccounts-providers [------------------------------------] 100%
(272/363) upgrading kate [------------------------------------] 100%
(273/363) upgrading kcalc [------------------------------------] 100%
(274/363) upgrading kcalendarcore [------------------------------------] 100%
(275/363) upgrading kde-gtk-config [------------------------------------] 100%
(276/363) upgrading kdeconnect [------------------------------------] 100%
(277/363) upgrading libkexiv2 [------------------------------------] 100%
(278/363) upgrading kdegraphics-thumbnailers [------------------------------------] 100%
(279/363) upgrading kdeplasma-addons [------------------------------------] 100%
(280/363) upgrading kdialog [------------------------------------] 100%
(281/363) upgrading kget [------------------------------------] 100%
(282/363) upgrading kgpg [------------------------------------] 100%
(283/363) upgrading khotkeys [------------------------------------] 100%
(284/363) upgrading kinfocenter [------------------------------------] 100%
(285/363) upgrading libkgapi [------------------------------------] 100%
(286/363) upgrading kio-gdrive [------------------------------------] 100%
(287/363) upgrading kjs [------------------------------------] 100%
(288/363) upgrading mariadb-libs [------------------------------------] 100%
(289/363) upgrading python-simplejson [------------------------------------] 100%
(290/363) installing pugixml [------------------------------------] 100%
(291/363) installing waylandpp [------------------------------------] 100%
(292/363) installing kodi [------------------------------------] 100%
Optional dependencies for kodi
afpfs-ng: Apple shares support [installed]
bluez: Blutooth support [installed]
python-pybluez: Bluetooth support
pulseaudio: PulseAudio support [installed]
upower: Display battery level [installed]
(293/363) upgrading konsole [------------------------------------] 100%
(294/363) upgrading kpmcore [------------------------------------] 100%
(295/363) upgrading krfb [------------------------------------] 100%
(296/363) upgrading kscreen [------------------------------------] 100%
(297/363) upgrading kwallet-pam [------------------------------------] 100%
(298/363) upgrading kwayland-integration [------------------------------------] 100%
(299/363) upgrading latte-dock-git [------------------------------------] 100%
(300/363) upgrading less [------------------------------------] 100%
(301/363) upgrading lib32-libxcrypt [------------------------------------] 100%
(302/363) upgrading lib32-libldap [------------------------------------] 100%
(303/363) upgrading lib32-curl [------------------------------------] 100%
(304/363) upgrading lib32-libdrm [------------------------------------] 100%
(305/363) upgrading lib32-llvm-libs [------------------------------------] 100%
(306/363) upgrading lib32-vulkan-icd-loader [------------------------------------] 100%
(307/363) upgrading lib32-mesa [------------------------------------] 100%
(308/363) upgrading libcurl-gnutls [------------------------------------] 100%
(309/363) upgrading libglade [------------------------------------] 100%
(310/363) upgrading libmwaw [------------------------------------] 100%
(311/363) upgrading libva-utils [------------------------------------] 100%
(312/363) upgrading linux-firmware [------------------------------------] 100%
(313/363) upgrading mkinitcpio [------------------------------------] 100%
(314/363) upgrading linux-zen [------------------------------------] 100%
(315/363) upgrading linux-zen-headers [------------------------------------] 100%
(316/363) upgrading llvm [------------------------------------] 100%
(317/363) upgrading man-db [------------------------------------] 100%
(318/363) upgrading man-pages [------------------------------------] 100%
(319/363) upgrading mercurial [------------------------------------] 100%
(320/363) upgrading mhwd-nvidia [------------------------------------] 100%
(321/363) upgrading modemmanager-qt [------------------------------------] 100%
(322/363) upgrading mtools [------------------------------------] 100%
(323/363) upgrading networkmanager [------------------------------------] 100%
(324/363) upgrading networkmanager-qt [------------------------------------] 100%
(325/363) upgrading nextcloud-client [------------------------------------] 100%
(326/363) upgrading nm-cloud-setup [------------------------------------] 100%
(327/363) upgrading noto-fonts-emoji [------------------------------------] 100%
(328/363) upgrading okular [------------------------------------] 100%
(329/363) upgrading openfortivpn [------------------------------------] 100%
(330/363) upgrading openldap [------------------------------------] 100%
(331/363) upgrading partitionmanager [------------------------------------] 100%
(332/363) upgrading perl-file-basedir [------------------------------------] 100%
(333/363) upgrading plasma-browser-integration [------------------------------------] 100%
(334/363) upgrading plasma-nm [------------------------------------] 100%
(335/363) upgrading plasma-pa [------------------------------------] 100%
(336/363) upgrading plasma-thunderbolt [------------------------------------] 100%
(337/363) upgrading plasma-vault [------------------------------------] 100%
(338/363) upgrading plymouth-git [------------------------------------] 100%
(339/363) upgrading powerdevil [------------------------------------] 100%
(340/363) upgrading python-gpgme [------------------------------------] 100%
(341/363) upgrading python-matplotlib [------------------------------------] 100%
(342/363) upgrading python-urllib3 [------------------------------------] 100%
(343/363) upgrading python-requests [------------------------------------] 100%
(344/363) upgrading python-xlib [------------------------------------] 100%
(345/363) upgrading qbittorrent [------------------------------------] 100%
(346/363) upgrading qt5-tools [------------------------------------] 100%
(347/363) upgrading rpcbind [------------------------------------] 100%
(348/363) upgrading rust [------------------------------------] 100%
(349/363) upgrading sddm-kcm [------------------------------------] 100%
(350/363) upgrading skypeforlinux-stable-bin [------------------------------------] 100%
(351/363) upgrading sof-firmware [------------------------------------] 100%
(352/363) upgrading spectacle [------------------------------------] 100%
(353/363) upgrading systemd-sysvcompat [------------------------------------] 100%
(354/363) upgrading teamviewer [------------------------------------] 100%
The Teamviewer daemon must be running for Teamviewer to work.
Execute 'sudo systemctl enable teamviewerd' in a terminal.
(355/363) upgrading texinfo [------------------------------------] 100%
(356/363) upgrading thunderbird [------------------------------------] 100%
(357/363) upgrading tor [------------------------------------] 100%
(358/363) upgrading torbrowser-launcher [------------------------------------] 100%
(359/363) upgrading vpnc [------------------------------------] 100%
(360/363) upgrading vulkan-tools [------------------------------------] 100%
(361/363) upgrading xapp [------------------------------------] 100%
(362/363) upgrading xdg-desktop-portal-kde [------------------------------------] 100%
(363/363) upgrading yay [------------------------------------] 100%
( 1/36) Syncing all file systems...
( 2/36) Restoring Linux kernel modules...
++ uname -r
+ KVER=5.12.11-zen1-1-zen
+ test -e /usr/lib/modules/backup/5.12.11-zen1-1-zen
+ rsync -AHXal --ignore-existing /usr/lib/modules/backup/5.12.11-zen1-1-zen /usr/lib/modules/
+ rm -rf /usr/lib/modules/backup
( 3/36) Creating system user accounts...
( 4/36) Updating journal message catalog...
( 5/36) Reloading system manager configuration...
( 6/36) Updating udev hardware database...
( 7/36) Applying kernel sysctl settings...
( 8/36) Creating temporary files...
( 9/36) Reloading device manager configuration...
(10/36) Arming ConditionNeedsUpdate...
(11/36) Rebuilding certificate stores...
(12/36) Updating module dependencies...
(13/36) Install DKMS modules
==> dkms install --no-depmod -m nvidia -v 465.31 -k 5.13.4-zen1-1-zen
==> depmod 5.13.4-zen1-1-zen
(14/36) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'default'
-> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen.img
==> Starting build: 5.13.4-zen1-1-zen
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [autodetect]
-> Running build hook: [modconf]
-> Running build hook: [block]
==> WARNING: Possibly missing firmware for module: xhci_pci
-> Running build hook: [keyboard]
-> Running build hook: [keymap]
-> Running build hook: [consolefont]
-> Running build hook: [plymouth]
-> Running build hook: [resume]
-> Running build hook: [filesystems]
==> Generating module dependencies
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-zen.img
==> Image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'fallback'
-> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: aic94xx
==> WARNING: Possibly missing firmware for module: wd719x
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-zen-fallback.img
(15/36) Reloading system bus configuration...
(16/36) Warn about old perl modules
(17/36) Updating fontconfig cache...
(18/36) Foreign/AUR package notification
aircrack-ng-clang-git 20210602.d7d8c075-1
firefox-appmenu 88.0.1-1
kwin-lowlatency 5.21-1
lazpaint-bin 7.1.6-1
lib32-nvidia-utils-tkg 465.31-166
lib32-opencl-nvidia-tkg 465.31-166
nvidia-dkms-tkg 465.31-166
nvidia-egl-wayland-tkg 465.31-166
nvidia-settings-tkg 465.31-166
openboardview-git r749.f971415-1
snowflake 1.0.4-1
umit 1.0-1
(19/36) Updating Garuda specific hooks...
(20/36) Probing GDK-Pixbuf loader modules...
(21/36) Compiling GSettings XML schema files...
(22/36) Probing GTK3 input method modules...
(23/36) Updating icon theme caches...
(24/36) Checking for kernel changes...
(25/36) Mkinitcpio and GRUB update after transactions...
Found theme: /usr/share/grub/themes/garuda/theme.txt
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-zen-fallback.img
Found Windows Boot Manager on /dev/nvme0n1p1@/efi/Microsoft/Boot/bootmgfw.efi
Adding boot menu entry for UEFI Firmware Settings ...
Detecting snapshots ...
Info: Separate boot partition not detected
Found snapshot: 2021-07-22 16:55:15 | timeshift-btrfs/snapshots/2021-07-22_16-55-15/@
Found snapshot: 2021-07-22 16:32:28 | timeshift-btrfs/snapshots/2021-07-22_16-32-28/@
Found snapshot: 2021-07-22 16:28:19 | timeshift-btrfs/snapshots/2021-07-22_16-28-18/@
Found snapshot: 2021-07-22 00:12:48 | timeshift-btrfs/snapshots/2021-07-22_16-49-54/@
Found 4 snapshot(s)
done
(26/36) Orphaned package notification...
cht.sh-git r865.6d83c4d-1
ddcutil 1.1.0-1
python-systemd 234-8
python-sysv_ipc 1.1.0-1
(27/36) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/nsswitch.conf.pacnew
/etc/default/grub-btrfs/config.pacnew
/etc/default/grub.pacnew
/etc/pamac.conf.pacnew
/etc/mkinitcpio.conf.pacnew
/etc/nohang/nohang-desktop.conf.pacsave
/etc/pacman.conf.pacnew
/etc/plymouth/plymouthd.conf.pacnew
/etc/systemd/system.conf.pacnew
/etc/systemd/user.conf.pacnew
Please check and merge
(28/36) Updating pkgfile database...
(29/36) Checking which packages need to be rebuilt
foreign firefox-appmenu
(30/36) Updating the info directory file...
(31/36) Copy Thunderbird Distribution Settings
(32/36) Updating the appstream cache...
AppStream cache update completed successfully.
(33/36) Updating the desktop file MIME type cache...
(34/36) Updating the MIME type database...
(35/36) Updating the vlc plugin cache...
(36/36) Syncing all file systems...
Where is the problem?
SGS:
This seems to break your X/plasma. I donât see your screen to know exactly what happens, so replace it with normal and you may be lucky.
kwin 5.22.3-1
Run and answer yes to replace
sudo pacman -S kwin
Also,
Check and merge your pacnew files
Verify you need or not the Orphaned packages
Remove obsolete or unused kernels. If you use an old kernel, check if it is discontinued
Uninstall unused nvidia packages (if any are left from kernel removal)
Sadly, still no luck. I have replaced kwin-lowlatency with kwin, merged pacnew files using pacdiff, removed orphaned packages, I don't have any other kernels - I have only installed zen.
Also, I have updated nvidia drivers.
Still, when I try to reboot the system, it gets stuck on loading initial ramdisk and then nothing happens. Any other way to diagnose where the problem might be?
filo
23 July 2021 08:06
11
Maybe you could remove "quite splash" from boot parameters in the grub, to see additional messages and maybe also sometimes removing splash helps...
Edit: sorry, at that early step I don't think this will help at all (I got confused with stuck on plymouth screen)
SGS
23 July 2021 08:26
12
Or press ESC on splash screen.
If you dual-boot with Windows, that's the problem.
Check your BIOS if Secure and fast boot are disabled.
If you boot to a snapshot, restore to the snapshot from Timeshift before doing updates and reboot again to the main entry. Then update chaotic mirrorlist first. Next update chaotic keyring. Then full update packages.
I think it's some kernel and nvidia drivers combination issue if ur on desktop. If ur on laptop and it has integrated GPU u probably wouldn't have this problem until and unless u were booting on dgpu which has f** drivers
Go to terminal with ctrl+alt+F2
Try
lsmod | grep nvidia
If u see some stuff probably nvidia drivers are loaded, run this
startx
Erros are to be reported back here
If u didn't have the drivers loaded ull have to run
modprobe nvidia
startx
To check if u have the drivers at all ready to go run
lspci -nnk | grep nvidia
If u don't see nvidia in available drivers ull have to reinstall nvidia-all or something
Can you bring yourself to think of others when replying "ur" "u" are only used on mobiles, a lot of users will not be able to translate what you say not being offensive just saying
Eh, i am not able to understand what TIk said and what you said.
Well I can't and won't teach ppl what a dgpu is and how gpus work on desktop. If ur using nvidia laptop or desktop u have to do some research and know something Abt it to fix things. Thanks
I'm not asking for help I'm complaining about your computor illiteracy this is not a social media site for mobile phone users.
Write in a readable format not childish mobile phone gibberish eg what the â â â â is this "u" and this "Abt" and this "ur".
How do you expect users to understand it can't be translated
